Yes, a Triple 1/32 Border Models Lancaster Build...
8 hours ago, BorisAlexandrov said:
Followed for both the three Lancasters and the huge desk of yours.
How did you even build such a desk? I'm looking to build myself a diorama base as well...not for 3 Lancs though.
Hi mate,
Lots of MDF!!
And some help from a Carpenter Friend... 😉
No way could I build this on my own.
Got the legs on Alibaba, really cheap, even with delivery from China.
Splendid idea. I wouldn't have space in 1:144 for something like that. Do you have a 'Lancaster diorama' room ?
Unfortunately you're not the first to post that all the transparencies weren't delivered intact. From other comments I think that's a packaging problem. Good luck with replacing yours.
Mark
You are completely insane and I can't wait to see the ne t installment 😀😀😀
Pulling up a seat.
Tom
  • 1 month later...
Hello All,
Firstly, may I say; God Rest Her Majesty and God Save The King!
Apologies everyone on the time between posts, I hope this post makes up and explains the time between posts...
Plus work has been well, a swear word...
After watching Nigels Build Videos, I decided to start with the Business End and build the Lanc's around the Bomb Bays.
So, I made a trip to Duxford and paid for a trip around their Airspace Lancaster Mk.X including a really good look in the Bomb Bay.
I also took a trip to the Avro Museum and finally I am in possession of Digital Copies of the Lancaster Maintenance and Parts Catalogues.
Plenty of research to start then!
After studying the Kit, several issues became apparent.
Now, I am not going to spend the whole of this thread gushing about the shear injection moulding brilliance of this kit but it is clear that the limitations of this kit is the Injection Moulding Process itself...
p?i=8d7f86e08f5c912d71f4603530a529df
The same issues can be said for the bomb bay piping;
p?i=f3076c874e8717662f2fe52fb8bd3c5c
There are also some missing details (see below);
p?i=bd883b9dca3d2f27fae0446f6265a84b
After some soul searching and short of taking the birch to myself, I decided on some serious pipe and cabling fatigue;
  • I stripped back everything in the Bomb Bay and discarded the piping.
  • Made some bespoke photo etch for all three bomb bays
  • The Parts Lists told which pipes where alloy, steel etc.
  • Re-cabled the whole thing
p?i=305c0278e0342b663a5945e57677adb6
p?i=e2e9b40dc82127bcce51c0bdbc21447e
p?i=318aae43d4e644ea2f2a1950940a4e48
Then the usual, primer, steel, airframe aluminium coats, varnishing and here you go;
Firstly here is the B.1;
p?i=dba4490f07a6801e74271efa39f6ddd9
p?i=11ae79c69c56c1e354359bff1ef295a3
p?i=5978c4b95781fb0bcc1fab7d6189799d
p?i=b8f75c72d138c866b6961ea869471b0d
Here is the Lancaster B.III;
The Gearbox and Bracing Frame is from Iconair, the rest is scratch built
p?i=46d40da03f42c7bcb5320dbd6af1cd45
This is the back end deflector cowl and as with the rest of the kit, I decided to take the Iconair and can the surface
p?i=90fc192bfeb488ec8da3a83e624b3d88
p?i=eb75f99a2b5ede9b37b8a3045ba1f9d8
Here it is with the cowling on; note I had to widen it to fit this kit;
p?i=b452ce2ea679d4f91186c7fd9d864770
Finally here is the Lancaster B.I (Special);
The complete cowling is 3D Printed from using the HK Models Kit as a basis and then size tweaked;
p?i=90795cb1f02729f4a844dabfe3e4f6e5
Decided on bespoke photoetch to give a better representation of the service covers on the aircraft;
p?i=48c43b3bc3eb985ab08fa7dc344b8b7e
All hand drilled and riveted, couldn't resist a bit of battle damage and patching too 😉
p?i=3fe5a6c1f189b537303b46f193fb3a3a
Hope you like them!!
Edited by Crossofiron1971
  • Like 22
Iconicair is a modelling company run by Graham French, he produces whole kits mostly if not exclusively in 1/32 scale such as the Supermarine Attacker, but also fortunately items such as bomb trolleys and other airfield equipment, all to an extraordinarily high standard in resin.
Hello all,
Bit of an update for you; I have, at long last, on the third attempt, received the replacement, intact clear sprues!
Based on a 6 week delivery time from China;
The first set were the wrong sprues...
The second set were the correct sprues but these too arrived damaged
Third time lucky!
Four months later, I now have more spare sprues than I can wave a stick at!
p?i=99b98998f265c9df547a805cc9474ed1
I will keep you posted but I am talking to a specialist 3D Printing Company who can do me a 'clearer' version of the canopy and turrets...
  • Haha 2
  • Confused 1
  • 4 weeks later...
Hi everyone,
I wouldn't normally post something like this as it is quite a small assembly but when you do three of them, it kind of becomes a thing...
Completed the Navigators and Radio Operators Stations;
UK Aircraft Explored on Youtube has been invaluable in working out the cable runs and types.
p?i=9c34aa18b84cf8285074a1bb44709bcd
p?i=fc9be14e00c5593a1f8c25afe57fdf30
Some points for you;
  • There are four materials that go to make up the shared table;
  • - Aluminium Main Construction
  • - Hard Dark Wood for the Radio Operators Compartment Hinged Flap and the Navigators Document Tidy
  • - Light, Grained Wood for the Navigators Map Station Area
  • - Brass Strip Guide for the Adjustable Measuring Angle
  • Couldn't resist a pin up...
  • Because none of my Lanc's have the H2S Ground Radar System, The Fishpond Indicators supplied for the kit are not fitted
  • I used Fag Packet Cellophane to mimic the plastic sleeve the maps were placed in to allow the Navigator to crayon all over them and then reuse them...
As I have said, The Lancaster B.I will be undergoing maintenance on my table so I have Red Tagged the Radio Receiver and Transmitter for strip down and test
Also disconnected the Power Leads and Morse Code Cables
p?i=7b8d0ebeae5a199818bdf46755045b87
p?i=c35ad30293585e4725a708ac0cb8f636
Please note the Lancaster B.III (Special) Upkeep Mine Revolutions Counter for the Crew
p?i=a83c3f1fcf868143b7a4812fd5ed474b
On a Side note, I have also completed the first of the vehicles for my Diorama;
Here is the Bomb Trolley Type E for the Upkeep Mine from Iconicair
p?i=30978c5ac40c2de5b8c47880827ad07a
p?i=1b76ecca5f377e064ade191fa4103c16
p?i=66eb30e6148eb56d1295aa4da32b35b4
p?i=9a11dcc4bd901112b5bafe362e1c55eb
p?i=bae0464cdefe0e71ede1389b8714a0b4
Hope you like the bits...
Steve
  • Like 15
Brilliant madness!
But,
IconAir Bomb Trollies' with Ordinance, tractors etc
Ordinance
an authoritative order.
Similar:
edict
decree
law
injunction
fiat
command
order
rule
ruling
dictum
dictate
directive
mandate
enactment
statute
act
canon
regulation
ukase
pronunciamento
2.
a religious rite.
"his strict observance of religious ordinances was no doubt quickened by the remorse he felt"
Ordnance
Things that go boom!
Pedant hat off, inspirational stuff
cheers,
Pappy
Edited by Pappy
  • 2 months later...
Hello all,
For those who celebrate it, I hope you all had a pleasant Christmas Holiday.
Thought I would give you an update to prove I am still alive...
Now, I have so far, not had a single issue with this kit but with my obsession with cabling up and piping, the kit does flag up a small issue and this is depth.
The whole fuselage internal is a solid moulded piece and this is great but does not allow for piping between the spars.
p?i=9afe245301faa58a37d944ae5a7bbe22
So, I got rid of the assembly and started from scratch!
p?i=ef9fb2cc4f755e963ed9e6368cd182dc
Here is the detail in the Dambuster Model as it shows the holes left with the Bomb Aiming Kit removed for Chastise;
p?i=0a8b852a8f91c169f63b33a7bac97cd6
I had to play around with the Longerons on the nose section to make them look straight from the nose to aft.
More on this later,,,
p?i=99fc30489992123baf8d593c6f0c6144
p?i=232d9e6ca378c219263ed473784966e2
In other news;
Electrics are beginning to appear;
p?i=07e5471a673d35c01de24c9000b62862
Cockpit Floor etc, are done;
p?i=316b29dab799eea4653ae297f5cfc3a2
Seats and Controls Columns are done.
The one folded up is the standard in maintenance...
p?i=9655941bdb82f4b8de8ea2c0d9ba9250
Hope you like them!
Steve
On 24/06/2022 at 09:33, Crossofiron1971 said:
Here are  the three I am going to build;
  • Lancaster B.I - PA474-KC-A (-T/-V) PA474  'Thumper' MkIII Flt Lt Bob Knight 617 Sqn Woodhall Spa, England. 1944
DV385 rather than PA474: the latter is the BoBMF machine, which didn't serve with 617.
This sounds a superb project but is it just me that's frustrated by the pictures not loading?
I'm on a PC using Windows 10 and all I'm getting is link addresses that go to hobbyphoto but don't load.
Any help appreciated.
Dave
A fascinating level of 'forensic-ness' on display👍
To replicate everything here 3 times is 🤯
I hope it's ok to ask: when you form a fuselage vertical rib, are my eyes deceiving me, or is it correct to say they are H shaped, formed by having 2 brass flat strips parallel with the fuselage, with the middle piece of the rib cut out of plastic sheet into the correct shape, then glued at 90 degrees between the 2 brass strips?
Dave
Hi Dave,
Sorry you are having problems, for the modulators, I am using Hobby Photo Host?
6 minutes ago, Crossofiron1971 said:
Hi Dave,
If I stay on the page they are starting to appear but exceedingly slowly, what size are the images you're linking to?
Anyway, from what I can see you are an artist!!
Dave
Hi WP.
Pretty much;
p?i=a120e6912ce5e9241622fc3f5f260d4d
  • All of the parts are photo etched bespoke from my drawings
  • I lightly tack the main section to the wall so I can manipulate to get vertical and straight
  • Then add the two side strips to form the T Section; then run some Zap A Gap down to fill gaps to make them look as one
  • Finally, the grooved top piece is added after a slight role to curve the parts; more so of course at the back.
For the pure amongst us, I know for of the main joining sections were 'C' Sections but thought that a step too far, particularly as two will not be really seen at the back...
1 hour ago, Crossofiron1971 said:
Ah yes: Kitsworld can be a bit patchy at times but it's nice to have period and recent warbird versions of the same scheme. I suspect that some won't realise however...
