MickE Posted April 27, 2022 Share Posted April 27, 2022 Hi All How many links per side should I use for the AFV Club FV101 Scorpion Tank? Link to comment Share on other sites More sharing options...
andygif290368 Posted April 27, 2022 Share Posted April 27, 2022 the rubber band tracks in the kit are 255mm/10inches long. The friulmodel metal tracks give you 180 in the box, so that wouuld give you a max 90 per side. but at about 3.5 mm per link thats too long 255/3.5 would give you 73 links for the same length as the rubberband tracks 1 Link to comment Share on other sites More sharing options...
MickE Posted April 27, 2022 Author Share Posted April 27, 2022 Thanks. I have the AFV Club plastic track links. At the moment I have made the track lengths the same as the rubber band ones and will check for fit when I have finished painting the tank and have fitted the wheels. Link to comment Share on other sites More sharing options...
wasacop Posted April 28, 2022 Share Posted April 28, 2022 15 hours ago, MickE said: Thanks. I have the AFV Club plastic track links. At the moment I have made the track lengths the same as the rubber band ones and will check for fit when I have finished painting the tank and have fitted the wheels. I did that and found the run a bit on the tight side so I chucked another link on per run which seemed to work. Hope this helps. 1 Link to comment Share on other sites More sharing options...
pigsty Posted April 28, 2022 Share Posted April 28, 2022 20 hours ago, andygif290368 said: 255/3.5 would give you 73 links for the same length as the rubberband tracks Not sure I'd want to do that - the kit's tracks are so short they run almost dead straight from sprocket to idler. One extra link would make it sag a bit, but with no return rollers the idea is that the tracks should droop far enough to touch the middle three road wheels, so more would be needed. Unless some kind soul can enlighten us from experience (and allow for tracks stretching with time) what about counting the links on a decent photo of the real thing? 1 Link to comment Share on other sites More sharing options...
MickE Posted April 28, 2022 Author Share Posted April 28, 2022 Thanks all. I will try and get the sag you mention. Link to comment Share on other sites More sharing options...
viper-30 Posted April 29, 2022 Share Posted April 29, 2022 On a real thing the track links are between 82/85 dependent on wear . Link to comment Share on other sites More sharing options...
