shortCummins Posted June 4, 2022 Author Share Posted June 4, 2022 On 01/06/2022 at 12:43, Troy Smith said: It a lot more than a 4 blade prop, it an entire new front from firewall forward. There is no good OOB F4U-4 kit, I spent some time digging into this. Depends how fussed you are, and be aware there is also a load right tosh floating about various kits. If you want the 50's gray over white scheme, the was also used on AU-1, and while the dedicated Hasegawa AU-1 kit is hard to get, it's easy to backdate the F4U-7 kit, which was issued by Revell of Germany a while back. If you want a straight forward build with reasonable detail, Hobby Boss. It has its faults though. It's the best of the HB Corsairs, but only as the other -4 are poor. The Academy is a copy of the very old raised line Hasegawa -4 kit, with an added error of a too wide spine behind the cockpit. You will find many references to the Hase -4 being basically decent, and the Academy to being awful, its cobblers. I have a part hacked Academy -4, and found the fuselage too deep and square, so I got the fabled Hase -4, and it's the same. Plus raised panel lines and moulded in engine. There are -4 kits by Hobbycraft and a 60 vintage Monogram that gets repopped by Revell that are even worse. There is also a resin conversion by CMK, though for the money you could use the Academy nose and wings on the Tamiya -1......... Ages ago I was asking about some leftover Tamiya Corsair parts from your Thunderbolt/Corsair kitbash for just these reasons.... If you would like more info on this, just ask! HTH T Hi Troy I've tried to send you a PM but form some reason I can't? anyhow, I'm away on holiday in Cornwall until the 12th and I'll confirm that I still have the parts when I get back, I'm 99% sure I still have them rgds John(shortCummins) 1 Link to comment Share on other sites More sharing options...
Biggles87 Posted June 6, 2022 Share Posted June 6, 2022 Cornwall you say, it’s probably they folks from Devon interfering with the ozone layer. 😜 1 Link to comment Share on other sites More sharing options...
shortCummins Posted June 6, 2022 Author Share Posted June 6, 2022 24 minutes ago, Biggles87 said: Cornwall you say, it’s probably they folks from Devon interfering with the ozone layer. 😜 it's "the" burning question clotted cream before or after the jam on your scone? to be honest after the 2nd beer I don't really care 😄 but then I'm a grockel rgds John(shortCummins) 3 Link to comment Share on other sites More sharing options...
81-er Posted June 7, 2022 Share Posted June 7, 2022 I think the answer to that one is however you want as it's you who's eating said scone, while debating the REAL question; does it rhyme with "gone" or "cone" 🤣 James 2 Link to comment Share on other sites More sharing options...
Thom216 Posted June 7, 2022 Share Posted June 7, 2022 Lovely looking engine! 1 Link to comment Share on other sites More sharing options...
shortCummins Posted June 8, 2022 Author Share Posted June 8, 2022 On 07/06/2022 at 13:59, Thom216 said: Lovely looking engine! thanks Thom216 Quickboost have done a fantastic job with their resin version, adding some lead wire just gives it a little nudge and as you'll be able to see a reasonable amount once the model is complete I think its worth the effort rgds John(shortCummins) 1 Link to comment Share on other sites More sharing options...
shortCummins Posted June 15, 2022 Author Share Posted June 15, 2022 I want to add a control ring to the cowl flaps, I’m not sure that these will be visible once fitted to the aircraft?, so after a base coat of the salmon pink mixture I dabbed some CA glue to act as connectors for the control ring, these will be painted after the ring has been attached. The control ring was shaped from some thin wire… And then glued to the CA mounting blocks, some Tamiya tape was cut into thin strips, glued in place as “catches”… Both the ring, mounting blocks and catches were painted with more of the salmon primer and then picked out with some vallejo 77.702 duraluminium. There are ribs on the front cowl that I’ve added with some strips of plastic. Once again these were given a coat of the salmon primer. Next I’ll be applying some rivets. until next time as always, any suggestions, criticisms or comments will be gratefully received. rgds John(shortCummins) 7 Link to comment Share on other sites More sharing options...
bigbadbadge Posted June 15, 2022 Share Posted June 15, 2022 Hope you enjoyed your holidays John. That is some lovely detail John especially on the cowl flaps Great job Chris 1 Link to comment Share on other sites More sharing options...
81-er Posted June 15, 2022 Share Posted June 15, 2022 Very nice work on the cowl rings, great attention to detail. And as Chris said, I hope you had a nice break? James 1 Link to comment Share on other sites More sharing options...
Biggles87 Posted June 15, 2022 Share Posted June 15, 2022 Nice work on the cowl flap interior, I wouldn’t even attempt something like that in 1/48 these days and I took the easy way out on my 1/32 version with a Neomega resin set. John 1 Link to comment Share on other sites More sharing options...
shortCummins Posted June 17, 2022 Author Share Posted June 17, 2022 On 15/06/2022 at 13:06, bigbadbadge said: Hope you enjoyed your holidays John. That is some lovely detail John especially on the cowl flaps Great job Chris On 15/06/2022 at 13:26, 81-er said: Very nice work on the cowl rings, great attention to detail. And as Chris said, I hope you had a nice break? James On 15/06/2022 at 14:14, Biggles87 said: Nice work on the cowl flap interior, I wouldn’t even attempt something like that in 1/48 these days and I took the easy way out on my 1/32 version with a Neomega resin set. John thanks Chaps Cornwall was really good, we're rested and the dog (Finn) is worn out, all that chasing a ball into the sea and "walks" to the pub rgds John(shortCummins) 2 1 Link to comment Share on other sites More sharing options...
shortCummins Posted June 17, 2022 Author Share Posted June 17, 2022 I wanted to follow a suggestion from John (Biggles87) and paint the push-rods black. Before starting on the rivets I needed to build the wing/wheel well subassembly. I’d previously applied a coat of salmon pink primer over aluminium which I’d chipped. It was a shame to cover this as I really liked the effect however I sprayed a coat of MRP-135 insignia white (on top of hairspray)… …which was then chipped in an attempt to show both the salmon and aluminium. The top wing and intakes were fixed to the lower wing. Flaps and “outer” wings were assembled Next I’ll be adding the rivets. until next time as always, any suggestions, criticisms or comments will be gratefully received. rgds John(shortCummins) 10 Link to comment Share on other sites More sharing options...
81-er Posted June 17, 2022 Share Posted June 17, 2022 The multi-stage chipping in the wheel wells looks good, John, nice work James 1 Link to comment Share on other sites More sharing options...
Dunny Posted June 17, 2022 Share Posted June 17, 2022 Looking lovely John. I do like the added detail and those wheel wells looked far too good to paint over! Cheers, Roger Link to comment Share on other sites More sharing options...
Grey Beema Posted June 18, 2022 Share Posted June 18, 2022 Great work so far John. Are you building it ‘Flaps Down’ or ‘Flaps Up’ John? I’m curious because I want to see how you are going to cover the covers that go flush with the Flaps in the Up configuration.. Link to comment Share on other sites More sharing options...
bigbadbadge Posted June 18, 2022 Share Posted June 18, 2022 Nice work on the U/C bays John, it's all starting to come together well . Chris Link to comment Share on other sites More sharing options...
Biggles87 Posted June 18, 2022 Share Posted June 18, 2022 Nice work n the wheel wells John. on the subject of the flappery it might be worth checking on the square hole ( foot step? ) something in the back of my mind is saying that not all sub-types had them, just a thought. John 🇺🇦 1 Link to comment Share on other sites More sharing options...
shortCummins Posted June 18, 2022 Author Share Posted June 18, 2022 5 hours ago, Biggles87 said: Nice work n the wheel wells John. on the subject of the flappery it might be worth checking on the square hole ( foot step? ) something in the back of my mind is saying that not all sub-types had them, just a thought. John 🇺🇦 thanks John Tamiya's instructions tell you to fill the hole, I must remember to do that! rgds John(shortCummins) 1 Link to comment Share on other sites More sharing options...
Biggles87 Posted June 19, 2022 Share Posted June 19, 2022 It’s good to know that at least some of the little grey cells are still working. 😆 1 Link to comment Share on other sites More sharing options...
shortCummins Posted June 19, 2022 Author Share Posted June 19, 2022 It was easier to add the rivets prior to attaching this subassembly. I started by adding start and end points for the rivet lines with a felt-tip pen… …then these dots were joined by lines of rivets using my “Rosie the Riveter” tool. IPA wipes were used to clean off the dots, then the “horizontal” rivet lines were marked and joined then I used some “permanent marker” to highlight the rivets (cleaned off with som IPA). Next I’ll be adding the wings to the fuselage. until next time as always, any suggestions, criticisms or comments will be gratefully received. rgds John(shortCummins) 7 Link to comment Share on other sites More sharing options...
bigbadbadge Posted June 19, 2022 Share Posted June 19, 2022 Very nice indeed John, the rivets look great. Chris 1 Link to comment Share on other sites More sharing options...
shortCummins Posted June 19, 2022 Author Share Posted June 19, 2022 44 minutes ago, bigbadbadge said: Very nice indeed John, the rivets look great. Chris thanks Chris I'm not sure if they'll be seen once the primer and a 100 layers of coloured paint get added but I hope they'll make a difference rgds John(shortCummins) Link to comment Share on other sites More sharing options...
shortCummins Posted June 19, 2022 Author Share Posted June 19, 2022 The wing-root subassembly was attached… …followed by the horizontal stabilisers I’ve decided to have the wings extended rather than folded… …the “inside” of the spar has been left salmon pink… …outer wings attached. Next I’ll be preparing for painting. until next time as always, any suggestions, criticisms or comments will be gratefully received. rgds John(shortCummins) 8 Link to comment Share on other sites More sharing options...
Biggles87 Posted June 19, 2022 Share Posted June 19, 2022 Looking very Corsair-ish now. I just went to page 1 by mistake and realised how quickly you had reached this stage, I would probably still be working on the cockpit! John 🇺🇦 1 Link to comment Share on other sites More sharing options...
81-er Posted June 20, 2022 Share Posted June 20, 2022 Lovely work on those rivets, John James 1 Link to comment Share on other sites More sharing options...
