pockets Posted April 8, 2022 Share Posted April 8, 2022 Any tips on handbrushing camo at 1/72 , ive already painted on the dark green so am painting the pattern with ocean gray over the green base coat , would people use diy masks or free hand ? Link to comment Share on other sites More sharing options...
colin Posted April 8, 2022 Share Posted April 8, 2022 May have been easier to have done it the the other way around, grey then green. Start with the lighter colour then darker in that order. If you have a steady hand free hand would be quicker 1 Link to comment Share on other sites More sharing options...
Troy Smith Posted April 8, 2022 Share Posted April 8, 2022 31 minutes ago, pockets said: Any tips on handbrushing camo at 1/72 , ive already painted on the dark green so am painting the pattern with ocean gray over the green base coat , would people use diy masks or free hand ? Freehand. Masking with brushpainting is tricky, and only occasionally needed, eg straight lines and canopies, as you tend to get ridges of paint. You may find it easier to pencil in the demarcation lines first as well, a retracting pencil is good for this. Usually you do the lighter colour first though. the pattern was specified, though there are noted factory variations thee is an official factory diagram in this. https://boxartden.com/reference/gallery/index.php/Camouflage-Markings/Supermarine-Spitfire 1 Link to comment Share on other sites More sharing options...
pockets Posted April 8, 2022 Author Share Posted April 8, 2022 ok thanks , thought that after I applied the green , oh well . should I future it before applying the pattern overpaint incase of mistakes ? the pencil sounds like a good call , the kit comes with reference images for different patterns . Link to comment Share on other sites More sharing options...
Troy Smith Posted April 8, 2022 Share Posted April 8, 2022 1 minute ago, pockets said: ok thanks , thought that after I applied the green , oh well . should I future it before applying the pattern overpaint incase of mistakes ? It depends on how comfortable you are with brushing, and what kind of paint you are using. if it all new, try on scrap first, old kit, toy, even a plastic container or bottle, so you get used to curved surfaces. pencil in the lines, and the practice working up to them and filling in. You can just touch up the green or wipe the excess off with a cotton bud, and the touch up later. outline each side and then fill in, if using acylic look to keep a wet edge, and two/three thin coats are better than a thick one, the edges will likely not need the same amount of coats, as they dry quicker. Which is why I say practice if you are unsure, so you get a feel for working the paint and how to get it to flow they way you want, as I say getting the right consistency will really help this as well. I use a small flat brush for acylics,aout 6m wide, works a lot better than a normal brush thinking about you might want to use tape for fuselage upper lower demarcation, as that is straight One chap who is really good at brushpainting is @PlaStix, have a look at some of his work. 1 minute ago, pockets said: the pencil sounds like a good call , the kit comes with reference images for different patterns . Just though you might find the whole booklet useful. 1 Link to comment Share on other sites More sharing options...
pockets Posted April 8, 2022 Author Share Posted April 8, 2022 (edited) Yes , thanks for the tips . Iv'e already done some practice on sprue spares for doing washes over pledge future, I'm using tamiyas flat acrylics for paint and thinning with their thinners averaging four coat to get desired finish , have done the underside already and masked the wings and upper/ lower demarcation , Iv'e made life difficult for myself by applying the darker colour first, but hopefully the ocean grey will cover ok with a few coats , its quite tricky to handbrush the camo this scale but will take my time , wonder if its worth adding some flat white to the grey as it'll darken slightly being applied over the green , what do you think? Thanks for the reference guide ,will have a good look tomoz . Edited April 8, 2022 by pockets Link to comment Share on other sites More sharing options...
Troy Smith Posted April 9, 2022 Share Posted April 9, 2022 22 hours ago, pockets said: I'm using tamiyas flat acrylics for paint and thinning with their thinners averaging four coat to get desired finish Check that won't cause the Dark Green to lift. Note, you can thin Tamiya acrylics happily with water (i use de-ionised, as I have some) and a tiny amount about 5% flow improver ( i get a 1 ml syringe, suck up 0.95 ml water, and 0.05ml flow improver, and shake) add some paint to a palette, and water/FI mix a drop at a time until the paint flows smoothly. Tamiya thinners is a bit 'hotter' as in contains alcohol solvents. 22 hours ago, pockets said: wonder if its worth adding some flat white to the grey as it'll darken slightly being applied over the green , what do you think? I don't think it will once you have a good paint coverage. One point, the yellow leading edges. Yellow is a sod to brush. You will need an undercoat, unless you have decals? (or a scheme not needing the yellow leading edges) HTH 1 Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted April 10, 2022 Share Posted April 10, 2022 (edited) On 4/8/2022 at 6:08 PM, Troy Smith said: I use a small flat brush for acylics,aout 6m wide, works a lot better than a normal brush Troy if 6 Meter’s is small to you than Id hate to see what a big brush is ? Edited April 10, 2022 by Corsairfoxfouruncle 1 2 Link to comment Share on other sites More sharing options...
pockets Posted April 10, 2022 Author Share Posted April 10, 2022 I've trialed a flat brush , do u use It on edge as the squarness flat on seems impossible to keep within the curves even twisting as you progress. Link to comment Share on other sites More sharing options...
Troy Smith Posted April 10, 2022 Share Posted April 10, 2022 24 minutes ago, pockets said: I've trialed a flat brush , do u use It on edge as the squarness flat on seems impossible to keep within the curves even twisting as you progress. Good question. I keep it flat and use the side, twisting the brush as needed I think, it's not something I think about, just do automatically... it's what ever is comfortable and works for you, and gets a result you are happy with.... I did this with a flat brush. This is after being kleered, oil washed and flat coated BTW. 6 hours ago, Corsairfoxfouruncle said: Troy if 6 Meter’s is small to you than Id hate to see what a big brush is ? indeed.... amazing the difference a missing m can make..... It's actually 7mm at the ferrule. 2 Link to comment Share on other sites More sharing options...
pockets Posted April 16, 2022 Author Share Posted April 16, 2022 Here's a few snaps of the progress , I masked in the end , then feathered any ridges on edges of camo pattern with some elastic sanding film . Came out ok , Futured at the moment for decals and panel line wash and weathering. 2 Link to comment Share on other sites More sharing options...
