Trenton guy Posted May 24 Share Posted May 24 I’m just starting a 1/72 Canberra B.2, using the new AMP kit. The color scheme will be the early MSG/LSG with white u/s (circa 1953) as depicted on Xtradecal sheet 72301. Not sure what color the wing walk markings should be (I know they varied over time). I think that I have seen something on point here. Tried SEARCH but it defeats me every time (the first thing found with a search, title as above concerned the Sea Vixen followed by many more references having nothing to do with Canberras). Can anyone help? Link to comment Share on other sites More sharing options...
canberra kid Posted May 24 Share Posted May 24 1 hour ago, Trenton guy said: I’m just starting a 1/72 Canberra B.2, using the new AMP kit. The color scheme will be the early MSG/LSG with white u/s (circa 1953) as depicted on Xtradecal sheet 72301. Not sure what color the wing walk markings should be (I know they varied over time). I think that I have seen something on point here. Tried SEARCH but it defeats me every time (the first thing found with a search, title as above concerned the Sea Vixen followed by many more references having nothing to do with Canberras). Can anyone help? This is the best I can do, I hope it helps? John Link to comment Share on other sites More sharing options...
Trenton guy Posted May 24 Author Share Posted May 24 Definitely helps. Thanks so much. Do you have an alarm that goes off whenever the word Canberra appears in a post? However you do it, it is appreciated. Link to comment Share on other sites More sharing options...
canberra kid Posted May 24 Share Posted May 24 7 minutes ago, Trenton guy said: Definitely helps. Thanks so much. Do you have an alarm that goes off whenever the word Canberra appears in a post? However you do it, it is appreciated. Lol, it's like the Bat symbol, a Canberra shaped light appears in the sky over Bradford John 1 Link to comment Share on other sites More sharing options...
Julien Posted May 25 Share Posted May 25 18 hours ago, Trenton guy said: Definitely helps. Thanks so much. Do you have an alarm that goes off whenever the word Canberra appears in a post? However you do it, it is appreciated. I think he does I did a similar scheme and John helped me with the info. No one does these walkways so it was out with the masking tape! 1 Link to comment Share on other sites More sharing options...
Trenton guy Posted May 25 Author Share Posted May 25 Thanks, Julien.it is a great scheme and a very nice model. Link to comment Share on other sites More sharing options...
