Mike Posted June 27, 2022 Share Posted June 27, 2022 F6F-3 Upgrade Sets (for Eduard) 1:48 Eduard The F6F Hellcat was one of Eduard’s earlier kits, first released in 2008 with many subsequent reboxings and additive toolings to depict other variants going on over the years. It’s still a jolly nice kit, but would of course benefit from some upgrades to bring it bang-up-to-date. Eduard's new range of sets are here to improve on the kit detail in the usual modular manner. Get what you want for the areas you want to be more of a focal point. As usual with Eduard's Photo-Etch (PE) and Mask sets, they arrive in a flat resealable package, with a white backing card protecting the contents and the instructions that are sandwiched between. SPACE 3D Printed Cockpit Decals (3DL48068) The Eduard SPACE sets use new 3D printing techniques that lay down successive layers of different colour resin, creating highly realistic almost full complete panels that are supplied on a decal sheet. They can depict metallic shades, plus glossy, satin and matt colours too, which really ups the detail on everything they print. In addition, a small sheet of nickel-plated and pre-painted PE is included for the aspects of the set that lend themselves better to this medium, such as seatbelts and rudder pedals. The Hellcat’s cockpit is a cramped compartment, with large side console to the right and a small instrument panel in front of the pilot. The moulded-in details on these are removed and replaced by 3D printed decals that are jaw-dropping in their realism, with more decals on the sides of the console and cockpit walls, including a triplet of two-layer boxes with printed cabling gathered together below it. The panel is supplied in sections to fix to the front of the otherwise unused part G43 that is a blank panel, saving you from having to remove the details from the other part. The PE sheet includes new rudder pedals and a full set of seatbelts for the pilot, including comfort pads beneath the buckles and connectors. Masks Tface (EX865) these pre-cut masks supply you with a full set of masks for the canopy exterior on a large sheet of kabuki tape. Also included are another set of masks tailored to fit the interior of the glazing so that you can paint the inside of the canopy and give your model that extra bit of realism. In addition, you get a set of hub/tyre masks for all three wheels including the small tail-wheel, allowing you to cut the demarcations perfectly with little effort. Review sample courtesy of Link to comment Share on other sites More sharing options...
