TimT64 Posted May 7, 2022 Share Posted May 7, 2022 The Russian NK-33 engine was developed in the late 60’s and was planned for use to power the N1-F launch vehicle. The N1F was to be the successor to the ill-fated N1 launch vehicle. After the Russians attempt to get to the moon ended in failure and the program was cancelled the stock of engines were mothballed. In the mid 90’s Russia sold 36 of these engines to Aerojet who modified them slightly and used them in the first stage of the Antares 100 series launch vehicle The kit is a 1-12th Scale resin 3d print and was purchased from Accura Space models https://accuraspacemodels.com/ Good clear, comprehensive instructions Separate painting instructions Decals Pieces individually bagged Snap of the engine bell next to a coffee mug for idea of scale A start made with dry fitting all the parts. I am absolutely blown away by the quality of the printed parts and the fit is superb. The amount of fettling, filling, and sanding is going to be at an absolute minimum 11 Link to comment Share on other sites More sharing options...
Bertie McBoatface Posted May 7, 2022 Share Posted May 7, 2022 I can't wait to see this painted. 🤩 1 Link to comment Share on other sites More sharing options...
Uncle Monty Posted May 18, 2022 Share Posted May 18, 2022 That's a big engine alright 😀 1 Link to comment Share on other sites More sharing options...
TimT64 Posted August 4, 2022 Author Share Posted August 4, 2022 With all the dry fitting completed all the parts were primed. The bulk of them were primed using UMP (Stynylrez) black gloss. When the topcoat was painted a few parts showed print lines. These became apparent only after the application of the metallic, which was Vallejo. These were stripped back and reprimed using Alclad black primer with micro filler. Whilst this was successful in “covering” the print lines it left a bit of a rough surface, which is not the best for applying a metallic coat to. It does say in the instructions of the Alclad to buff up the parts after application, something I did not do. I will call that a lesson learnt and not go down that route again as it seems to be making unnecessary work especially considering there are other products that would not need a post painted “sanding/buffing session” to make the finish acceptable. I am slowly starting to drift away from using water based acrylics now that I have come up with a way of spraying lacquers without stinking the house out. (In a moment of inspiration I realised that if I placed my spray booth on the cooker top under the powerful extractor hood I can spray and all the smell is gone by the time the wife comes home!!!! The next time that I build a resin kit that will be painted in metallics I have this plan. Undercoat with black Mr Color surfacer 1500 mixed 50/50 with MR Levelling thinner. This is a fantastic micro filler, and gives a lovely smooth surface, it also keys really well to the resin. If a high gloss finish is required then a coat of Mr Color GX2 will be applied over the surfacer prior to the topcoat Then topcoats of metallics applied, using Vallejo acrylic paints Some very light weathering applied. A black panel line wash used on the lighter aluminium parts. photos here show the wash applied, but not yet toned down. Most of the wash was removed using odourless thinners There are a couple of gas spheres and a small section of pipework that required a green finish, with a high gloss sheen. These were painted with Tamiya acrylic paint, and top coated with VMS clearcoat The darker magnesium coloured turbo pump was treated to a panel line wash using a grey colour. The effect is very subtle, but enough to accentuate the nuts and bolts With all the parts ready time for assembly to begin Photos of the finished model can be seen here https://www.britmodeller.com/forums/index.php?/forum/387-ready-for-inspection-sf-amp-realspace/&do=add 8 Link to comment Share on other sites More sharing options...
xebec Posted August 4, 2022 Share Posted August 4, 2022 On 5/7/2022 at 11:09 AM, TimT64 said: I am absolutely blown away by the quality of the printed parts and the fit is superb. The amount of fettling, filling, and sanding is going to be at an absolute minimum That is very impressive- looks like a high-quality casting rather than a print. This is going to produce a lovely model. 1 Link to comment Share on other sites More sharing options...
