Mike Posted May 12, 2022 Share Posted May 12, 2022 Gotha Go.242B Glider (48225) 1:48 ICM via Hannants Germany broke new ground in WWII in the successful use of Paratroop landings in gliders that met with some initial successes, although that method of delivering soldiers and materiel hasn’t seen much use since the end of WWII, possibly following the experiences of the Allies later in the war and around D-Day. Gotha created the small DFS 230 that was used by Fallschirmjager units during the early part of the war, and the RLM subsequently issued a specification for a larger glider that could carry 20 fully equipped troops into action, or alternatively bring equipment of an equivalent weight to the battle. Gotha’s offering was a simple tapered box on wings, but with a twin-tail boom that allowed the cargo version to unload from the rear using a simple flip-up rear fuselage, and later the troop carrier could also unload from the rear with the addition of new doors. The type entered service soon after its initial flight in 1941, with over 1,500 manufactured in various guises. The initial A series was split into troop and cargo types, with the following B series being improved from experience and sporting upgraded landing gear, plus double rear doors for faster troop exit. A further C series was intended for water landings using a boat-shaped hull to carry explosive-laden small boats to maritime targets, although that never reached service. Gotha later added engines in nacelles that extended the twin booms past the leading edge of the wings, allowing it to get aloft under its own power, rather than being towed by a Heinkel He.111 or adapted Stuka, but take-off was marginal with a heavy load, so RATO bottles were developed to give the aircraft an extra boost. The Kit This is a brand-new kit of this boxy glider, and the first of a number of variants no doubt. Despite their difficulties at the moment, ICM have worked hard to keep on producing kits, and our collective hats have to go off to them for that. The kit arrives in a top-opening box that has the Ukrainian flag emblazoned in the top right corner, and a painting showing the aircraft from below with its jettisonable landing gear clearly visible. The outer lid is extremely tight, and if you can get it off the usual captive inner lid is exposed, with eight sprues in grey styrene, one of clear parts, the instruction booklet in spot colour, and a long narrow decal sheet. The first thing that’s evident on perusal of the sprues is that the aircraft is larger than I expected, and the designers at ICM have put a lot of effort into the detail that’s moulded-into the model, especially the sections that are fabric over a tubular framework. Construction begins with the large floor space, which is made up from the fabric outer skin with visible ribbing, onto which the floor surface added in two sections, after drilling a number of 1mm holes in the skin first. The forward section is then enclosed by a tubular framework that stops at the centre bulkhead, which also has short spars moulded-in, with a bulkhead between the passenger and pilot sections. The twenty passenger seats are each made from horizontal and vertical sections that are then arranged into two rows of 10 and are fitted out with diagonal braces that mate with the rear legs, plus a length of top brackets that allow the seats to stand clear of the wall. Both rows are glued into the passenger compartment either side of the central spar, and a triangular section of framework is attached to the aft section of the area, following which the side walls are made up from two parts each and a number of windows that are applied from the inside. These are fixed to the floor assembly along with the roof once the cockpit is made up. Note that there are a few ejector-pin marks to erase on the interior if you're interested. Punched discs of styrene sheet, CA, or filler should do the trick. This is a training variant, so the controls are duplicated on both sides of the cockpit, starting with a well-detailed pair of rudder pedals that each comprise of four parts. The control column differs between stations, with the trainee having a two-part right-angle column with separate yoke, while the trainer has a straight stick for when he needs to take over. The seats differ too, as the trainee has a sturdier five-part seat that has an adjustment wheel, while the instructor has a simple two-part affair. These are all inserted onto a cockpit floor that is placed within the front of the fuselage at the time when the sides and roof are both added with a single tube bracing the top of the diagonal rear divide. The insertion and addition of the sidewalls are shown out of order in the instructions, but allowances have to be made for the little things under the circumstances. The cockpit surround is incomplete at this stage, having the nose added along with a simple instrument panel on a pair of supports fitted, then underneath a clear window is inserted beneath the instructor’s feet, plus two panels of side glazing and a single windscreen part that has an optional 0.8mm hole drilled in it before fitting if you are mounting the guns. Take it easy if you decide that’s the option for you, as clear styrene is much easier to damage because of its brittle nature. Light pressure and plenty of patience is the way to go. The wings of the 242 are necessarily long, as once the towing aircraft cuts it loose, the only way is down, so a long glide slope is an absolute necessity. The wings are each moulded as top and bottom skins, which have some lovely ribbing and other details moulded-in as you can see above, and have the flying surfaces as separate sub-assemblies of two parts each. Once the halves are joined, they have the front fairings of the booms added top and bottom, then have the two flap sections and long ailerons slotted into the trailing edges. This is repeated twice of course, and the two wings are slotted onto their projecting spar sections, taking care to put them on with the leading edges and canopy pointing in the same direction. A pair of supports are added underneath in recessed sockets, although I’d be tempted to leave those off until after main painting was complete so they don’t get damaged. The aft section of the fuselage is missing at this stage, giving it the look of a “ute”, but this part is next to be assembled. The tapering sides have windows inserted from inside and the internal framework added, then they are spaced apart by three more framework sections, after which the lower part with window, internal floor with steps, and roof with framework and observation window (the reason for the steps) added, to be finished off with a transparent end cap giving even better field of view, just in case they’re being stalked by a fighter from behind. The door pivots upward between the booms, and can either be glued closed, or propped open with five supports holding it at the correct angle. The booms are simple and made from two parts each, with separate rudders and a single elevator panel with separate flying surface. The instructions show the completed assembly being offered up to the rear of the model, but it may be more sensible to glue one boom in place first, then add the other with the elevator once the glue is set on the first boom. A number of actuators and mass balances are added all around the flying surfaces, but first the landing gear struts are added, beginning with the two main gear legs that are simple two-part assemblies with a corrugated gaiter over the suspension tube. The nose gear is a strange affair, made from a two-part yoke that traps the wheel between it, with a pair of V-shaped braces (moulded as one part) at the front, which fixes to the underside of the nose. The main wheels and nose wheel are each are two parts, and the former slide over the short axles to complete the gear. The final parts are used for two optional self-defence machine guns that are fixed to the windscreen and in front of the observation window in the aft section of the fuselage. Markings There are two decal options on the sheet, both very similar and sporting yellow wingtips with a tail band in the same colour. ICM have also included a printed template for masking the copious glazing that’s present on this aircraft, which should come in handy, and save some hassle, even if you’re OK with masking things up yourself. From the box you can build one of the following: Gotha Go.242B-2 Schleppgruppe 4, 1943 Gotha Go.242B-2 Germany, 1942 Decals are by ICM’s usual partner, which is a guarantee of good registration, sharpness and colour density, with a thin gloss carrier film cut close to the printed areas. Conclusion This is cool. The side profile alone sells it to me, but I do like the weird stuff. The detail is excellent, and apart from wishing there was a little more variety in markings options, it’s a big thumbs up for a kit that has been produced under very difficult circumstances. Very highly recommended. Available in the UK from importers H G Hannants Ltd. Review sample courtesy of 7 Link to comment Share on other sites More sharing options...
