British ATMP w/Ammo pallet
I'm taking a short break from Ship-modelling to build this.  There's still a Centurion AVRE that sit's forlorn; more of that soon.
2022 04 11_3601_edited-1 (2)
I bought this on impulse after seeing Pete Smith of Stonhenge Modellers display his in British Army green at IPMS Avon last year.
Gecko are releasing some interesting kits, certainly for British vehicles and I've followed @APA's Beford builds with interest.
The Supacat ATMP was primarily designed with air mobility in mind and served with airborne forces as a load carrier, with it's introduction coming after lessons learned in the Falklands conflict.  It served up to 2010 and then was withdrawn without a really obvious successor.  In truth the Quad bike and trailer have taken over it's role though how successfully is not entirely clear.
Anyway on with the show - the instructions are full colour Bronco-type
Scan0113 (2)
There are a couple of correction sheets and a spare sprue that covers parts for other variants that Gecko have released, 4 to date including a WMIK
Scan0117
Scan0114 (2)
Scan0118 Scan0116
2021 08 31_3206
A driver figure is included and I'll wait to build it to judge how good it is.
I might use this Accurate Armour figure instead
2021 08 31_3204
There are some L85 rifles, handguns and body pouches
Scan0115
And here are some pics of the original
supacat_atmp
maxresdefault
img_78-2_9
The web is certainly not awash with pics of the machine in action
These are 2 useful references for history and appearance:
https://www.mafva.org/walk-around-supacat-atmp/?v=79cba1185463
https://www.thinkdefence.co.uk/supacat-terrain-mobility-platform-atmp/
The central tub is well moulded
2021 08 31_3202
Construction begins with the transmission
2021 08 31_3203
2021 08 31_3201
And the deck is cleaned and attached
2021 08 31_3205
2022 04 11_3599
The Diamond pattern plate is really effective
2022 04 11_3600
As is the etch for the engine compartment
2022 04 11_3594
The pallet containing 105mm shell boxes builds cleanly and the wood grain on the wooden pa;et is nicely done
2022 04 11_3596
2022 04 11_3597
The wheel build up in 2 halves - they do need some filing to reduce the width so that the tyres "fit"
2022 04 11_3598
The hub rims are added separately
2022 04 11_3593
This is meant to be a quick build so more soon (hopefully!)
Thanks for looking
Rob
  • Like 15
Hi Rob
Interesting little subject. I've seen their range of these vehicles and if I ever get into modern armour I'll definitely consider one of these. Gecko, along with a few other manufacturers are definitely expanding the range of UK vehicles which is a breath of fresh air. We might even stop moaning about it one day 😉.
I'll keep an eye on this build. It looks a bit simpler than the MW range and hopefully everything fits ok!!
Crack on with your Banana Buggy 😁
banana
or should that be a Space 1999 Moonbuggy 😁
99
Andrew
  • Haha 3
Pete's displays (and his mate Brian) have long been the cause of impulse buys for me at such shows! I saw him again at Yeovil on 10th April (long before I tested positive I hasten to add!). I think I saw his rendition of this one there. Very inspirational displays.
This one is a real neat little job Rob, and I particularly like the look of the picture of the one towing what I believe is a Lightweight M777 155mm howitzer. I'm a bit partial to artillery models!
Will follow along with interest.
Terry
Interesting subject I know what you mean about just a quick build because ships can be so involved
looking forward to more. 👍
stay Safe
beefy
  • 3 weeks later...
On 4/16/2022 at 9:47 AM, APA said:
Hi Rob
banana
99
Andrew
La, la la....la,la,la....Hadn't thought of that before:lol:  That's certainly reduced the gravitas :winkgrin:
The light units are fiddly....
2021 08 31_3207
I had second thoughts and might use the seated figure, though there is a large unsightly sink mark on the right leg
2022 05 09_3690
That was filled with putty
The Diamond tread plates sit very accurately
2022 05 09_3689
The steering gear is well represented though il lbe completely hidden
2022 05 09_3688
The roll cage bars are cleaned up
2022 05 09_3680
And sequentially assembled
2022 05 09_3681
2022 05 09_3682
2022 05 09_3683
2022 05 09_3684
Fitting the seat belt wihc comes as a single piece of PE was not easy and super glue got spilled in abundance :rant:
I tried Super Glue remover - for the first time - apply wait a few minutes and thenremove with a wettened brush or cocktail stick - the "treated" super Glue goes sticky and can be "rolled" off.  hey Presto - it works :clap2:
2022 05 09_3673
2022 05 09_3685
More soon - Thanks for looking
Rob
  • Like 11
I keep looking at these kits and thinking of a diorama with me and a Supacat instructor stacked into a bush on a bend on their test track.  I was driving...........  until I wasn't 😁
  • Haha 3
It's got to be done!!!
On 5/9/2022 at 10:12 PM, Bertie Psmith said:
It's so tiny. I have the WMIK one and have been misled by the box size!
Looks very good so far though.
Bertie - you aren't joking, the box is blooming huge!
Tools are added
2022 05 09_3674
I have quite a few of these bargain cheap MDF bases.  The finish is very rough but comes up beatutifully with some Liquitex Gloss medium and varnish
2022 04 18_3604
Which is then sanded gently and sprayed up.
And onto primer, using my "Go-to" - Mig Ammo One shot
2022 05 09_3676
2022 05 09_3675
2022 05 09_3677
and after drying for 24 hours - the top coat comprising Mig Ammo 0030 to Mig ammo IDF Sand Grey 73, 2 : 1
2022 05 09_3671
2022 05 09_3670
Building up slowly in very light coats.  I'm aware of the debate about UK Light Stone and the exact colour.  To my mind these Supacats looked more yellow though it may just be the light intensity.  For The Cent AVRE I'll be using Soveereign Colourcoats but I wanted some variety, so It's Mig Ammo here
2022 05 12_3701
2022 05 12_3700
2022 05 12_3706
Thanks to @Dads203 for his confirmation that Brit Ammo boxes are still a chocolate colour
2022 05 12_3705
And the figure is prepared with some Scalpel "undercutting" and "Scraping".  The arms do seem to fit the control bars
2022 05 12_3702
2022 05 12_3703
and finally, I couldn't resist staining the pallet despite fact it won't realy be seen
2022 05 12_3694
Thanks for looking
Rob
  • Like 14
Nice work Rob. It looks pretty PE heavy but it seems to be appropriate. Adds lots of scale detail.
Andrew
On 5/13/2022 at 7:42 AM, Geo1966 said:
Looking great Rob.
Where did you get the MDF bases from please?
George
Hi George - I've picked them up from bargain nins at shows.  Just bases now defunct also used to sell them.
Andrew
Andrew the PE was very well behaved, and a kit this size does need it.
After finishing a ship over on maritime I've been adding paint details to this today
2022 05 23_3794
Pin wash followed
2022 05 23_3796
2022 05 23_3795
2022 05 23_3793
Current plan is to fit the seated driver.  Camo wil lbe Desert DPM as befits the time period these vehicles were used.  Painting such a fine pattern at this scale is difficult IMO and I followed @Dads203 figure build on his FV 423 build with interest.  I've used camo decaals before such as this ACU figure that went withh an NBC Stryker.
2022 05 23_3799
So the plan is to use FFSMC DPM decals
2022 05 23_3798
They recommend spraying a gloss cream base though on previous occasions I've laid decals directly onto the figure plastic.
2022 05 23_3797
More soon
thanks for looking
Rob
  • Like 12
I have this kit too, not quite ready to get started on it, but I'm picking up some useful tips from yourself.
I wonder though if you provide a link to suppliers of the DPM decals you mention?
On 5/26/2022 at 8:12 PM, Courageous said:
Decals for 1/35 figures, seen it all now!
Stuart
Thanks Stuart
I presume this is said in an "Uncle Bryn"voice  :lol:
  • Haha 2
So to decalling time....
2022 05 30_3833
2022 05 30_3832
2022 05 30_3827
2022 05 30_3830
2022 05 30_3829
2022 05 30_3831
2022 05 30_3828
2022 05 31_3838
Verdict - The base colour ends up too dark.  I sprayed Cremeweiss for the trousers and then sprayed white for the jacket.  Decals work but in this instance I think the colour is too dark.  It's far easier to apply the decals to a standing figure.  In fact I stripped the decals off the Accurate Armour standing figure.  I think I can do better hand painting.
2022 05 30_3834
2022 05 31_3837
2022 05 31_3836
2022 05 31_3835
In the last pic you'll ee that the wheels have been attached after being coated with a slurry of wter/dust pigment which is then rubbed off.
Thanks for looking
Rob
  • Like 11
Thanks Kev
The final act was to attach ratchet straps to the load using Acuurtae Armour's set
2022 06 04_3843
Fiddly but effective
2022 06 04_3844
It was a job to "glue" the palstic tape supplied that seemed resistant to CA glue.
Some ration boxes came from FC Model trends that are doing some interesting stuff.
And so RFI now available:
I really enjoyed this model and Gecko are doing some interesting releases - not the least of which is a "Landing Craft Assault" in 1/35 just announced yesterday.  I also took possession of the new Scimitar Mk2 with slat armour, last week and very nice it looks too.  however that will have to wait for a few more ships yet.
Thanks for looking
Rob
  • Like 10
