John Masters Posted April 18, 2022 Author Share Posted April 18, 2022 7 hours ago, Wings unlevel said: the next MiG-21 GB Yes please... 1 1 Link to comment Share on other sites More sharing options...
modelling minion Posted April 18, 2022 Share Posted April 18, 2022 Looking good John, paint on soon! 🇺🇦 Link to comment Share on other sites More sharing options...
John Masters Posted April 19, 2022 Author Share Posted April 19, 2022 The painting has begun. --John 4 Link to comment Share on other sites More sharing options...
modelling minion Posted April 19, 2022 Share Posted April 19, 2022 Good bit of pre-shading there John. 🇺🇦 Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted April 19, 2022 Share Posted April 19, 2022 Nice work I was never able to master the pre-shading lines technique, my hands shake too much. I tend to go with color modulation after the main painting. Link to comment Share on other sites More sharing options...
John Masters Posted April 28, 2022 Author Share Posted April 28, 2022 On 4/19/2022 at 8:29 PM, Corsairfoxfouruncle said: Nice work I was never able to master the pre-shading lines technique, my hands shake too much. I tend to go with color modulation after the main painting. Thanks Dennis. I'm not impressed with mine either. I've seen things here...things you will not believe! 😄 But thank you. I am working on improving my technique. I used Light Ghost Grey for the underside. Et voila! I'll let this dry overnight and mask it off tomorrow. Crossed fingers for the green, my airbrush nemesis...I guess I'll go very thinned out green coats at a very low pressure. --John 6 Link to comment Share on other sites More sharing options...
modelling minion Posted April 28, 2022 Share Posted April 28, 2022 Nice work John, the undersides look very good indeed. 🇺🇦 Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted April 28, 2022 Share Posted April 28, 2022 Very nice work with the grey, I used the sane on my build. Link to comment Share on other sites More sharing options...
John Masters Posted April 29, 2022 Author Share Posted April 29, 2022 10 hours ago, modelling minion said: Nice work John, the undersides look very good indeed. 9 hours ago, Corsairfoxfouruncle said: Very nice work with the grey, I used the sane on my build. Thank you both! I will start the topside tonight. Crossed fingers for good luck with the green. 2 Link to comment Share on other sites More sharing options...
John Masters Posted April 30, 2022 Author Share Posted April 30, 2022 Dielectric panels painted and masked. The green went on first. Verrrry low psi (5) and thin paint. The blue will define the camouflage shape. Blue tomorrow... --John 3 Link to comment Share on other sites More sharing options...
modelling minion Posted April 30, 2022 Share Posted April 30, 2022 Looking forward to the finished camo John, she's looking great so far. 🇺🇦 Link to comment Share on other sites More sharing options...
John Masters Posted May 1, 2022 Author Share Posted May 1, 2022 8 hours ago, modelling minion said: Looking forward to the finished camo John Me too! Thank you Craig. 1 Link to comment Share on other sites More sharing options...
John Masters Posted May 1, 2022 Author Share Posted May 1, 2022 The first thing I did was take a pencil and lightly draw the lines for the blue... And then I painted the blue. I used very low psi (4-5) and went in really close with barely a tug on the trigger. I had to clean the needle frequently. When the blue was all on I went around with the green again (also very low psi, and thinned) and sharpened up some edges, filled some small gaps here and there...then again with the blue for some quick touch-ups. All airbrush. I'm quite pleased with the result. It seems bright right now, but once I give it a going over with some Flory-Wash, it'll tone down bit. 7 Link to comment Share on other sites More sharing options...
drake122 Posted May 1, 2022 Share Posted May 1, 2022 Looking great. Which Vallejo colors did you use for the camo? I can see 71.121 for the underside but not the rest.🤣 Link to comment Share on other sites More sharing options...
Vultures1 Posted May 1, 2022 Share Posted May 1, 2022 25 minutes ago, drake122 said: Looking great. Which Vallejo colors did you use for the camo? I can see 71.121 for the underside but not the rest.🤣 Yes, do please tell which Vallejo colours you used! Lovely job on the camo Link to comment Share on other sites More sharing options...
modelling minion Posted May 1, 2022 Share Posted May 1, 2022 1 hour ago, John Masters said: I'm quite pleased with the result. As well you should be John. That really is some excellent airbrushing mate, well done.👍 🇺🇦 Link to comment Share on other sites More sharing options...
drake122 Posted May 1, 2022 Share Posted May 1, 2022 25 minutes ago, Vultures1 said: Yes, do please tell which Vallejo colours you used! Lovely job on the camo I used some Horatio Caine style CSI super zoom and here are the colors based on the jars pictured: Vallejo 71.121 grey Vallejo 71.318 blue Vallejo 71.303 green Unless they were some mixtures involved... 1 1 Link to comment Share on other sites More sharing options...
PattheCat Posted May 1, 2022 Share Posted May 1, 2022 Very nice work with the airbrush. 5 psi? I never go lower than 10 - 12 (but I always use masking tape, not having the touch for freehand camo), maybe I should try to lower pressure. What are your thinning ratio's? Cheers. Pat Link to comment Share on other sites More sharing options...
John Masters Posted May 1, 2022 Author Share Posted May 1, 2022 2 hours ago, PattheCat said: Very nice work with the airbrush. 5 psi? I never go lower than 10 - 12 (but I always use masking tape, not having the touch for freehand camo), maybe I should try to lower pressure. What are your thinning ratio's? Thank you Pat...I didn't thin the blue, and ran it at about 5psi, kept the valve closed down almost to the end and also airbrushed about 5mm from the surface of the aircraft. It is tricky and I am not so facile yet, but I am getting better. The green (all greens, btw) I am thinking about 50/50 with Ajax. Like skim milk and at 4-5psi too, same technique. Even then I have to stop periodically and clean off the needle. Green (any green) seems to dry and clog very easily. So that's what I did there. I have done this with mottling camo on Bf-109 builds and have been happy. Learned it here on Britmodeller. It's all your fault!😆 3 hours ago, Vultures1 said: Yes, do please tell which Vallejo colours you used! Lovely job on the camo Thank you! See below... 2 hours ago, drake122 said: Vallejo 71.121 grey Vallejo 71.318 blue Vallejo 71.303 green Thank you...you are correct! No mixtures. Straight from the bottle, but the green is thinned (see above). So I started in on the decals...stencils first. 2 1/2 hours of stencils. Egads. I always start off thinking, "Oh well...I'll just do the big ones, the ones everyone will see..." Then I begin and I end up using them all...a type of masochism, I suppose. But they do look good and will look even better when it is all done. What is it about the Soviet aircraft? I mean really...so many stencils! Don't walk, don't touch, don't open, watch out...Jeez! Probably a stencil somewhere that says, 'Sit here, shut up and fly the plane!" Beneath... Up top... And don't you know these stencils are in Cyrillic...you can see the letters. Nice decals. The physics worked. I imagine the Cubans would have overpainted them in Spanish. Let's pretend, shall we? 😉 --John 4 1 Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted May 1, 2022 Share Posted May 1, 2022 5 hours ago, John Masters said: I'm quite pleased with the result. And you should be thats a good looking bird. 1 Link to comment Share on other sites More sharing options...
modelling minion Posted May 1, 2022 Share Posted May 1, 2022 She looks absolutely fantastic John. You really have nailed the airbrushing mate, its very neat, and I think the colours look perfect. There can't be many more decals left to do now. 🇺🇦 Link to comment Share on other sites More sharing options...
John Masters Posted May 1, 2022 Author Share Posted May 1, 2022 17 minutes ago, modelling minion said: There can't be many more decals left to do now. Thanks Craig. Only the Cuban markings, then some varnish, Florywash…landing gear. Weather tomorrow calls for rain. Modelling weather. 51 minutes ago, Corsairfoxfouruncle said: And you should be thats a good looking bird. Thank you Dennis. I’m getting better! 2 Link to comment Share on other sites More sharing options...
John Masters Posted May 2, 2022 Author Share Posted May 2, 2022 The national markings, etc...are on. No issues with these KoPro decals except I did tear the port fuselage roundel. I'll wait until they are fully dry and touch it up with some dark blue. So later...satin varnish. I'll attach the landing gear and weapons at the very end. --John 5 Link to comment Share on other sites More sharing options...
modelling minion Posted May 2, 2022 Share Posted May 2, 2022 Very nice John, what a lovely and colourful build this is. Don't worry about the torn roundel as I am sure you will be able to touch that up very neatly. 🇺🇦 Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted May 2, 2022 Share Posted May 2, 2022 Everything's looking good John, I agree you should be able to fix the roundel with some paint Link to comment Share on other sites More sharing options...
