Mike Posted June 8 Share Posted June 8 USS Enterprise NCC-1701A Refit (14021-1/1000 for Moebius) 1:1000 GreenStrawberry After losing Spock on the Genesis Planet at the end of the Wrath of Khan and getting him back in Search for Spock, the sneaky trick on the Klingons near the end of the film sees Kirk and co. leaving the bridge of the original refitted Enterprise for the last time just in time for it to blow up and take the deluded Klingons with it. Captain Kirk is a bit upset about that for obvious reasons, and they’re stuck flying a green Klingon Bird of Prey for most of the following Long Way Home movie, engaging in some time-travelling, whale kidnap and saving of the world once again. At the end of the movie, they get a new Enterprise as a thank you from a grateful earth, which they sail off into the black depths of space until the next film came calling, with many break-downs following a refit, and some chicanery from a group of baddies that frame Kirk for murder, at least temporarily. That’s a massive over-simplification of events, so if that doesn’t make any sense, just watch the films, some of which are better than others. The Kit Polar Lights kicked off a new series of Star Trek kits in the homogenous 1:1000 scale around the same time as Star Trek: Discovery reached our screens. This version of the Constitution Class Enterprise is available again as a reboxing, which also comes with some ‘damage’ decals for people wishing to depict the ship in a state of battle weariness. This set arrives in GreenStrawberry’s usual clear foil packaging with black card that has green and red branding, whilst inside are two frets of Photo-Etch (PE) separated by a sheet of black paper, a small printed sheet of self-adhesive paper, a thick chunk of card for protection, and the folded-up instruction sheets that are also doing some protective duties. Construction begins with removing a tiny raised light at the rear of the upper bridge, with a two-layer bulkhead added to the flat rear before it is joined to the lower. The lower section has a detail strip applied all around its middle, which includes vertical frames for the bridge windows at the rear, through which the simple insert that is made next will be seen. The floor of the insert is folded to create a bulkhead, and two additional short bulkhead sections are glued into grooves in the floor, and some half-thickness details are etched in the area nearest the windows. It is inserted from below and glued into position before it is placed in the centre of the saucer section. The lower surface of the saucer has two shuttered bays cut out to receive a pair of wedge-shaped inserts that are each folded up from four parts before they are slotted into place. These parts are identical to the Reliant set we reviewed recently. The impulse engine housing at the rear of the saucer section has the lower lip removed and a PE mesh insert fitted, with two more light fittings on the saucer nearby, and a PE spider placed over the dome-shaped Plasma Deflection Assembly just forward of the impulse engines. The similar-shaped Photon Torpedo housing at the base of the saucer ‘neck’ has a new insert made up from two main layers with additional bezels around the launch tubes. The central scanner array in the lower saucer has four PE skins added to the flat-fronted sections, while a trio of lights are added to the rim, and at the top of the neck a ribbed appliqué plate is glued to each side, butting up against the saucer. The edge of the saucer is decorated with new skins that have textured stripes and windows etched-in, with the ends shaped to fit around the Impulse Engine housing at the rear, and where the sections join at the sides, the left side is hidden by the application of the crew gangway over the top in a half-thickness socket. A circular hatch is installed at the bottom of both sides of the neck, with two more on the sides of the hull. The hull has a long, windowed section along the lower side with an arboretum stretching from side-to-side, and this is updated with a PE window frame part on each side, which will allow the interior to be seen. The arboretum itself is made up from a floor part that has pathways etched to half-height, and walls with etched-in fold lines that are bent up to support the roof section, onto which the sticker is fixed, giving the impression of lights and a blue cloudy sky, with the light portions having the PE etched away behind so that if you light the interior, it will show through the sticker. Two small curved skins are applied at the rear around the sides of the shuttle bay doors, with yet another little circular light added over the top. On the underside of the hull another pair of light fittings are glued onto the centreline - there are quite a few of these on the sheet. Moving to the warp nacelles, the kit inner nacelle sides have their striping removed, and the new PE replacements are glued into the recess instead, then at the rear the exhausts are inset with two new parts that make up a U-shape when complete. Yet another light fitting replaces the kit lumps at the rear of each of the nacelles. Conclusion Apart from some slight vagueness around the fitting of the arboretum (my kit is on its way, so I can’t peruse the parts together yet), this is another great set from GS with plenty of detail added to the base kit. Very highly recommended. Review sample courtesy of 2 Link to comment Share on other sites More sharing options...
