Arie Vos Posted July 11, 2022 Share Posted July 11, 2022 I'll be building 2 NF-5B's from 314 squadron Royal Netherlands Air Force. One will be the original ESCI kit and the other one the Italeri re-issue. Link to the Italeri F-5B: https://www.scalemates.com/nl/kits/italeri-1275-f-5b-freedom-fighter--105831 One NF-5B will be K-4021 in the grey/green scheme. Underside will be RAL 7001; top colors will be RAL 6014 and RAL 7012. The second one will be K-4018 in the F-16 scheme. Underside will be FS36375; top colors will be FS 36118 and FS 36270. Decals will be Dutch Decal and I'll be using the Wolfpack-D F-5A/B update set. Drop tanks for K-4021 will come from AK3D and paint masks from LF Models ( https://www.scalemates.com/nl/kits/lf-models-m72105-northrop-nf-5a-freedom-fighter-rnlaf--1408872 ) These paint masks are for an NF-5A and with some slight modifications on the nose can also be used for an NF-5B. 7 Link to comment Share on other sites More sharing options...
Robert Stuart Posted July 11, 2022 Share Posted July 11, 2022 This all sounds good. The Dutch used RAL colours? Seen that elsewhere in Europe, but didn't know the Dutch did too? Link to comment Share on other sites More sharing options...
Arie Vos Posted July 11, 2022 Author Share Posted July 11, 2022 Depending on the era and aircraft different colour systems were used. Post-war till the arrival of the F-104G Starfighter mostly BS standard and own colour coding was used. From early '60's till the arrival of the F-16 mainly RAL-codes (sometimes translated to own codes) were used and from the F-16 onwards FS-paint system was used. The Dutch Army is (still) using RAL colours; with some exceptions like the Bushmaster-vehicles for which AUSCAM-colours are used. All can be found in the book: "Camouflage en kentekens op vliegtuigen van de Nederlandse strijdkrachten" 1 Link to comment Share on other sites More sharing options...
modelling minion Posted July 11, 2022 Share Posted July 11, 2022 Sounds like a very interesting project, looking forward to this. 🇺🇦 Link to comment Share on other sites More sharing options...
Arie Vos Posted July 17, 2022 Author Share Posted July 17, 2022 With my F-5B’s I started at the very beginning. From IPMS Austria I have the update set for the cockpit. Based on that I ceated the side panels from plastic card and plastic rod. As I want to use the Wolfpack-D set for the interior I had to slightly adjust the instrument panel. Added some plastic card to the upper part. Wolfpack-D parts in their place. Also adjusted the rear part of the cockpit. Need to detail this a bit more. Next up some more details and painting. 14 Link to comment Share on other sites More sharing options...
modelling minion Posted July 17, 2022 Share Posted July 17, 2022 That is a very nice start on the cockpit, the details you have added are going to make a big difference. 🇺🇦 Link to comment Share on other sites More sharing options...
Robert Stuart Posted July 17, 2022 Share Posted July 17, 2022 This promises to be an interesting build, lots of nice brass in those 'pits. Link to comment Share on other sites More sharing options...
Arie Vos Posted July 18, 2022 Author Share Posted July 18, 2022 Few more details added to the cockpit. Bit more details on the rear part and a wall between the front and rear part of the cockpit. The white part on the instrument panel will represent the roller-map. This was a typical feature of the Dutch NF-5A/B. 9 1 Link to comment Share on other sites More sharing options...
modelling minion Posted July 18, 2022 Share Posted July 18, 2022 More nice work, and great attention to detail in fitting parts specific to the NF-5B.👍 🇺🇦 1 Link to comment Share on other sites More sharing options...
Robert Stuart Posted July 18, 2022 Share Posted July 18, 2022 Very nice, thorough, detail work - I like it. Link to comment Share on other sites More sharing options...
Hook Posted July 18, 2022 Share Posted July 18, 2022 Lovely work so far! Link to comment Share on other sites More sharing options...
Arie Vos Posted July 19, 2022 Author Share Posted July 19, 2022 Not the biggest update. Openend up the intakes and the part of the fuselage. Will insert a piece of straw to simulate the air intake. Still a bit of sanding needed to smoothen it out. (The silver colored plastic is ESCI and the grey one is Italeri) 5 Link to comment Share on other sites More sharing options...
81-er Posted July 19, 2022 Share Posted July 19, 2022 Very impressive work there! I love the extra detailing in the cockpits. James 2 Link to comment Share on other sites More sharing options...
Robert Stuart Posted July 19, 2022 Share Posted July 19, 2022 Progress is progress, and I'm enjoying this build. 2 Link to comment Share on other sites More sharing options...
Arie Vos Posted July 21, 2022 Author Share Posted July 21, 2022 Intakes added with 6mm straw and a piece of plastic rod at the end: Sprayed both cockpits: 9 Link to comment Share on other sites More sharing options...
modelling minion Posted July 21, 2022 Share Posted July 21, 2022 The painted cockpits really do look good, ties in all the different materials used to improve them, and the straws for intakes look like they will work very well. 🇺🇦 1 Link to comment Share on other sites More sharing options...
Robert Stuart Posted July 21, 2022 Share Posted July 21, 2022 Those straws look effective, and seamless. And the cockpits are coming along nicely. 1 Link to comment Share on other sites More sharing options...
Courageous Posted July 21, 2022 Share Posted July 21, 2022 Nice work with the cockpits. Stuart Link to comment Share on other sites More sharing options...
Hook Posted July 22, 2022 Share Posted July 22, 2022 22 hours ago, Arie Vos said: Intakes added with 6mm straw and a piece of plastic rod at the end: I am so going to nick this idea. Lovely progress! 1 Link to comment Share on other sites More sharing options...
RidgeRunner Posted July 22, 2022 Share Posted July 22, 2022 I agree, that is really nice upgrade work on the cockpits. Martin Link to comment Share on other sites More sharing options...
Mr T Posted July 22, 2022 Share Posted July 22, 2022 Very nice work there, I couldn't find any cockpit upgrades for my CF116, but the canopy will be closed anyway. Link to comment Share on other sites More sharing options...
Arie Vos Posted July 24, 2022 Author Share Posted July 24, 2022 Fuselage glued together, wings attached and sanded. Seems that my ESCI kit (the silver plastic one) is also warped. Needed some bending, twisting and tape to get it straight. The Italeri one, in grey plasic, had no issue at all. 6 Link to comment Share on other sites More sharing options...
Robert Stuart Posted July 24, 2022 Share Posted July 24, 2022 Good progress there - I'd say they are coming together nicely, but ... warping Think the warping will be down to the age of the kit, and, perhaps the plastic used, but, you are recovering well Link to comment Share on other sites More sharing options...
modelling minion Posted July 24, 2022 Share Posted July 24, 2022 They're both taking shape very nicely, even with the warping issues you have had to deal with. 🇺🇦 Link to comment Share on other sites More sharing options...
Arie Vos Posted August 3, 2022 Author Share Posted August 3, 2022 Managed to put the fuselage together, wings on and sanding. Wing tip tanks on. Landing gear installed and replaced the small air intakes on top and bottom of the fuselage by Quickboost ones. Pitot tus is a metal one from Master Model. Also replaced the AOA-indicator with a metal one from Master Model. One of the typical features of the NF-5 is the changed slat. One needs to add a small bit at the end and remove this bit from the wing. 8 Link to comment Share on other sites More sharing options...
