Roden 1/144 Boeing RC-135V/W Rivet Joint
Looking forward to the 1/72 scale Rivet Joint from the USAF/RAF.
  • Confused 1
  • Sad 1
Is there such a kit projected?
Given the varied quality of Roden decals , something will turn up in the aftermarket range no doubt, including the RAF version. I presume that the aircraft are identical between the services and if anyone knows otherwise regards all the lumps and bumps and sticky out bits, I would suggest you get out more! Looking forward to the plastic.
Keith
Keith
Caracal Decals has a set in 1/72, perhaps they can be persuaded to do it in 1/144th with a few extras chucked in.
8 hours ago, VMA131Marine said:
Weird! They work for me.
Just tried them again and they work, It May have been something on my end to be 100% honest. My internet has been acting funky for two days now and haven't been able to figure it out ? So it may just have been my AT&T blocking because something wasn't quite right.
Edited by Corsairfoxfouruncle
On 27/04/2022 at 18:27, Teeradej said:
Right scale right subject. Very welcome!
agreed right scale, right subject.... but wrong decals! RAF ones please!
10 hours ago, CaracalModels said:
There will be a Caracal sheet with a RAF option added.
You have no choice other than wait for aftermarket decals or next boxing at this time. Roden have a good record on covering variants of a subject. Have seen many times when X kit released then why no Y scale, no Z variants etc…  I am happy no matter whatever marking included.
Edit: A suggestion email to Roden is not bad idea if you really want to use decals made by them. I had a good luck asking for C-5 kit.
Edited by Teeradej
  • 1 month later...
Hmmm.  The wing-body fairing looks a bit funky.  There shouldn't be any kind of fairing ahead of the leading edge, and the trailing edge fairing should be real sharp--so it blends with the trailing edge of the wing.  As depicted, the trailing edge looks more like a -300 series 707 aircraft.  AMT-ERTL got this exactly right on their 1/72 scale model back in the day, and I would compare the fuselage halves with those of the much bigger kit.
On 6/24/2022 at 9:07 AM, TheyJammedKenny! said:
No.  I share your views on this.  The "hog nose" is much too small.
Too short?
I somehiw miss the kink on the lower fuselage... might this one be for another  fuselage? / model?
