Look what the postman just delivered - the new submarine kit from Mikro-Mir......
Box art (Note the patriotic logo)
HMS Conqueror (S48) is the Royal Navy Churchill Class sub that sank the General Belgrano during the Falklands war.
First page of the instruction sheet...
Second sheet...
Decal shet (note the skull and crossbones) and etched propeller.....
Upper and Lower hull...
The rest of the parts...
It looks like a simple build - in the usual Mikro-Mir style - thanks to them for producing a kit of an important historical British submarine.
Can anyone confirm the white waterline markings - I don't think I've ever seen it on a RN sub before????
Ken
I think the waterline marking around the submarine is not from its operational life, but a legacy of being stored at the dockyard. When I visited HMS Courageous a few years ago, all of the submarines in storage had white lines painted around them. I assume it allows for an easy reference if they are taking on water as the stored submarines are probably not manned very often.
Nope...no white line. As @Flintstone says, the depicted w/l is too low.
Stuart
Thanks all for the info about the white waterline.... :thumbsup:
I used thin strips of plastic card glued to the hull sides to make a stronger join... there are only locating holes/pips at front and rear.
.... then glued to hull halves together.....
The joint isn't that good - so out with the filler....
It isn't as bad as it looks - I overdid it with the filler.
More later....
Ken
A little progress.....
Filler sanded down.....
Closeup of the front join - and the separate forward diving plane 'shoulders'.
Sail/conning tower parts - complete with inner decking.
Ken
  • Like 11
Looking nice.  I built one super fast last week to give to a co-worker who is an RN submarine officer. Nice quick build.  No super detailing. Lots of sanding. Can't wait see how yours turns out. I'll give my second one the detail treatment.
Dave
A little (slow) progress..... All the slots to take the tongues on the rudder and dive planes had to be reamed out to fit - :wall:
Ready for a coat of Halford's Grey Primer....
Note my botched attempt at depicting the louvre on the casing.
I tried to cut out a square of plastic - but my hand-eye co-ordination isn't up to it these days - so it's filled in and I'll just paint a black square on the finished model.
Ken
After a coat of Halford's Grey Plastic Primer...
... ready for a black topcoat....
For my black painted subs, I use a rattle can of Halford's Volvo Dark Grey - which gives a nice 'off-black' finish, suitable for this scale.....
Now I just need to mask off the anti-slip decking and paint it matt black - along with the side vents....
Off for a lie down now - it's too hot and muggy (although it's really Weggy) to do much.
Ken
  • 1 month later...
Just about to complete the kit. Nice model but:
Too many panel lines
Wrong colour draft Markings
It's a bit of a Falklands age mixed with post refit upgrades in 1985.
The missing outlets near the fin was a big miss.
Any ideas where you can get red draught marking for the 1/350 scale
Correct and a set of markings are missing from the forward edge of the rudder. I sabotaged a surplus decal sheet to get one.
There aren't any. Once fitted to surface, over-paint them with a diluted red or Tamiya Clear Red...very carefully. If you do a good job, you shouldn't see any tonal difference with the surrounding black.
HTH
Stuart
  • 3 weeks later...
Could you please expand on the missing outlets near the fin?
Are you referring to the square cut-outs that appear on the box lid but are missing on the kit?
cheers,
Pappy
Yes. This: vent
Stuart
On 8/8/2022 at 6:55 AM, Courageous said:
Yes. This: vent
Stuart
Great pic Stuart, thanks very much.
I posted a question regarding the screw/prop in the Maritime Cold war section but would also like to post it here:
HMS Conqueror information required - Maritime Cold War to 1990 - Britmodeller.com
Which way 'round does the prop face and which way should the blades be bent?
The destructions are not very explicit in this area
cheers,
Pappy
Edited by Pappy
Sorry, can't be much help here, I display my subs on a sea base so I don't have to worry about it. FWIW, my interpretation of it is the outer curves cut into the water, so they need to be bent forward and the rotation would be CCW when viewed from the rear looking forward. I hope that makes sense and I know a picture would make things much clearer but pics of propellers on warships/subs are a sensitive thing. Maybe someone else can help.
Stuart
Stuart
G'day Stu,
I undertand what you mean, that was my interperetation as well, just not sure whuch way around the prop spins.I would be very surprised if MM (or any manufacturer) got the prop shape 100% correct, apart from being a complex shape they are sensitive assets as you say. Most kit makers seem to screw up the noses on jets and they are in plain sight!
You say CCW is correct, story checks out....
chweers,
Pappy
On 8/10/2022 at 10:16 PM, Francis Macnaughton said:
Immensely, however, if I am looking at the pictures correctly, the screw rotates CW, contrary to that suggested by Stu?
In the pics included in the above link, the screws as viewed from above are looking from the rear forward?
confused
Pappy
Edited by Pappy
  • 3 weeks later...
Stuart
Sorry guys, the prop definitely is turning clockwise (not CCW) when looked from the rear. Please refer to this thread: https://www.britmodeller.com/forums/index.php?/topic/235082530-churchill-class-ssn-1350-scale-conversion/
