Ju.88A-4 Interior 3D Decal (QD32114 for Revell) 1:32
1:32 Quinta Studios
When Quinta’s innovative products first came to our attention, they caused quite a stir, as well they should.  The replacement Instrument Panels and internal details are mind-boggling to look at, because we’re used to seeing simplified styrene instrument panels, or Photo-Etch Brass panels with either two layers of etch, or laminated parts that can be tricky to glue together, even though they are pre-painted for your ease.  But decals?  These aren’t your run-of-the-mill decals though, they’re 3D printed in many layers and colours on a flat carrier film, having as much in the way of elevation as is needed to complete a realistic panel printed in the correct colours, complete with shiny dial faces and metallic-effect hardware, and often including cushions and seat belts in the set.
Each set arrives in a ziplok bag with a folded instruction booklet protecting the decals, which are also separately bagged, so they should reach you in good condition.  The pictorial instructions are printed on glossy paper, and are shown in full colour as befits the awesomeness of the sets, showing exactly where each part should go on the actual model, so there’s no confusion due to the “pictures speak a thousand words” maxim.  Additional hints and instructions are also included, marking out parts needing bases, kit parts that are used or replaced and other useful tips.  The technical instructions in the text-based, giving additional tips to the new user about maximising adhesion and preventing lift at the edges by wicking in super glue.
Although you are advised to use Super Glue (CA) to attach the decals to the surface permanently, preparation is much the same as your standard decal, but you will need to remove any raised detail that would be underneath the location depicted in the instructions, and some new parts will need small backing panels or bases on which to apply the decal.  A slim piece of sheet styrene would perform that task, and painting the edges a matching colour should minimise its appearance or turn it completely invisible.
This set is patterned for the big Revell Junkers Ju.88, which is a nice kit in itself that deserves a little extra detail in the cockpit area, especially given its size and the expansive greenhouse of a canopy.  The set comprises a staggering six sheets of decals, three of which contain identical sets of crew seatbelts, which are laminated up with comfort pads, adjusters and other details for each of the aircrew.  These can be draped however you like on the seats, with the instructions showing a few suggestions to help you on your way.
The main instrument panel is a tour-de-force of detail, with additional decals adding extra depth, more instruments on the yoke, and straps for the rudder pedals.  The radio panel is completely redone with superbly accurate fronts that are simply stunning.  The bomb-sight is similarly redone with dials, knobs and buttons added to the kit part, and a realistic slab of wood grain effect for the plotting table.  The other instruments around the cockpit are many and varied, adding depth, detail and colour to the area in heaps, as you can see from the instructions above.  The final aspect of the set is the sheet of ammunition belts that are used to adorn the various crew-served self-defence weapons around the airframe, getting more detail and colour in there than most of could achieve with a lifetime of practice.
Conclusion
The breadth of the set and the detail therein is incredible, even down to the infinitesimal switches and impressive crispness of the set.  This cockpit will be so impressive after completion that you will be desperate to open the canopy to show off the details.  It’s not a cheap set, but it is large, comprehensive and worth the expense.
Extremely highly recommended.
Review sample courtesy of
17 minutes ago, Hook said:
That does look pretty amazing!
It's even prettier in the flesh.  Like I said on Facebook, the Superlative machine is in top gear ;)
