Casey Posted April 5, 2022 Share Posted April 5, 2022 (edited) Purpose: Re-create Humbrol range of paints using commercially available paints from a given vendor. Source of colors Reasoning: Needed an alternative for discontinued / health risk products. And I like math. Methodology: Custom implementation of two-flux Kubelka-Munk algorithm with measured model of Golden Fluid Acrylics. Paint mixing solves the minimum of perceptual difference between target paint and the mixture, prioritizing for small integer ratios of constituent paints. Target is a measured spectral data (see other posts). DE00 is https://en.wikipedia.org/wiki/Color_difference#CIEDE2000 Some colors (like fluorescent paints and Bright Green (No 37)) are not represented very well. If you see high DE00, it is a poor fit. Ratios are given in mass not volume, but it should not be super big deal - the paints have similar density. To use in airbrush, use Golden Fluid Airbrush Medium, starting with 1:1 ratio. I find it works well with brush painting too and feeling similar to Vallejo Air in an airbrush. You can either use varnish or gloss/matt medium to bring it to a desired gloss/matt level. Data hidden in spoiler due to the volume. Using full range of Golden Fluid Acrylics - calculations based on MASS. Information about metallics Most metallics (minus those metalcote) are made with mica particles, which are sold in Golden Fluid range as Irididescent Pearl (fine) or as colored versions. It is fully possible to mix most of the metallics replacing part of white with this product. Alternatively, you may want to explore the full range of true metallics: Coarse iridescent stainless steel is made of iron, chromium and nickel particles for example and it is produces coarse metal layer. Micaeous Iron Oxide is made from hematite ore (iron ore) They also offer very good bronze/gold/silver metallics. Spoiler DB0001 - No 1 - Primer - Matt Suggested using total of 48 parts (DE00: 0.47) Expected: #8A8D8D, Simulated: #898B8B Titan Green Pale: 43 Carbon Black: 3 Pyrrole Red Light: 2 DB0002 - No 2 - Emerald Green - Gloss Suggested using total of 43 parts (DE00: 0.49) Expected: #327646, Simulated: #327545 Permanent Green Light: 18 Raw Sienna: 16 Hansa Yellow Opaque: 7 Phthalo Blue (Green Shade): 2 DB0003 - No 3 - Brunswick Green - Gloss Suggested using total of 10 parts (DE00: 0.46) Expected: #34553F, Simulated: #355541 Payne's Gray: 4 Cadmium Yellow Medium Hue: 3 Phthalo Green (Yellow Shade): 3 AA0059 - No 5 - Dark Admiral Grey - Gloss Suggested using total of 30 parts (DE00: 0.36) Expected: #6B7477, Simulated: #6A7476 Titan Green Pale: 11 Bone Black: 18 Primary Cyan: 1 AA0076 - No 7 - Light Buff - Gloss Suggested using total of 31 parts (DE00: 0.33) Expected: #E2AE67, Simulated: #E3AF65 Titanium White: 12 Benzimidazolone Yellow Medium: 2 Yellow Ochre: 16 Diarylide Yellow: 1 DB0009 - No 9 - Tan - Gloss Suggested using total of 33 parts (DE00: 0.42) Expected: #9A654D, Simulated: #9A654F Raw Sienna: 27 Primary Magenta: 3 Titan Green Pale: 2 Sap Green Hue: 1 DB0010 - No 10 - Service Brown - Gloss Suggested using total of 15 parts (DE00: 0.40) Expected: #514742, Simulated: #514742 Bone Black: 6 Raw Sienna: 6 Transparent Yellow Iron Oxide: 2 Cadmium Red Medium Hue: 1 STARTER11 - No 11 - Silver - Metallic Suggested using total of 45 parts (DE00: 0.47) Expected: #C9C9C9, Simulated: #C9C7C7 Titanium White: 41 Bone Black: 3 Burnt Umber Light: 1 DB0011 - No 11 - Silver - Metallic Suggested using total of 31 parts (DE00: 0.38) Expected: #ACAEAF, Simulated: #ACADAE Titanium White: 24 Bone Black: 6 Yellow Ochre: 1 DB0012 - No 12 - Copper - Metallic Suggested using total of 33 parts (DE00: 0.41) Expected: #A5715D, Simulated: #A6725D Burnt Sienna: 14 Cadmium Yellow Medium Hue: 2 Titanium White: 10 Pyrrole Red Light: 5 Sap Green Hue: 2 AA0134 - No 12 - Copper - Metallic Suggested using total of 25 parts (DE00: 0.39) Expected: #775A52, Simulated: #765A52 Transparent Yellow Iron Oxide: 18 Teal: 3 Cadmium Red Medium Hue: 4 DB0014 - No 14 - French Blue - Gloss Suggested using total of 41 parts (DE00: 0.49) Expected: #395D99, Simulated: #365D9C Ultramarine Blue: 32 Titan Buff: 8 Phthalo Green (Yellow Shade): 1 DB0015 - No 15 - Midnight Blue - Gloss Suggested using total of 15 parts (DE00: 0.29) Expected: #34516C, Simulated: #34516C Prussian Blue Hue: 11 Raw Sienna: 1 Teal: 3 STARTER15 - No 15 - Midnight Blue - Gloss Suggested using total of 12 parts (DE00: 0.49) Expected: #374150, Simulated: #364051 Primary Cyan: 6 Payne's Gray: 5 Phthalo Green (Yellow Shade): 1 DB0016 - No 16 - Gold - Metallic Suggested using total of 25 parts (DE00: 0.27) Expected: #B09673, Simulated: #AF9672 Burnt Umber Light: 6 Titan Buff: 17 Sap Green Hue: 1 Diarylide Yellow: 1 DB0018 - No 18 - Orange - Gloss Suggested using total of 15 parts (DE00: 0.43) Expected: #ED6C38, Simulated: #ED6C3B Pyrrole Orange: 3 Pyrrole Red Light: 3 Primary Yellow: 1 Hansa Yellow Opaque: 7 Titanium White: 1 DB0019 - No 19 - Bright Red - Gloss Suggested using total of 8 parts (DE00: 0.48) Expected: #A53639, Simulated: #A2383A Cadmium Red Medium Hue: 5 Quinacridone Crimson: 1 Transparent Yellow Iron Oxide: 2 DB0020 - No 20 - Crimson - Gloss Suggested using total of 21 parts (DE00: 0.48) Expected: #9A413F, Simulated: #994140 Burnt Sienna: 10 Titanium White: 1 Cadmium Red Medium Hue: 10 DB0021 - No 21 - Black - Gloss Suggested using total of 1 parts (DE00: 0.47) Expected: #3A3B3D, Simulated: #3B3C3D Carbon Black: 1 DB0022 - No 22 - White - Gloss Suggested using total of 1 parts (DE00: 0.51) Expected: #F9FAF7, Simulated: #FAFAF6 Titanium White: 1 DB0023 - No 23 - Duck Egg Blue - Matt Suggested using total of 39 parts (DE00: 0.40) Expected: #B7C1B1, Simulated: #B5BFB0 Titan Green Pale: 5 Titanium White: 27 Prussian Blue Hue: 1 Yellow Ochre: 6 DB0024 - No 24 - Trainer Yellow - Matt Suggested using total of 15 parts (DE00: 0.46) Expected: #DBA73C, Simulated: #D8A53C Titan Buff: 3 Benzimidazolone Yellow Medium: 5 Transparent Yellow Iron Oxide: 7 DB0025 - No 25 - Blue - Matt Suggested using total of 18 parts (DE00: 0.41) Expected: #3C4E77, Simulated: #3D4E76 Ultramarine Violet: 9 Prussian Blue Hue: 7 Titanium White: 2 DB0026 - No 26 - Khaki - Matt Suggested using total of 28 parts (DE00: 0.44) Expected: #746044, Simulated: #725F44 Transparent Yellow Iron Oxide: 26 Chromium Oxide Green: 1 Benzimidazolone Yellow Light: 1 DB0027 - No 27 - Sea Grey - Matt Suggested using total of 44 parts (DE00: 0.50) Expected: #646C71, Simulated: #656B71 Carbon Black: 9 Titan Green Pale: 35 AA1496 - No 28 - Camouflage Grey - Matt Suggested using total of 10 parts (DE00: 0.48) Expected: #BFBAAE, Simulated: #C0BBB0 Titanium White: 8 Bone Black: 1 Yellow Ochre: 1 DB0029 - No 29 - Dark Earth - Matt Suggested using total of 33 parts (DE00: 0.36) Expected: #776450, Simulated: #776550 Raw Sienna: 18 Bone Black: 9 Titanium White: 3 Pyrrole Orange: 2 Diarylide Yellow: 1 DB0030 - No 30 - Dark Green - Matt Suggested using total of 10 parts (DE00: 0.39) Expected: #4F5C53, Simulated: #4F5B53 Raw Umber: 7 Teal: 2 Phthalo Green (Yellow Shade): 1 AA0343 - No 31 - Slate Grey - Matt Suggested using total of 3 parts (DE00: 0.29) Expected: #646D63, Simulated: #636D64 Teal: 1 Burnt Umber Light: 2 DB0032 - No 32 - Dark Grey - Matt Suggested using total of 10 parts (DE00: 0.39) Expected: #4B4E51, Simulated: #4B4E51 Bone Black: 9 Titan Green Pale: 1 DB0033 - No 33 - Black - Matt Suggested using total of 1 parts (DE00: 0.32) Expected: #38393A, Simulated: #383939 Bone Black: 1 AA0360 - No 33 - Black - Matt Suggested using total of 1 parts (DE00: 0.40) Expected: #3C3C3E, Simulated: #3B3C3D Carbon Black: 1 STARTER33 - No 33 - Black - Matt Suggested using total of 23 parts (DE00: 0.44) Expected: #3E3F40, Simulated: #3E4041 Bone Black: 22 Titan Buff: 1 DB0034 - No 34 - White - Matt Suggested using total of 1 parts (DE00: 0.54) Expected: #F7F8F5, Simulated: #FAFAF6 Titanium White: 1 DB0036 - No 36 - Pastel Green - Matt Suggested using total of 10 parts (DE00: 0.49) Expected: #A3B045, Simulated: #A0B041 Titan Buff: 2 Primary Yellow: 5 Chromium Oxide Green: 1 Hansa Yellow Opaque: 2 DB0037 - No 37 - Bright Green - Matt Suggested using total of 3 parts (DE00: 8.21) Expected: #00A83C, Simulated: #008A49 - (approximate color) Permanent Green Light: 2 Primary Yellow: 1 AA0037 - No 37 - Bright Green - Matt Suggested using total of 29 parts (DE00: 4.74) Expected: #00B539, Simulated: #2EA63B - (approximate color) Benzimidazolone Yellow Light: 26 Phthalo Green (Yellow Shade): 3 DB0038 - No 38 - Lime - Gloss Suggested using total of 21 parts (DE00: 0.20) Expected: #87A347, Simulated: #86A348 Hansa Yellow Opaque: 6 Primary Yellow: 9 Titan Buff: 5 Prussian Blue Hue: 1 AB0040 - No 40 - Pale Grey - Matt Suggested using total of 10 parts (DE00: 0.39) Expected: #9CA19B, Simulated: #9BA099 Bone Black: 2 Titan Green Pale: 7 Ultramarine Violet: 1 DB0041 - No 41 - Ivory - Gloss Suggested using total of 11 parts (DE00: 0.42) Expected: #E5DBC3, Simulated: #E6DCC3 Titanium White: 9 Titan Green Pale: 1 Raw Sienna: 1 DB0047 - No 42 - Pastel Violet - Matt Suggested using total of 26 parts (DE00: 0.10) Expected: #7D7599, Simulated: #7D7599 Titanium White: 11 Prussian Blue Hue: 2 Quinacridone Crimson: 4 Ultramarine Violet: 9 DB0044 - No 44 - Pastel Blue - Matt Suggested using total of 38 parts (DE00: 0.39) Expected: #92B0CD, Simulated: #90B0CB Titanium White: 32 Payne's Gray: 5 Primary Cyan: 1 AA0046 - No 46 - Orange - Matt Suggested using total of 40 parts (DE00: 3.49) Expected: #DE8630, Simulated: #D27C37 - (approximate color) Titanium White: 1 Pyrrole Orange: 6 Diarylide Yellow: 6 Benzimidazolone Yellow Light: 5 Yellow Ochre: 22 AB0047 - No 47 - Sea Blue - Gloss Suggested using total of 10 parts (DE00: 0.43) Expected: #80B1C4, Simulated: #80B2C4 Primary Cyan: 1 Titanium White: 8 Bone Black: 1 DB0048 - No 48 - Mediterranean Blue - Gloss Suggested using total of 9 parts (DE00: 0.29) Expected: #4584A2, Simulated: #4684A3 Teal: 7 Quinacridone Violet: 1 Ultramarine Blue: 1 AA0549 - No 50 - Green Mist - Metallic Suggested using total of 23 parts (DE00: 0.50) Expected: #397466, Simulated: #3A7465 Teal: 4 Phthalo Green (Blue Shade): 4 Raw Sienna: 12 Ultramarine Blue: 3 AA0552 - No 51 - Sunset Red - Metallic Suggested using total of 17 parts (DE00: 0.48) Expected: #8F5E74, Simulated: #8C5E73 Primary Magenta: 6 Titan Buff: 7 Transparent Yellow Iron Oxide: 3 Prussian Blue Hue: 1 AB0052 - No 52 - Baltic Blue - Metallic Suggested using total of 16 parts (DE00: 0.45) Expected: #2B72AA, Simulated: #2971AD Ultramarine Blue: 11 Teal: 5 AA0583 - No 53 - Gunmetal - Metallic Suggested using total of 39 parts (DE00: 0.45) Expected: #797878, Simulated: #797879 Titan Buff: 20 Bone Black: 18 Red Oxide: 1 DB0053 - No 53 - Gunmetal - Metallic Suggested using total of 16 parts (DE00: 0.41) Expected: #86888A, Simulated: #858888 Raw Sienna: 4 Titanium White: 11 Carbon Black: 1 DB0054 - No 54 - Brass - Metallic Suggested using total of 36 parts (DE00: 0.48) Expected: #9B7E51, Simulated: #997D51 Raw Sienna: 16 Titanium White: 6 Pyrrole Red Light: 2 Bone Black: 5 Cadmium Yellow Medium Hue: 7 DB0055 - No 55 - Bronze - Metallic Suggested using total of 16 parts (DE00: 0.37) Expected: #9A7455, Simulated: #997555 Titan Green Pale: 4 Burnt Umber Light: 8 Cadmium Yellow Medium Hue: 3 Pyrrole Red Light: 1 DB0056 - No 56 - Aluminium - Metallic Suggested using total of 8 parts (DE00: 0.29) Expected: #A2A5A7, Simulated: #A1A5A7 Titanium White: 5 Bone Black: 2 Titan Green Pale: 1 DB0057 - No 57 - Pink - Matt Suggested using total of 26 parts (DE00: 0.47) Expected: #EFABB8, Simulated: #EDAAB7 Primary Magenta: 2 Titanium White: 21 Raw Sienna: 3 DB0058 - No 58 - Magenta - Matt Suggested using total of 17 parts (DE00: 0.50) Expected: #AF576B, Simulated: #B1566A Quinacridone Crimson: 8 Titan Buff: 8 Naphthol Red Light: 1 DB0060 - No 60 - Scarlet - Matt Suggested using total of 35 parts (DE00: 0.59) Expected: #A23734, Simulated: #A73334 Naphthol Red Medium: 22 Pyrrole Orange: 12 Red Oxide: 1 DB0061 - No 61 - Flesh - Matt Suggested using total of 37 parts (DE00: 0.35) Expected: #DC946F, Simulated: #DC936F Titan Buff: 21 Raw Sienna: 9 Pyrrole Red Light: 4 Hansa Yellow Opaque: 3 DB0062 - No 62 - Leather - Matt Suggested using total of 9 parts (DE00: 0.25) Expected: #906141, Simulated: #936041 Burnt Sienna: 2 Raw Sienna: 7 DB0063 - No 63 - Sand - Matt Suggested using total of 7 parts (DE00: 0.48) Expected: #BB8958, Simulated: #B88956 Titan Green Pale: 2 Raw Sienna: 2 Diarylide Yellow: 1 Burnt Sienna: 2 DB0064 - No 64 - Light Grey - Matt Suggested using total of 15 parts (DE00: 0.10) Expected: #939695, Simulated: #939695 Titanium White: 9 Bone Black: 5 Transparent Yellow Iron Oxide: 1 AB0065 - No 65 - Aircraft Blue - Matt Suggested using total of 20 parts (DE00: 0.42) Expected: #92B7B5, Simulated: #94B8B9 Titan Buff: 17 Primary Cyan: 1 Ultramarine Violet: 2 AA0727 - No 65 - Aircraft Blue - Matt Suggested using total of 21 parts (DE00: 0.46) Expected: #86AAAB, Simulated: #86A8A9 Titan Green Pale: 19 Prussian Blue Hue: 2 AA0730 - No 66 - Olive Drab - Matt Suggested using total of 12 parts (DE00: 0.33) Expected: #4A4D4B, Simulated: #4A4D4B Raw Umber: 9 Teal: 2 Carbon Black: 1 DB0067 - No 67 - Tank Grey - Matt Suggested using total of 35 parts (DE00: 0.49) Expected: #474B4D, Simulated: #484B4E Titanium White: 3 Bone Black: 31 Permanent Green Light: 1 DB0068 - No 68 - Purple - Gloss Suggested using total of 47 parts (DE00: 0.41) Expected: #614C64, Simulated: #614D63 Ultramarine Violet: 37 Titan Buff: 4 Quinacridone Crimson: 5 Benzimidazolone Yellow Light: 1 DB0069 - No 69 - Yellow - Gloss Suggested using total of 27 parts (DE00: 0.50) Expected: #EDBB3F, Simulated: #E7BC3F Benzimidazolone Yellow Medium: 13 Titan Buff: 11 Burnt Sienna: 1 Hansa Yellow Opaque: 2 AA0775 - No 70 - Brick Red - Matt Suggested using total of 6 parts (DE00: 0.34) Expected: #78544F, Simulated: #77534F Teal: 1 Burnt Sienna: 4 Naphthol Red Light: 1 DB0071 - No 71 - Oak - Satin Suggested using total of 4 parts (DE00: 0.42) Expected: #CFBA91, Simulated: #D0BB90 Titan Buff: 2 Titan Green Pale: 1 Yellow Ochre: 1 DB0072 - No 72 - Khaki Drill - Matt Suggested using total of 4 parts (DE00: 0.36) Expected: #88806E, Simulated: #887F6D Raw Sienna: 2 Titanium White: 1 Bone Black: 1 AA0802 - No 73 - Wine - Matt Suggested using total of 42 parts (DE00: 0.49) Expected: #834140, Simulated: #84423F Burnt Sienna: 31 Primary Magenta: 10 Titan Green Pale: 1 AA0816 - No 74 - Linen - Matt Suggested using total of 44 parts (DE00: 0.48) Expected: #DABD74, Simulated: #DDBE74 Cadmium Yellow Medium Hue: 7 Titan Buff: 35 Burnt Umber Light: 2 AA0833 - No 75 - Bronze Green - Matt Suggested using total of 17 parts (DE00: 0.44) Expected: #454B44, Simulated: #444B43 Phthalo Green (Yellow Shade): 3 Transparent Yellow Iron Oxide: 8 Yellow Ochre: 1 Burnt Umber Light: 5 AA0847 - No 76 - Uniform Green - Matt Suggested using total of 27 parts (DE00: 0.49) Expected: #426153, Simulated: #406152 Phthalo Green (Yellow Shade): 3 Transparent Yellow Iron Oxide: 18 Ultramarine Blue: 4 Teal: 2 AA0850 - No 77 - Navy Blue - Matt Suggested using total of 25 parts (DE00: 0.37) Expected: #3D4951, Simulated: #3C484F Ultramarine Violet: 9 Raw Sienna: 9 Primary Cyan: 4 Prussian Blue Hue: 3 AB0078 - No 78 - Cockpit Green - Matt Suggested using total of 35 parts (DE00: 0.47) Expected: #687866, Simulated: #677765 Teal: 6 Raw Sienna: 20 Primary Magenta: 1 Phthalo Green (Yellow Shade): 1 Ultramarine Violet: 7 AA0878 - No 79 - Blue Grey - Matt Suggested using total of 40 parts (DE00: 0.47) Expected: #53585A, Simulated: #53585A Bone Black: 30 Titan Buff: 9 Phthalo Green (Yellow Shade): 1 DB0080 - No 80 - Grass Green - Matt Suggested using total of 6 parts (DE00: 0.25) Expected: #57643D, Simulated: #58643D Raw Sienna: 2 Benzimidazolone Yellow Medium: 2 Sap Green Hue: 1 Ultramarine Blue: 1 STARTER81 - No 81 - Pale Yellow - Matt Suggested using total of 22 parts (DE00: 0.43) Expected: #C1AA5E, Simulated: #BFA85E Yellow Ochre: 4 Benzimidazolone Yellow Medium: 7 Raw Umber: 2 Titanium White: 9 AA0905 - No 82 - Orange Lining - Matt Suggested using total of 9 parts (DE00: 0.45) Expected: #B85B3D, Simulated: #B55B3C Transparent Yellow Iron Oxide: 6 Pyrrole Orange: 2 Primary Yellow: 1 AA0919 - No 83 - Ochre - Matt Suggested using total of 33 parts (DE00: 0.47) Expected: #93855C, Simulated: #92865C Raw Sienna: 28 Titanium White: 4 Primary Cyan: 1 AA0922 - No 84 - Mid Stone - Matt Suggested using total of 31 parts (DE00: 0.42) Expected: #847B62, Simulated: #857C63 Titan Green Pale: 8 Yellow Ochre: 16 Carbon Black: 1 Transparent Yellow Iron Oxide: 6 DB0085 - No 85 - Black - Satin Suggested using total of 1 parts (DE00: 0.43) Expected: #3A3C3D, Simulated: #3B3C3D Carbon Black: 1 DB0086 - No 86 - Light Olive - Matt Suggested using total of 21 parts (DE00: 0.30) Expected: #5B5D4E, Simulated: #5C5E4E Burnt Umber Light: 14 Teal: 4 Sap Green Hue: 3 AA0967 - No 87 - Steel Grey - Matt Suggested using total of 13 parts (DE00: 0.45) Expected: #75888A, Simulated: #75898C Teal: 2 Titanium White: 5 Raw Sienna: 1 Bone Black: 5 AA0970 - No 88 - Deck Green - Matt Suggested using total of 9 parts (DE00: 0.34) Expected: #3C6158, Simulated: #3B6159 Raw Umber: 4 Phthalo Green (Blue Shade): 3 Teal: 2 DB0089 - No 89 - Middle Blue - Matt Suggested using total of 32 parts (DE00: 0.19) Expected: #5F8A9E, Simulated: #608A9F Payne's Gray: 7 Primary Cyan: 4 Titanium White: 16 Raw Sienna: 5 AB0090 - No 90 - Beige Green - Matt Suggested using total of 41 parts (DE00: 0.50) Expected: #B9C7A5, Simulated: #B9C5A3 Titan Green Pale: 30 Hansa Yellow Opaque: 1 Teal: 1 Titan Buff: 9 AB0091 - No 91 - Black Green - Matt Suggested using total of 12 parts (DE00: 0.48) Expected: #525A59, Simulated: #525B5A Burnt Umber Light: 7 Teal: 4 Carbon Black: 1 DB0093 - No 93 - Desert Yellow - Matt Suggested using total of 19 parts (DE00: 0.42) Expected: #A78B68, Simulated: #A78A67 Titan Green Pale: 6 Raw Sienna: 7 Burnt Umber Light: 5 Cadmium Yellow Medium Hue: 1 AB0094 - No 94 - Brown Yellow - Matt Suggested using total of 32 parts (DE00: 0.48) Expected: #AC8C64, Simulated: #AF8D65 Raw Sienna: 22 Titan Green Pale: 7 Burnt Umber Light: 3 DB0096 - No 96 - RAF Blue - Matt Suggested using total of 24 parts (DE00: 0.41) Expected: #4B5E6D, Simulated: #4C5E6E Titanium White: 6 Bone Black: 13 Prussian Blue Hue: 5 DB0098 - No 98 - Chocolate - Matt Suggested using total of 36 parts (DE00: 0.29) Expected: #5B504E, Simulated: #5A4F4D Carbon Black: 2 Titanium White: 3 Transparent Yellow Iron Oxide: 27 Cadmium Red Medium Hue: 4 DB0099 - No 99 - Lemon - Matt Suggested using total of 3 parts (DE00: 0.56) Expected: #EECD2D, Simulated: #F1CF32 Hansa Yellow Opaque: 1 Titan Buff: 1 Benzimidazolone Yellow Light: 1 AA1105 - No 100 - Red Brown - Matt Suggested using total of 6 parts (DE00: 0.40) Expected: #9C4B36, Simulated: #9E4B37 Red Oxide: 3 Pyrrole Orange: 2 Benzimidazolone Yellow Medium: 1 AA1119 - No 101 - Mid Green - Matt Suggested using total of 12 parts (DE00: 0.42) Expected: #3D7150, Simulated: #3B714F Teal: 1 Transparent Yellow Iron Oxide: 6 Phthalo Green (Yellow Shade): 3 Chromium Oxide Green: 2 DB0102 - No 102 - Army Green - Matt Suggested using total of 34 parts (DE00: 0.49) Expected: #5D6351, Simulated: #5F6352 Burnt Umber Light: 23 Phthalo Green (Yellow Shade): 5 Hansa Yellow Opaque: 1 Titan Green Pale: 5 DB0103 - No 103 - Cream - Matt Suggested using total of 16 parts (DE00: 0.40) Expected: #C8AF81, Simulated: #C8B080 Titan Green Pale: 6 Yellow Ochre: 7 Titan Buff: 3 AB0104 - No 104 - Oxford Blue - Matt Suggested using total of 14 parts (DE00: 0.44) Expected: #464C5A, Simulated: #474E5B Ultramarine Violet: 9 Teal: 1 Bone Black: 4 AA1167 - No 105 - Marine Green - Matt Suggested using total of 20 parts (DE00: 0.46) Expected: #505B44, Simulated: #4F5B45 Transparent Yellow Iron Oxide: 15 Sap Green Hue: 1 Primary Cyan: 1 Primary Yellow: 3 DB0106 - No 106 - Ocean Grey - Matt Suggested using total of 7 parts (DE00: 0.48) Expected: #666A6D, Simulated: #66696C Bone Black: 5 Titan Green Pale: 2 DB0109 - No 109 - WWI Blue - Matt Suggested using total of 27 parts (DE00: 0.44) Expected: #4F7D9D, Simulated: #507D9F Teal: 14 Ultramarine Violet: 11 Quinacridone Violet: 2 DB0110 - No 110 - Natural Wood - Matt Suggested using total of 25 parts (DE00: 0.44) Expected: #816C51, Simulated: #826C53 Raw Sienna: 18 Titan Green Pale: 2 Bone Black: 4 Pyrrole Orange: 1 DB0113 - No 113 - Rust - Matt Suggested using total of 23 parts (DE00: 0.33) Expected: #79524C, Simulated: #7A514C Bone Black: 3 Yellow Ochre: 10 Teal: 2 Cadmium Red Medium Hue: 8 AA1287 - No 116 - US Dark Green - Matt Suggested using total of 39 parts (DE00: 0.44) Expected: #515349, Simulated: #515348 Bone Black: 20 Yellow Ochre: 17 Primary Cyan: 1 Teal: 1 DB0117 - No 117 - US Light Green - Matt Suggested using total of 25 parts (DE00: 0.43) Expected: #555A44, Simulated: #545A44 Bone Black: 1 Primary Cyan: 1 Benzimidazolone Yellow Medium: 2 Transparent Yellow Iron Oxide: 21 DB0118 - No 118 - US Tan - Matt Suggested using total of 32 parts (DE00: 0.25) Expected: #91796A, Simulated: #91796A Titanium White: 10 Bone Black: 9 Raw Sienna: 8 Pyrrole Orange: 4 Diarylide Yellow: 1 AA1314 - No 119 - Light Earth - Matt Suggested using total of 23 parts (DE00: 0.34) Expected: #957860, Simulated: #967961 Raw Sienna: 15 Titanium White: 4 Bone Black: 3 Pyrrole Red Light: 1 AA1328 - No 120 - Light Green - Matt Suggested using total of 33 parts (DE00: 0.47) Expected: #668064, Simulated: #668164 Raw Sienna: 23 Teal: 7 Bone Black: 2 Phthalo Green (Yellow Shade): 1 AA1331 - No 121 - Pale Stone - Matt Suggested using total of 22 parts (DE00: 0.43) Expected: #C3B29A, Simulated: #C1B098 Titan Green Pale: 18 Pyrrole Red Light: 1 Yellow Ochre: 3 DB0123 - No 123 - Extra Dark Sea Grey - Satin Suggested using total of 8 parts (DE00: 0.30) Expected: #5B5F64, Simulated: #5B5F64 Titan Green Pale: 5 Raw Umber: 1 Carbon Black: 2 AA1376 - No 125 - US Dark Grey - Satin Suggested using total of 6 parts (DE00: 0.49) Expected: #5D636A, Simulated: #5E636A Ultramarine Violet: 2 Titan Green Pale: 3 Carbon Black: 1 AA1393 - No 126 - US Medium Grey - Satin Suggested using total of 16 parts (DE00: 0.50) Expected: #82878A, Simulated: #818689 Titan Buff: 15 Carbon Black: 1 DB0127 - No 127 - US Ghost Grey - Satin Suggested using total of 36 parts (DE00: 0.34) Expected: #A7B1B9, Simulated: #A6AFB8 Titanium White: 28 Titan Buff: 3 Primary Cyan: 2 Red Oxide: 3 AA1417 - No 128 - US Compass Grey - Satin Suggested using total of 29 parts (DE00: 0.24) Expected: #606369, Simulated: #5F6369 Bone Black: 19 Titanium White: 9 Carbon Black: 1 AA1420 - No 129 - US Gull Grey - Satin Suggested using total of 32 parts (DE00: 0.45) Expected: #A9A9A5, Simulated: #A7A8A3 Titan Buff: 13 Titanium White: 12 Bone Black: 6 Yellow Ochre: 1 DB0130 - No 130 - White - Satin Suggested using total of 1 parts (DE00: 0.28) Expected: #FBFBF7, Simulated: #FAFAF6 Titanium White: 1 AA1448 - No 131 - Mid Green - Satin Suggested using total of 44 parts (DE00: 0.49) Expected: #567D4D, Simulated: #577C4E Chromium Oxide Green: 10 Primary Yellow: 13 Primary Cyan: 3 Titan Buff: 4 Transparent Yellow Iron Oxide: 14 AA1451 - No 132 - Red - Satin Suggested using total of 13 parts (DE00: 0.39) Expected: #B34D3D, Simulated: #B34E3E Transparent Yellow Iron Oxide: 9 Pyrrole Red Light: 3 Hansa Yellow Opaque: 1 AA1465 - No 133 - Brown - Satin Suggested using total of 13 parts (DE00: 0.32) Expected: #734A3E, Simulated: #73493E Bone Black: 3 Raw Sienna: 5 Red Oxide: 5 AA1523 - No 140 - Gull Grey - Matt Suggested using total of 13 parts (DE00: 0.17) Expected: #787D82, Simulated: #787D82 Red Oxide: 3 Titan Buff: 8 Primary Cyan: 2 AA1568 - No 144 - Intermediate Blue - Matt Suggested using total of 11 parts (DE00: 0.45) Expected: #616C79, Simulated: #626C78 Titanium White: 6 Carbon Black: 1 Payne's Gray: 3 Transparent Yellow Iron Oxide: 1 STARTER145 - No 145 - Medium Grey - Matt Suggested using total of 23 parts (DE00: 0.42) Expected: #7B8B93, Simulated: #7B8A92 Titan Green Pale: 17 Carbon Black: 1 Ultramarine Blue: 5 AA1571 - No 145 - Medium Grey - Matt Suggested using total of 32 parts (DE00: 0.25) Expected: #778388, Simulated: #778389 Red Oxide: 6 Titan Buff: 21 Primary Cyan: 5 AA1599 - No 147 - Light Grey - Matt Suggested using total of 22 parts (DE00: 0.64) Expected: #C2C6C4, Simulated: #BEC2C0 Titan Green Pale: 3 Titanium White: 17 Bone Black: 2 AA1609 - No 148 - Radome Tan - Matt Suggested using total of 21 parts (DE00: 0.50) Expected: #E3C495, Simulated: #E2C196 Titan Buff: 17 Yellow Ochre: 4 AA1612 - No 149 - Dark Green - Matt Suggested using total of 41 parts (DE00: 0.46) Expected: #4D5D58, Simulated: #4C5C57 Teal: 6 Bone Black: 19 Transparent Yellow Iron Oxide: 15 Phthalo Green (Yellow Shade): 1 AA1626 - No 150 - Forest Green - Matt Suggested using total of 34 parts (DE00: 0.45) Expected: #5C5D42, Simulated: #5C5D44 Bone Black: 14 Raw Sienna: 13 Titanium White: 1 Cadmium Yellow Medium Hue: 6 DB0153 - No 153 - Insignia Red - Matt Suggested using total of 9 parts (DE00: 0.45) Expected: #A1393C, Simulated: #9E3A3B Primary Magenta: 5 Burnt Sienna: 2 Pyrrole Red Light: 1 Raw Sienna: 1 DB0154 - No 154 - Insignia Yellow - Matt Suggested using total of 22 parts (DE00: 1.15) Expected: #F2A619, Simulated: #F5AC0E Diarylide Yellow: 8 Benzimidazolone Yellow Light: 13 Titan Green Pale: 1 DB0155 - No 155 - Olive Drab - Matt Suggested using total of 24 parts (DE00: 0.39) Expected: #5F5A46, Simulated: #5E5A47 Transparent Yellow Iron Oxide: 16 Titan Buff: 1 Bone Black: 5 Benzimidazolone Yellow Medium: 2 DB0156 - No 156 - Dark Camouflage Grey - Satin Suggested using total of 31 parts (DE00: 0.47) Expected: #6A6E72, Simulated: #6A6E71 Titanium White: 5 Bone Black: 21 Titan Green Pale: 5 A1701 - No 157 - Azure Blue - Matt Suggested using total of 19 parts (DE00: 0.49) Expected: #556774, Simulated: #546673 Titanium White: 11 Carbon Black: 3 Primary Cyan: 5 AA1729 - No 159 - Khaki Drab - Matt Suggested using total of 34 parts (DE00: 0.43) Expected: #676245, Simulated: #676145 Bone Black: 4 Raw Sienna: 29 Phthalo Green (Yellow Shade): 1 DB0160 - No 160 - German Camouflage Red - Matt Suggested using total of 45 parts (DE00: 0.49) Expected: #634D48, Simulated: #634D49 Raw Sienna: 12 Bone Black: 21 Titan Buff: 4 Pyrrole Red Light: 8 DB0163 - No 163 - Dark Green - Satin Suggested using total of 33 parts (DE00: 0.36) Expected: #54544F, Simulated: #53544E Burnt Umber Light: 24 Teal: 6 Carbon Black: 2 Hansa Yellow Opaque: 1 AA1780 - No 164 - Dark Sea Grey - Satin Suggested using total of 42 parts (DE00: 0.38) Expected: #62666C, Simulated: #61656B Bone Black: 28 Titanium White: 13 Carbon Black: 1 AB0165 - No 165 - Medium Sea Grey - Satin Suggested using total of 18 parts (DE00: 0.49) Expected: #858B8D, Simulated: #858A8C Titan Buff: 17 Carbon Black: 1 AA1804 - No 166 - Light Aircraft Grey - Satin Suggested using total of 10 parts (DE00: 0.37) Expected: #ADAFA8, Simulated: #AEB1AA Titan Green Pale: 7 Ultramarine Violet: 3 AB0167 - No 167 - RAF Barley Grey - Satin Suggested using total of 29 parts (DE00: 0.29) Expected: #959998, Simulated: #949897 Carbon Black: 1 Titan Buff: 28 AB0168 - No 168 - Hemp - Satin Suggested using total of 13 parts (DE00: 0.48) Expected: #A49B87, Simulated: #A39A85 Raw Umber: 3 Transparent Yellow Iron Oxide: 2 Titanium White: 4 Titan Green Pale: 4 DB0171 - No 171 - Anitique Bronze - Metallic Suggested using total of 40 parts (DE00: 0.33) Expected: #9C7D62, Simulated: #9C7D63 Raw Sienna: 13 Titanium White: 14 Red Oxide: 8 Sap Green Hue: 5 AA0173 - No 173 - Track Colour - Matt Suggested using total of 45 parts (DE00: 0.42) Expected: #4D4746, Simulated: #4C4646 Carbon Black: 1 Transparent Yellow Iron Oxide: 43 Naphthol Red Medium: 1 DB0174 - No 174 - Signal Red - Satin Suggested using total of 9 parts (DE00: 0.17) Expected: #BC3E3C, Simulated: #BD3F3C Benzimidazolone Yellow Light: 2 Primary Magenta: 5 Benzimidazolone Yellow Medium: 2 DB0186 - No 186 - Brown - Matt Suggested using total of 11 parts (DE00: 0.43) Expected: #755440, Simulated: #745340 Raw Sienna: 7 Bone Black: 2 Pyrrole Orange: 2 A6238 - No 187 - Dark Stone - Matt Suggested using total of 13 parts (DE00: 0.40) Expected: #8A806C, Simulated: #897E6A Raw Sienna: 7 Titanium White: 3 Bone Black: 3 DB0191 - No 191 - Chrome Silver - Metallic Suggested using total of 30 parts (DE00: 0.49) Expected: #C3C3C2, Simulated: #C0C1C0 Titanium White: 26 Bone Black: 3 Raw Sienna: 1 AA6330 - No 195 - Dark Green - Satin Suggested using total of 13 parts (DE00: 0.50) Expected: #485449, Simulated: #48554A Bone Black: 2 Raw Sienna: 9 Primary Cyan: 2 AA6344 - No 196 - Light Grey - Satin Suggested using total of 20 parts (DE00: 0.48) Expected: #BFC2C0, Simulated: #BCC0BD Titan Green Pale: 3 Titanium White: 15 Bone Black: 2 AA6389 - No 200 - Pink - Gloss Suggested using total of 42 parts (DE00: 0.34) Expected: #EEA4B0, Simulated: #ECA3AF Primary Magenta: 4 Titanium White: 33 Yellow Ochre: 5 AA6392 - No 201 - Black - Metallic Suggested using total of 2 parts (DE00: 0.48) Expected: #3D3D3E, Simulated: #3D3E3E Carbon Black: 1 Raw Sienna: 1 DB0208 - No 208 - Signal Green - Fluorescent Suggested using total of 1 parts (DE00: 14.92) Expected: #00B73A, Simulated: #007E4C - (approximate color) Permanent Green Light: 1 DB0209 - No 209 - Fire Orange - Fluorescent Suggested using total of 28 parts (DE00: 5.57) Expected: #FF2A2C, Simulated: #F6532C - (approximate color) Titanium White: 1 Pyrrole Orange: 27 AA6608 - No 220 - Racing Red - Gloss Suggested using total of 12 parts (DE00: 0.28) Expected: #9A393F, Simulated: #99383F Primary Magenta: 4 Quinacridone Violet: 1 Raw Sienna: 3 Benzimidazolone Yellow Light: 2 Cadmium Red Medium Hue: 2 AA7222 - No 222 - Moonlight Blue - Metallic Suggested using total of 22 parts (DE00: 0.48) Expected: #444B78, Simulated: #444C77 Ultramarine Violet: 17 Prussian Blue Hue: 3 Titan Buff: 2 AA7224 - No 224 - Dark Slate Grey - Matt Suggested using total of 25 parts (DE00: 0.46) Expected: #60625C, Simulated: #61625C Bone Black: 13 Titan Green Pale: 4 Transparent Yellow Iron Oxide: 8 AA7225 - No 225 - Middle Stone - Matt Suggested using total of 28 parts (DE00: 0.40) Expected: #9A7E4B, Simulated: #997E4B Yellow Ochre: 24 Ultramarine Violet: 3 Teal: 1 AB0226 - No 226 - Interior Green - Matt Suggested using total of 13 parts (DE00: 0.15) Expected: #6A6B4A, Simulated: #6A6B4A Bone Black: 1 Yellow Ochre: 11 Primary Cyan: 1 AB0230 - No 230 - Pru Blue - Matt Suggested using total of 18 parts (DE00: 0.39) Expected: #5B6F79, Simulated: #5C707B Ultramarine Violet: 4 Bone Black: 7 Titan Green Pale: 5 Primary Cyan: 2 AA0234 - No 234 - Dark Flesh - Matt Suggested using total of 46 parts (DE00: 0.30) Expected: #947365, Simulated: #947366 Titanium White: 14 Burnt Umber Light: 31 Primary Yellow: 1 AB0237 - No 237 - Desert Tan - Matt Suggested using total of 20 parts (DE00: 0.33) Expected: #B7A282, Simulated: #B6A180 Titan Green Pale: 11 Burnt Umber Light: 3 Yellow Ochre: 6 AB0238 - No 238 - Arrow Red - Gloss Suggested using total of 12 parts (DE00: 1.42) Expected: #CA2F40, Simulated: #C13942 Titanium White: 1 Cadmium Red Medium Hue: 11 AB0239 - No 239 - British Racing Green - Gloss Suggested using total of 19 parts (DE00: 0.42) Expected: #394442, Simulated: #394341 Sap Green Hue: 8 Primary Cyan: 10 Carbon Black: 1 AB0240 - No 240 - RLM02 Grau - Matt Suggested using total of 33 parts (DE00: 0.45) Expected: #7B796B, Simulated: #7B7A6C Teal: 1 Yellow Ochre: 12 Titanium White: 8 Bone Black: 12 AA2240 - No 240 - RLM02 Grau - Matt Suggested using total of 46 parts (DE00: 0.42) Expected: #858471, Simulated: #848371 Bone Black: 11 Titan Buff: 19 Yellow Ochre: 15 Primary Cyan: 1 AA2241 - No 241 - RLM70 Schwartzgrun - Matt Suggested using total of 14 parts (DE00: 0.27) Expected: #434947, Simulated: #434948 Transparent Yellow Iron Oxide: 13 Prussian Blue Hue: 1 AB0242 - No 242 - RLM71 Dunkelgrun - Matt Suggested using total of 27 parts (DE00: 0.46) Expected: #51514B, Simulated: #51514C Raw Sienna: 22 Titanium White: 2 Carbon Black: 3 AA2242 - No 242 - RLM71 Dunkelgrun - Matt Suggested using total of 34 parts (DE00: 0.40) Expected: #474A47, Simulated: #474B46 Teal: 1 Bone Black: 23 Yellow Ochre: 9 Primary Cyan: 1 AB0243 - No 243 - RLM72 Grun - Matt Suggested using total of 13 parts (DE00: 0.32) Expected: #414547, Simulated: #414547 Ultramarine Violet: 4 Raw Umber: 2 Primary Cyan: 1 Transparent Yellow Iron Oxide: 6 AB0244 - No 244 - RLM73 Grun - Matt Suggested using total of 16 parts (DE00: 0.43) Expected: #424C4B, Simulated: #414B4A Bone Black: 9 Teal: 1 Transparent Yellow Iron Oxide: 5 Phthalo Green (Yellow Shade): 1 AB0245 - No 245 - RLM74 Graugrun - Matt Suggested using total of 33 parts (DE00: 0.50) Expected: #525352, Simulated: #515251 Raw Sienna: 23 Titanium White: 5 Carbon Black: 5 AB0246 - No 246 - RLM75 Grauviolett - Matt Suggested using total of 13 parts (DE00: 0.36) Expected: #61646A, Simulated: #606369 Bone Black: 9 Titanium White: 3 Ultramarine Violet: 1 AB0247 - No 247 - RLM76 Lichtblau - Matt Suggested using total of 35 parts (DE00: 0.40) Expected: #98A4A7, Simulated: #98A6A9 Titan Green Pale: 23 Ultramarine Violet: 11 Prussian Blue Hue: 1 AA2247 - No 247 - RLM76 Lichtblau - Matt Suggested using total of 27 parts (DE00: 0.45) Expected: #94A5A8, Simulated: #93A5AA Titan Green Pale: 16 Ultramarine Violet: 10 Primary Cyan: 1 AA2248 - No 248 - RLM78 Himmelblau - Matt Suggested using total of 13 parts (DE00: 0.39) Expected: #728891, Simulated: #738991 Titanium White: 7 Transparent Yellow Iron Oxide: 3 Prussian Blue Hue: 2 Pyrrole Orange: 1 AB0249 - No 249 - RLM79 Sandgelb - Matt Suggested using total of 42 parts (DE00: 0.35) Expected: #8F705D, Simulated: #8E705D Yellow Ochre: 25 Titanium White: 9 Red Oxide: 7 Carbon Black: 1 AB0251 - No 251 - RLM81 Dunkelbraun - Matt Suggested using total of 33 parts (DE00: 0.39) Expected: #534B4A, Simulated: #544B4A Bone Black: 19 Titanium White: 2 Red Oxide: 3 Transparent Yellow Iron Oxide: 9 AB0252 - No 252 - RLM82 Olivgrun - Matt Suggested using total of 31 parts (DE00: 0.38) Expected: #5E634C, Simulated: #5D634C Yellow Ochre: 24 Primary Cyan: 5 Pyrrole Red Light: 2 AA2252 - No 252 - RLM82 Olivgrun - Matt Suggested using total of 29 parts (DE00: 0.43) Expected: #636756, Simulated: #626755 Bone Black: 7 Raw Sienna: 19 Teal: 3 AB0253 - No 253 - RLM83 Dunkel Grun - Matt Suggested using total of 21 parts (DE00: 0.47) Expected: #58584C, Simulated: #58594B Teal: 1 Bone Black: 10 Yellow Ochre: 10 AA2253 - No 253 - RLM83 Dunkel Grun - Matt Suggested using total of 40 parts (DE00: 0.37) Expected: #555549, Simulated: #55554A Burnt Umber Light: 27 Primary Cyan: 7 Diarylide Yellow: 3 Titanium White: 3 AC5008 - No 27001 - Aluminium - Metallic Suggested using total of 50 parts (DE00: 0.64) Expected: #C7C7C9, Simulated: #C6C5C6 Titanium White: 45 Bone Black: 4 Burnt Sienna: 1 AC5011 - No 27002 - Polished Aluminium - Metallic Suggested using total of 49 parts (DE00: 0.59) Expected: #CDCED0, Simulated: #CCCFD1 Titanium White: 46 Bone Black: 3 AC5025 - No 27003 - Polished Steel - Metallic Suggested using total of 11 parts (DE00: 0.33) Expected: #5B5C61, Simulated: #5C5C61 Titan Green Pale: 2 Burnt Sienna: 5 Payne's Gray: 4 AC5039 - No 27004 - Gunmetal - Metallic Suggested using total of 27 parts (DE00: 0.30) Expected: #585A5F, Simulated: #585B60 Ultramarine Violet: 17 Teal: 3 Burnt Umber Light: 7 Edited June 30, 2022 by Casey Updated with even more recipes 5 2 Link to comment Share on other sites More sharing options...
Mark Harmsworth Posted April 7, 2022 Share Posted April 7, 2022 Wow. I think I'm impressed but I'm not completely sure as I only understood about 10% of that. Link to comment Share on other sites More sharing options...
Casey Posted April 7, 2022 Author Share Posted April 7, 2022 If you think I should update the post with more explanations and a guide how to make an use of it - please let me know, I'll be happy to provide a tutorial. 1 1 Link to comment Share on other sites More sharing options...
John Laidlaw Posted April 7, 2022 Share Posted April 7, 2022 This is wonderful, thank you! Link to comment Share on other sites More sharing options...
Troy Smith Posted April 7, 2022 Share Posted April 7, 2022 1 hour ago, Casey said: If you think I should update the post with more explanations and a guide how to make an use of it - please let me know, I'll be happy to provide a tutorial. I think it would help. I'll @Jamie @ Sovereign Hobbies as he might find this interesting. Link to comment Share on other sites More sharing options...
Troy Smith Posted April 7, 2022 Share Posted April 7, 2022 On 05/04/2022 at 04:13, Casey said: Purpose: Re-create Humbrol range of paints using commercially available paints from a given vendor. Reasoning: Needed an alternative for discontinued / health risk products. And I like math. Methodology: Custom implementation of two-flux Kubelka-Munk algorithm with measured model of Golden Fluid Acrylics. Paint mixing solves the minimum of perceptual difference between target paint and the mixture, prioritizing for small integer ratios of constituent paints. Target is a measured spectral data (see other posts). Of more use would be mixes like for actual colours, given how blinkin' awful many of the existing acrylic matches are for, obscure things like RAF Dark Green (eg Humbrol 30) and Dark Earth (eh Humbrol 29) etc etc..... the Humbrol paint range is wide, but lacks a lot of useful colours... Of the US NAvy Sea Blues.... On 05/04/2022 at 04:13, Casey said: Ratios are given in mass not volume. OK, how are the mixes supposed to work, done one sensitive scales? cheers T Link to comment Share on other sites More sharing options...
Casey Posted April 7, 2022 Author Share Posted April 7, 2022 4 minutes ago, Troy Smith said: Of more use would be mixes like for actual colours, given how blinkin' awful many of the existing acrylic matches are for, obscure things like RAF Dark Green (eg Humbrol 30) and Dark Earth (eh Humbrol 29) etc etc..... the Humbrol paint range is wide, but lacks a lot of useful colours... Of the US NAvy Sea Blues.... I am working on it too (slowly). Please see the RLM example on another post. 4 minutes ago, Troy Smith said: OK, how are the mixes supposed to work, done one sensitive scales? cheers T I did originals calculations with measurements taken on jewelry scale. I did checked those mixes using simply numbers as 'paint parts' and they are acceptable. The density of original paints is rather uniform (0.952g/ml with standard deviation of 0.081 from my measurements). 1 Link to comment Share on other sites More sharing options...
Jamie @ Sovereign Hobbies Posted April 7, 2022 Share Posted April 7, 2022 Have you tested these? I do enjoy this sort of exercise but a couple of observations if I may: Firstly, ultramarine blue is a bit of a pain. I love the pigment and the colour and whilst it can be bought dry and as artists paints, it's been shunned by commercial paint pigment tint manufacturers. It's eluded me so far to the extent that I don't make a WWII submarine colour I really want to make because it can only be done with proper ultramarine and I can't get a compatible pigment tint for my composition. Secondly, whilst density of paint is fairly uniform, the staining power of different pigments most certainly is not, nor is it certain that the proportion of the paint mass which is that pigment is consistent - indeed some commercial paint manufacture software packages offer or indeed default in some cases to minimising the total injected pigment tint to achieve the target colour. This can be tested with a selection of model paints even from the same brand: one can mix one drop each of two paints and expect a colour half way between the two only to discover one colour absolutely steamrolls the other and the resultant mix looks very much more like one than the other. Lastly (ok, I said a couple), the pigmentation requirements are nominally calculated by the software using similar algorithms to achieve a target, but roughly half of our batches need manual intervention and adjustment after the machine has had its go at it and a physical sample of the result is measured. It's better than starting from scratch every time but the calculations aren't that reliable. There are small variables in various places. One of them we don't really have to worry about with the batch sizes we make is the minimum dose, which a modeller probably will have to worry about. How heavy is one drop? Despite the high precision of progressive cavity pumps and relatively large batches to make differences in injection quantities insignificant, we still get variations from one batch to the next as even the expensive high quality pigments vary from one batch to the next - not so much in their colour but their opacity as a liquid tint. Tiny differences make a surprisingly big difference to the result, especially where small quantities are called for in the recipe. 5 1 Link to comment Share on other sites More sharing options...
Casey Posted April 7, 2022 Author Share Posted April 7, 2022 (edited) Thank you for the great feedback. I can only agree with everything you wrote in your post. The whole thing started for me as an interesting hobby excercise and by no means it is aimed to replace the professional paint making process. It was more of a result of an despair I faced while trying to use the original paint manufacturer products. You can think of it as of any other of "<paint vendor> mixes to achieve <some color>" charts that there are many online... Mine are just based on my personal math obsession. I tested some (I admit not all) of those recipes and the results were decent enough for me to decide to share. For small volume liquid dispensing I use micropipettes (and calculator). Also, I am comparing my results to the targetted paint manufacturer and their current consistency of color matching of batch-to-batch delivery process... And thanks to the myriad of variables it was never going to be as accurate as a validated batch of a paint delivered by an producer with proper equipment. But who knows, maybe I'll discover a genius way to calculate pigment tinting coefficient without spectrophotometer... Edited April 8, 2022 by Casey 6 Link to comment Share on other sites More sharing options...
Jochen Barett Posted April 8, 2022 Share Posted April 8, 2022 I'm impressed by the theory and would love to see examples in real life. Link to comment Share on other sites More sharing options...
Casey Posted June 29, 2022 Author Share Posted June 29, 2022 (edited) FYI - I am still working on those. I've updated the recipes in this thread with my most recent math. It is an effort of producing of more than 1000 of paint swatches so far to provide the data to characterize the Golden pigments and the results are really good now. Here is an example of Humbrol 93 - desert yellow. It is one the 'difficult' colors to match since it correlates with human color sensitivity curve. My math results and suggested simple recipe And the reality (measurements from spectrophotometer of an original paint and the paint made from above recipe) The results are quite good. And this is how both colors look (real paints) as they are seen by spectrophotometer: The one on the left is original Humbrol, the one on the right is my mix. My work is currently based on following parts: Simulation of light behavior - paint is a semi-transparent medium of a different refraction index than air and all measurements need to factor that. This effects highly depends on the geometry of hardware used for measurements. Pigment characterization - to provide absorption / scattering coefficients for pigments at each wavelength. They both describe tinting strength too. Pigment mixing simulation - it gives me a spectral curve for any arbitrary mix of pigments Optimal pigment selection - to figure out the best combination of pigments that give the resulting color. This is a rabbit hole of fun! Perceptual curve-fitting - to use the data above to solve the 'how much of each pigment I need' question to re-create a paint that will be *seen* as same by humans, while not necessary being an exact copy. Exact curve-fitting - similar as above to get the closest possible representation using the pigments. It may sometimes be impossible or impractical since pigments vary. Paint above is also an good example of the perceptual curve fitting - the paints do differ in spectra but their perception is close. Their measured DE of my mix is 1.15 with the theoretical best being 0.42. Edited June 29, 2022 by Casey 3 Link to comment Share on other sites More sharing options...
sapperastro Posted August 7, 2022 Share Posted August 7, 2022 Did you start this effort because of Humbrol quality decreasing and the line getting constantly cut? Link to comment Share on other sites More sharing options...
