Devo Posted June 23, 2022 Share Posted June 23, 2022 G'day all, A couple of questions. Which wooden deck is the right one to buy for the Tamiya kit? I'm doing her in late 1945, with the non standard paint scheme applied in Australia. I'm going OOB for the rest of the build. Never used a wooden deck before. Do I need to remove any of the kits detail before applying the wooden deck? Cheers, Devo Link to comment Share on other sites More sharing options...
Faraway Posted June 23, 2022 Share Posted June 23, 2022 I’ve used a few wooden decks in 1/350 and 1/700 and usually get them from here https://www.bnamodelworld.com/ Which luckily is in the same country as you, so postage should be cheaper AND quicker. I have found that their prices are usually cheaper than other suppliers. Not sure what you mean by ‘which one is right’ the ones I’ve used have been from various manufacturers and all have fitted well. With regards removing kit detail, unlikely, but you will know when you come to fit the deck. More often you don’t ADD detail until the deck is in place. Jon Link to comment Share on other sites More sharing options...
Rich75 Posted June 23, 2022 Share Posted June 23, 2022 I have one from BNA as well for this kit as far as I can see its designed to fit straight over, I haven't fitted it yet but it looks very good, it will be going on soon....look forward to seeing yours in progress Link to comment Share on other sites More sharing options...
Devo Posted June 24, 2022 Author Share Posted June 24, 2022 On 6/23/2022 at 5:31 PM, Faraway said: I’ve used a few wooden decks in 1/350 and 1/700 and usually get them from here https://www.bnamodelworld.com/ Which luckily is in the same country as you, so postage should be cheaper AND quicker. I have found that their prices are usually cheaper than other suppliers. Not sure what you mean by ‘which one is right’ the ones I’ve used have been from various manufacturers and all have fitted well. With regards removing kit detail, unlikely, but you will know when you come to fit the deck. More often you don’t ADD detail until the deck is in place. Jon On 6/23/2022 at 7:03 PM, Rich75 said: I have one from BNA as well for this kit as far as I can see its designed to fit straight over, I haven't fitted it yet but it looks very good, it will be going on soon....look forward to seeing yours in progress Thanks for your response's fella's.👍 I wasn't sure if a Pontos deck was better than an Artwox deck was better than another brand etc etc and vice a versa.🤔 Link to comment Share on other sites More sharing options...
Devo Posted June 25, 2022 Author Share Posted June 25, 2022 Another question regarding paints. Getting the right paints made by Colourcoats is near on impossible in my part of the world. I only know of one shop in Australia to buy them them from and he is out of stock for what I need. As I have my kit (after a decade of procrastinating over buying it), I dont want to wait x amount of time waiting on getting Colourcoats paint. What Humbrol or Tamiya equivalents can I use for NARN 22 G-45, NARN 36 B-20 and Majors Anti-fouling Grey?? Thanks All, Devo Link to comment Share on other sites More sharing options...
Faraway Posted June 25, 2022 Share Posted June 25, 2022 LifeColor do a set of paint for Royal Navy Eastern Approachs. How accurate they are I’m not sure. Jon Link to comment Share on other sites More sharing options...
Rich75 Posted June 25, 2022 Share Posted June 25, 2022 I think hataka have a decent range of RN colours too, but how accurate I don't know, I have only used colourcoats myself, nice scheme though don't see it very often... Link to comment Share on other sites More sharing options...
Jamie @ Sovereign Hobbies Posted June 25, 2022 Share Posted June 25, 2022 10 hours ago, Faraway said: LifeColor do a set of paint for Royal Navy Eastern Approachs. How accurate they are I’m not sure. Jon 1 hour ago, Rich75 said: I think hataka have a decent range of RN colours too, but how accurate I don't know, I have only used colourcoats myself, nice scheme though don't see it very often... Hi folks, both the above are based on the Snyder & Short chips originally offered by White Ensign Models as the original Colourcoats Royal Navy range at the turn of the millennium until we scrapped them in 2018. 1 Link to comment Share on other sites More sharing options...
Rich75 Posted June 25, 2022 Share Posted June 25, 2022 1 hour ago, Jamie @ Sovereign Hobbies said: Hi folks, both the above are based on the Snyder & Short chips originally offered by White Ensign Models as the original Colourcoats Royal Navy range at the turn of the millennium until we scrapped them in 2018. So not a bad shout then if @Devo can get them for his build? Link to comment Share on other sites More sharing options...
Jamie @ Sovereign Hobbies Posted June 26, 2022 Share Posted June 26, 2022 18 hours ago, Rich75 said: So not a bad shout then if @Devo can get them for his build? We did have to ditch them following the new research but without a big colour matching exercise with competitors' products (which isn't an exercise that will benefit me in the slightest) then they may be deemed serviceable. The G45 Snyder & Short chip is just wrong. It's badly aged and the binder has turned brown. This is similar to the sample of 507C held at Portsmouth which is the worst I've seen personally. An alternative would be to use the Snyder & Short matched 507C which isn't too bad but is too light and lacks the blue component it should have. The Snyder & Short matched B20 is too dark and again has the rogue yellow component from old paint binder turning yellow, rendering the appearance a greenish blue. There won't be a match for Moravia anti-fouling grey out there. That's something Richard Dennis discovered only relatively recently and we don't have a match either because there's nothing to match to - there are no known surviving samples of it, no colour data nor any known formula we can recreate and reverse engineer. We have instead estimated an approximation from our existing range based upon how the tone/brightness compares with neighbouring colours we do have the data for e.g. Home Fleet Grey. 1 Link to comment Share on other sites More sharing options...
Devo Posted June 27, 2022 Author Share Posted June 27, 2022 Thanks All for your input. As I am exclusively a hairy stick painter I shall try and match some Humbrol paints. (I prefer enamel's) and they are readily available to buy. Cheers, Devo 1 Link to comment Share on other sites More sharing options...
foeth Posted June 27, 2022 Share Posted June 27, 2022 Incidentally, I just uploaded a new post with previously unseen pics (well, to me at least) of KGV in Australia with a link to the famous Alan C Green pics https://ontheslipway.com/hms-king-george-v-visits-melbourne/ 3 2 Link to comment Share on other sites More sharing options...
dickrd Posted June 27, 2022 Share Posted June 27, 2022 5 hours ago, foeth said: Incidentally, I just uploaded a new post with previously unseen pics (well, to me at least) of KGV in Australia with a link to the famous Alan C Green pics Thank you for sharing these! 1 Link to comment Share on other sites More sharing options...
