Decal softener. Can it be re-applied several days later after initial application?
DOD
Hi,
I have been applying some US stars and bars decals made by Techmod to my PR XI . Using Ultimate Decal Setting Solution,  Normal strength.
It is not having much effect in getting the decals to conform to panel lines.
I can get the stronger versions but this is going to to several days. Would it still be ok to use the stronger solution on the decals after this time and still work?
Or just remove and start again when new solutions arrive?
Or suggest an alternative solution? There seems to be a mass of them out there!  And terminology: Setting, softening, fixer.....
Any help would appreciated.
David
2 hours ago, DOD said:
Hi,
David
I used the stronger Ultimate decal solutions quite some time after failing to get some thick decals to settle down. They worked very well indeed, saving the model from CFITing into the nearest wall.
I have used Microsoft for the last thirty-four Tears. It has almost
always succeeded in its task, together with a judiciously applied q-tip 😉
Cheers, Moggy
  • Haha 4
THE product in question is Microsol
Microsoft's self-"correction" feature in action 🤢
It should be "years"
Cheers, Moggy
Edited by Moggy
Self-corrector's bo-bo
  • Haha 2
Micro-set and Micro-sol are great for the great majority of modern transfers. For tougher transfers, I use Walthers Solvaset, and for old, thick Tamiya ones, hot water, Mr. Mark Setter and Mr. Mark Softer. I've tried using Mark Fit Strong, but frankly it was no better than the Micro-scale products. Apparently there's a Mark Fit Really, Really Strong, Honestly (actually Mark Fit Super Strong) available, but I haven't tried it because I can't find it easily.
I recall using Microsol several time on a Monogram F-82 - not because the Microscale transfers didn't take but, because they consisted of a sheet of stars on a lot of blank varnish, there was quite a lot of silvering to get rid of.
Whether Microsol is stronger than any of the others I can't say, but it works for me on the rare occasions it was needed, so I've never felt any drive to experiment with others..
Thanks to all who have replied. Have got useful information.
10 hours ago, stevehnz said:
This could be worth a go, I've never used setting solutions.
Steve.
Thanks for this Steve. I have never used Klear. It just seems funny to be using floor polish on models. But I shall investigate further.
David
"Fixer" is not the same product as "softener". The fixer is like a slightly stronger version of the decal's own adhesive, to give it that extra bit of adhesion to your model, as I understand it (I'm no expert on these matters, TBH).
Be very careful with softeners - I've read stories about decals being destroyed / badly-shrivelled by softeners they don't like. For every kit, I would recommend you try applying a "non-essential" marking before you dive right in and go for the main ones.
Hope this helps.
Chris.
PS: I remember a Youtube vid from several years ago.... The modeller added 5-8 drops of decal-softener to the water he dipped his decals in right at the start and he swore by this method. His results looked very creditable.
Edited by spruecutter96
Amending some information.
I use Daco soft setting solution. I only used the strong version once as it ruined the decal. That's why I prefer several applications of the soft one. Still, when I apply it in a row, some decals disintegrate. If I wait (at least) a couple of hours before a new coat - to be sure that the decal has hardened again -  all goes well.
Safer to try on a spare sheet, and also to test the stronger product, IMHO.
The best way to avoid silvering of decals begins with preparing the surface.
A method that i learned at the club many many years ago is to polish the surface to make it as shiny as possible. Usually well-applied Gunze gets me the surface I want - otherwise I spray clear varnish until the surface is as smooth as possible.
Then it's time for decalling - when applying Microsol it is well to remember that the decal wrinkles to begin with - then it smooths without having to do anything.
Sometimes I use a q-tip to help the decal get into the panel lines by rolling it gently along the panel line in question.
Cheers, Moggy
Yes you can, as long as you have not sealed the decals with a layer of varnish then you can reapply a decalsetting solution which will react on the decals...
I read that my Strong (red labeled) Decalsetting solution can be too strong for some decals. That's true, as not all decals are the same: on one side you have "semi-house-made/laser-printed" decals that are really thin and very flimsy and on the other hand you have Tamiya/Hasegawa decals that are really thick and strong. Placing my Strong Decalsetting on a laser-printed decal is asking for problems: it will indeed eat through such decal, but placing my Soft (green labeled) bottle on a Tamiya decal will give no results either... Hence the reason I supply three different strenghts of my Decalsetting solution...
Hope this helps...
Danny Coremans
DACO Products
www.dacoproducts.com
  • Thanks 3
Hope this helps...
Danny Coremans
DACO Products
Hi Danny,
Thanks for the reasoning behind the use of the different strengths. It has helped to explain their use better.
David
