masterKamera Posted April 29, 2022 Share Posted April 29, 2022 WHat is the special way to pain the german turned aluminum engine cowlings so that they get the "changes color based on angle of viewing"? What little i can find is "paint one color then use micro paint brush to apply lines of a different color" Link to comment Share on other sites More sharing options...
JackG Posted April 29, 2022 Share Posted April 29, 2022 You can sort of get that effect by first painting a flat grey base, and then apply dots of metallic aluminum paint. Light source quality will impact the degree of how those applied dots 'shine'. This was my approach, but on a 1/72 French Hanriot HD.2 Seaplane: regards, Jack 5 Link to comment Share on other sites More sharing options...
masterKamera Posted April 29, 2022 Author Share Posted April 29, 2022 Thanks for that suggestion and photo, still will need to do some research on that. Im starting to realize why i didnt mind not painting when i was a tyke. Link to comment Share on other sites More sharing options...
Bozothenutter Posted April 29, 2022 Share Posted April 29, 2022 Use a punch and die set. Punch out some sandpaper. Stick discs to something suitable Create pattern on unpainted plastic Paint appropriately No idea if it works, just made it up, but that's what I'd try... Link to comment Share on other sites More sharing options...
Black Knight Posted April 29, 2022 Share Posted April 29, 2022 I put on a coat of aluminium then use a small brush to paint on commas of a bright silver 3 Link to comment Share on other sites More sharing options...
wmcgill Posted April 29, 2022 Share Posted April 29, 2022 14 hours ago, masterKamera said: WHat is the special way to pain the german turned aluminum engine cowlings so that they get the "changes color based on angle of viewing"? What little i can find is "paint one color then use micro paint brush to apply lines of a different color" The key to light/dark changes appears to be using one very shiny paint and one much less shiny paint. http://www.wingnutwings.com/ww/v98C7274C/www/hintsandtips/Jeannin Stahltaube cowling 'scales' hints & tips.jpg http://www.wingnutwings.com/ww/v98C7274C/www/hintsandtips/Fokker 'turned' cowl hints & tips.jpg 1 Link to comment Share on other sites More sharing options...
masterKamera Posted April 30, 2022 Author Share Posted April 30, 2022 Thanks for the help guys, It's great when the smarter kids are able to help out the not so smart ones. It does seem to make a model look more special then what the air fix directions for the eindecker say to do. Link to comment Share on other sites More sharing options...
Black Knight Posted April 30, 2022 Share Posted April 30, 2022 Revell supply decals to put on the cowling and forward metal area for their 1/48 Lindbergh Ryan NYP I've scanned them and changed them into sections to print out for use to try on 1/72 and 1/48 types Link to comment Share on other sites More sharing options...
JackG Posted April 30, 2022 Share Posted April 30, 2022 As described above, one can make the project more technical, such as using a decal method. I tried something similar with an Oeffag Albatros. I made my own decals on clear film. The turned aluminum or swirl areas are designed to be see through on the decal, surrounded by a base background of a mid-light grey. These are applied over the cowl that is prepainted a metallic aluminum. After the fact observations are, I could have gone with a more darker printed grey, since clear film decals are fairly translucent. Also, this method is finicky when dealing with curved surfaces that run in more than one direction. The other method I've yet to try is creating a spray mask, wherein holes are made in sections of tape, followed by spraying a metallic paint of choice. I do foresee the same problems as decals in tackling curved surfaces. regards, Jack 1 Link to comment Share on other sites More sharing options...
Bughunter Posted May 4, 2022 Share Posted May 4, 2022 On 4/29/2022 at 8:44 AM, masterKamera said: WHat is the special way to pain the german turned aluminum engine cowlings so that they get the "changes color based on angle of viewing"? One special way is to use real aluminium and polish it accordingly. Yes, the cowling is turned, on a lathe. Also a "normal" polishing is possible: Link to comment Share on other sites More sharing options...
