Mike Posted July 1, 2022 Share Posted July 1, 2022 StuG III Ausf.G (36480 for MiniArt) 1:35 Eduard MiniArt’s new range of StuGs have become the de facto standard kit in 1:35 since their recent launch (only my humble opinion of course), and as is usually the case with their toolings, they have been crafted with multiple variants in mind. You can always improve on injection moulded styrene though, and this set intends to do just that, although because of the quality of the base kit, it’s not the largest of Eduard’s sets. As usual with Eduard's Photo-Etch (PE) and Mask sets, they arrive in a flat resealable package, with a white backing card protecting the contents and the instructions that are sandwiched between. Inside is a single fret of nickel-plated brass PE, with some parts pre-painted for realism, such as the jack block that is covered with a light wooden texturing, and a few belts that are red-brown colour. It includes a replacement bracket for the glacis, chains for the towing shackle pins at the rear, and a heat deflecting piece of tinwork under the overhang next to the rear shackles. This will need bending to shape using a D-shaped template on the long part, and an L-shaped template for the side parts. They replace some styrene parts from the kit, so you can use those as a guide on how to shape the new parts. At the rear of the casemate a long bracket is fixed across the width to carry a number of spare track links that double up as extra armour to the weaker rear, and are fixed in place on styrene brackets that are already moulded-in, and have PE wingnuts added to the ends. A suitcase-style stowage box on the exterior is cleaned of its moulded-in hinges and closures, after which a new set of parts are glued in place with improved detail and a padlock to complete it. Another padlock and two-part L-shaped eye is fitted to one of the hatches on the casemate, and after removing the styrene supports for the jack block on the fender, a replacement block is made from the pre-painted part, then it is wrapped in strengthening straps, has a pair of lifting handles fixed to the ends, and a bracket that secures it to the fender on opposite corners, with the painted strap holding it down. A small but effective set of parts. Highly recommended. Review sample courtesy of 1 Link to comment Share on other sites More sharing options...
Stef N. Posted July 2, 2022 Share Posted July 2, 2022 These new, fantastically detailed kits from Miniart, RFM etc are really hard for Eduard and co to improve as shown by a single small fret. Link to comment Share on other sites More sharing options...
