Hasegawa 1/48 VF-1S Strike Valkyrie
My bench has been jammed full of 1/32 aircraft builds (my regular choice of libation) so I decided to mix it up a bit and switch gears from 4 engine heavies. At least temporarily.
I've got a few Valkyrie kits in the stash, mostly Hasegawa 1/72 kits but also a couple of their 1/48 ones. There's also the Max Factory 1/20 release that I'm hoping to start later this year.
So the 1/48 Strike Valkyrie seemed like a nice warm up build for big brother. Here's the kit in question:
Sprues are in two colours plus clear. Here's the blue ones which are dedicated to the Strike bits.
The airframe parts are in white.
I started with filling many of the ejector  pin marks in the visible areas. I had to full some a couple times to get them flush.
Carl
I then started working on making several sub-assmblies.
Intakes/upper legs
Lower fuselage and swing wing pivots.
FAST pack armour/boosters for the legs.
Leg thrusters.
I missed documenting the forward fuselage assembly but that was pretty straightforward. Same for the lower legs/engine nacelles.
Here's some of the various sub-assmblies laid out.
I then started on the detail painting. I'm basically following the instructions for all of this.
There's also the vernier cones that need to be painted black. I used a circle template to mask those off.
Here's the FAST packs after removing all the masking tape.
The upper legs were next.
On the Strike Valkyrie, the upper packs have one with a twin beam cannon and the other has missle launchers in the front. Hasegawa has really added quite a bit of detail into these kits.
The missle pod nose even had individual missiles to be added before you close things up.
You can just see them in the assembled one on the right.
Here's the assembled upper boosters along with the legs/engine nacelles.
A quick mock-up.
Edited by FG2Si
Fix typo
  • Like 11
I'm slowly working on all the decals for the kit.
There's a lot of them. Even for places you'll never see, like the vertical tails:
Which then get folded over...
..and installed upside down.
More progress on the decals.
Stickers actually which is typical of Bandai. Whoops, wrong Strike Valkyrie.:lol:
Here's the right one.
I finally glued the legs and arms to the fuselage.
Flipping it over, I then attached the backpack (? I never knew what they called this part).
With that on, I've added the FAST packs.
On 5/24/2022 at 9:48 AM, JamesP said:
Those SD Valkyries are surprising good and fully transform.
Considering their age, they're definitely not bad. Bandai did a reissue last year of them and I grabbed both sets.
Finishing up all the small bits and I finally added the gun pod.
Upright, I just need need to add a few more decals to call it finished.
42 minutes ago, Thom216 said:
Awesome! Love those Macross kits. I don't have any 1/48, as 1/72 is my 'jet scale,' but that bigger kit must be a hoot to put together!
Thanks! Compared to their 1/72 Valkyrie kits, the 1/48 one has quite a bit more detail to it.
I usually build 1/32 aircraft but have been considering down sizing to 1/48 for my jets. Having a 1/32 Lanc and B-24 on the bench at the same time takes a lot of real estate.  Even if it's just their fuselages at the moment.
Carl
On 5/26/2022 at 9:39 PM, Thom216 said:
Looks like you're about to start a boneyard! Which looks awesome.
Lol, no boneyard. Just the pile of stalled projects.
Ok, I finally got the Strike Valkyrie done. The last few decals and details bits are on now.
Overall, it went together nicely and was a great distraction from my B-24 and Lanc builds. Once those are done and I learn how to do lighting, the 1/20 Strike Valkyrie will hit the bench.
Thanks to everyone who dropped by.
Carl
  • Like 9
  • 4 weeks later...
Carl
Outstanding build! I just received the same kit, shopping for photoetch bling for some additional touches.
PS: 1/20m you have the big PlayMax kit? I've been wanting one but they're hard to find, and the price jumped considerably. I should have bought one when they first hit the market.
Edited by HadesOmega
Thanks! Hasegawa makes a PE set and Jasmine models makes one too I believe.
Yes, I've got the Max Factory kit as well as the decal set that came out for it. The moment I saw it listed I ordered one. It's the biggest box in my stash and will certainly be the largest model I've got.
Carl
