Reini78 Posted May 5, 2022 Share Posted May 5, 2022 It´s a long way to Mukumbura..... My dad´s next project, soon to be started DSC_0010 by grimreaper110, auf Flickr gonna do the lower scheme DSC_0011 by grimreaper110, auf Flickr 12 Link to comment Share on other sites More sharing options...
coneheadff Posted May 5, 2022 Share Posted May 5, 2022 Another great project!! 1 Link to comment Share on other sites More sharing options...
heloman1 Posted May 6, 2022 Share Posted May 6, 2022 Woooh, yes, I like this. I'll follow with interest coffee and croissants are ready... Colin 1 Link to comment Share on other sites More sharing options...
Reini78 Posted May 7, 2022 Author Share Posted May 7, 2022 was looking through our aftermarket stuff stash for a Quickboost seat I bought some time ago, when my dad told me he found a full True Details cockpit for the Hunter in another stash so let´s see how that turns out... DSC_0004 by grimreaper110, auf Flickr 7 Link to comment Share on other sites More sharing options...
Gondor44 Posted May 8, 2022 Share Posted May 8, 2022 Not my usual scale but it looks interesting enough to follow, it is a Hunter after all! Gondor 1 Link to comment Share on other sites More sharing options...
Reini78 Posted May 14, 2022 Author Share Posted May 14, 2022 so, finally enough free space to start this project testfitted the resin cockpit into the fuselage, fit is good the right sidewall is an extra part, the rest of the cockpit tub is in one piece DSC_0005 by grimreaper110, auf Flickr 2 Link to comment Share on other sites More sharing options...
Reini78 Posted May 16, 2022 Author Share Posted May 16, 2022 primed the resin parts, ready for paint DSC_0002 by grimreaper110, auf Flickr 4 Link to comment Share on other sites More sharing options...
Reini78 Posted May 18, 2022 Author Share Posted May 18, 2022 already painted all the cockpit parts black but although my dad washed/degreased and primed the resin, the paint was removed when he started to drybrush the isntruments and touched the parts too much also the CA glue didn´t connect well with the resin DSC_0001 by grimreaper110, auf Flickr DSC_0002 by grimreaper110, auf Flickr 1 1 Link to comment Share on other sites More sharing options...
coneheadff Posted May 18, 2022 Share Posted May 18, 2022 That is weird 😕 Link to comment Share on other sites More sharing options...
Reini78 Posted May 18, 2022 Author Share Posted May 18, 2022 my dad decided to use the cockpit tub and IB from the kit, sidewall panels and seat from True Details washed the resin parts again, for now the paint and CA glue holds DSC_0004 by grimreaper110, auf Flickr DSC_0005 by grimreaper110, auf Flickr 3 Link to comment Share on other sites More sharing options...
Reini78 Posted May 21, 2022 Author Share Posted May 21, 2022 cockpit tub done, painted and drybrushed DSC_0001 by grimreaper110, auf Flickr DSC_0002 by grimreaper110, auf Flickr 5 Link to comment Share on other sites More sharing options...
Reini78 Posted May 25, 2022 Author Share Posted May 25, 2022 fuselage closed added about 17g weight in total in the nose area DSC_0003 by grimreaper110, auf Flickr DSC_0004 by grimreaper110, auf Flickr DSC_0005 by grimreaper110, auf Flickr 5 Link to comment Share on other sites More sharing options...
Reini78 Posted May 28, 2022 Author Share Posted May 28, 2022 left wing went on more or less ok, the right wing not so, needs some filling in the wing root areas DSC_0001 by grimreaper110, auf Flickr DSC_0002 by grimreaper110, auf Flickr DSC_0003 by grimreaper110, auf Flickr DSC_0004 by grimreaper110, auf Flickr Link to comment Share on other sites More sharing options...
Reini78 Posted June 2, 2022 Author Share Posted June 2, 2022 had to fill a gap between inner airintake and leading edge too tailplane done gun bulges, speed brake and ailerons added DSC_0001 by grimreaper110, auf Flickr DSC_0002 by grimreaper110, auf Flickr DSC_0003 by grimreaper110, auf Flickr 3 Link to comment Share on other sites More sharing options...
Reini78 Posted June 9, 2022 Author Share Posted June 9, 2022 preshaded and ready for paint DSC_0003 by grimreaper110, auf Flickr 6 Link to comment Share on other sites More sharing options...
SouthViper Posted June 10, 2022 Share Posted June 10, 2022 On 09/06/2022 at 14:49, Reini78 said: preshaded and ready for paint DSC_0003 by grimreaper110, auf Flickr Going well, What BS colors do you will use for upper and under surfaces ? SouthViper from Brazil 1 Link to comment Share on other sites More sharing options...
exdraken Posted June 11, 2022 Share Posted June 11, 2022 Great work!! 1 Link to comment Share on other sites More sharing options...
Reini78 Posted June 11, 2022 Author Share Posted June 11, 2022 first camo colour applied with Tamiya XF-52 Flat Earth second one will be Tamiya XF-81 Dark Green (RAF) DSC_0002 by grimreaper110, auf Flickr 3 Link to comment Share on other sites More sharing options...
Reini78 Posted June 12, 2022 Author Share Posted June 12, 2022 fuel tanks painted too DSC_0010 by grimreaper110, auf Flickr canopy masked and inner colour already sprayed on DSC_0009 by grimreaper110, auf Flickr 3 Link to comment Share on other sites More sharing options...
Selwyn Posted June 12, 2022 Share Posted June 12, 2022 3 hours ago, Reini78 said: fuel tanks painted too DSC_0010 by grimreaper110, auf Flickr canopy masked and inner colour already sprayed on DSC_0009 by grimreaper110, auf Flickr Are you fitting any weaponry to this build? if so don't use the kit supplied stuff which is badly out of scale, I think the bombs supplied are closer to 1/32 than 1/48. Selwyn Link to comment Share on other sites More sharing options...
Reini78 Posted June 12, 2022 Author Share Posted June 12, 2022 2 hours ago, Selwyn said: Are you fitting any weaponry to this build? if so don't use the kit supplied stuff which is badly out of scale, I think the bombs supplied are closer to 1/32 than 1/48. Selwyn gonna add the Matra rocket pods Link to comment Share on other sites More sharing options...
mitchem Posted June 12, 2022 Share Posted June 12, 2022 Been watching from the sidelines with interest as I've had the 1/32 Hunter in the loft for more years than I care to remember. One day.... mike Link to comment Share on other sites More sharing options...
Reini78 Posted June 17, 2022 Author Share Posted June 17, 2022 camo done, maybe the one or other correction DSC_0003 by grimreaper110, auf Flickr DSC_0004 by grimreaper110, auf Flickr 11 Link to comment Share on other sites More sharing options...
heloman1 Posted June 17, 2022 Share Posted June 17, 2022 Neat looking camo... Colin 1 Link to comment Share on other sites More sharing options...
phildagreek Posted June 17, 2022 Share Posted June 17, 2022 Looks good! 1 Link to comment Share on other sites More sharing options...
