Tamiya 1/6 Harley Davidson
So after having this kit in the loft for a good few years, I've finally made a start on this 1/6th Tamiya Harley Davidson Classic bike.
The kit is the black classic, but I'm going to base it on the 75th anniversary model from 1978/9 and paint it in Harley Davidson black cherry.
I'm planning on going all out on detail and mods, adding all the bits missing from the kit. My plan is to have working lights, but I might be so sick of it by that stage, that I'll bin that idea.
I'm going to be bolting and screwing as much of this as possible. This will also allow me to build it in MY order and not as the instructions say to do
This is the crankcase with the moulded bolts cut off and holes drilled. God, it takes an age doesn't it?
IMG_8930
Tappet blocks on and a couple of cylinder studs in
IMG_8932
Cylinders on
IMG_8936
My plan was to finish the engine before I moved on to the frame, but because I needed to drill several holes in the block for attaching to the frame, I had to assemble the frame and test fit, so I could drill in the correct places
IMG_8949
Reworked transmission plate. Kit one is too short and too thin.  Took forever cutting off the moulded bolts and cleaning out the elongated mounting holes. Transmission can slide now for precise lining up with the primary chain case
Studs fitted to underside of transmission
IMG_8944
Transmission bolted to frame
IMG_8945
Rear and front of engine bolted to frame
IMG_8948 IMG_8950
Now all the holes are where they should be, I can put the frame aside and concentrate on the engine. Once I'm happy and everything is where it should be, I'll take it all apart and paint it, before final assembly
Thanks for looking
Gary
  • Like 11
Little update.
Been working on the engine and associated parts. Quite happy with how it's progressing
I think I'm happy with the colours, aluminium mainly.
IMG_8980 IMG_8979
Starter motor done. Just needs cable added
IMG_8967 IMG_8965
Primary chain case. The starter in the kit is a bit short and never reaches the little bracket that supports it to the transmission on the end.
I've extended the mount and added the studs
IMG_8963
Oil pump reworked. pressure switch and extra outlets added
Dry fit
IMG_8953
Individual parts
IMG_8961
Pressure switch
IMG_8962
Painted and assembled
IMG_8971
Gasket between pump and front cover
IMG_8976
Transmission cover plate drilled out and studs/nuts added
IMG_8957
Thanks for looking
Gary
Edited by apollogary
Not sure why I've spent best part of 2 days on the carburettor, It can barely be seen once the air cleaner is on, but it's good practice if nothing else
Thanks for looking
Gary
52000718389_077bb37182_k.jpg52000462091_3d5a8ca04a_k.jpg51999440802_339e59bff8_k.jpg51999446677_740588e913_k.jpg52000992135_10483fac2a_k.jpg
  • Like 9
On 14/04/2022 at 16:02, krow113 said:
Good stuff.
Are you gonna address the rear exhaust port?
Very visual , very apparent , very wrong , lol.
Can you go into a bit more detail? maybe I'm missing something, but compared to real engines, it doesn't look too far away from what it should look like. Is that instead of being at 12 minutes past, it should be at maybe 5?
Here's the model
IMG_9018
And the real thing
Thunderbike-Harley-Davidson-80-FLH-Shovelhead-Making-Of-Custombike-Foto-Ben-Ott-8-1920x1280
Realisation
Anyway..... couple of updates
Temporarily back in frame, with points cover and air cleaner cover temporarily on. Tappets fitted. Oil pump and hoses fitted and rigid oil line to head and crossover pipe added
IMG_9010
IMG_9018 IMG_9013
Oil drain plug fabricated on inner chaincase
Oil hoses added
IMG_9020
Front oil tank mount/clutch cable bracket added to frame
IMG_9022
Rear oil tank mount
IMG_9023
Front battery tray mount. Kit doesn't have a front mount at all. Can't believe how easily the paint rubs off the silvered parts. Will have to repaint the transmission end cover
IMG_9024 IMG_9026
So many things have to involve things that I really don't want to start on yet. The rear battery mount bracket is also the lug for the battery hold down strap. So i have to temporarily fit the battery housing in place to get that bit right. But... I've run out of 1.2 hex nuts, so will have to wait until after bank holiday for them to arrive.
Once all 4 Battery/oil tank mounts are fitted, I'll cut away the plastic kit mounts.
Thanks for looking
Gary
That‘s an impressive amount of work you are putting in to this 👍
If it wasn‘t for your fingers being visible in some of the photos, I would have thought that I was on the webpage of a Harley garage and not a modeling forum !!
Here's the model
IMG_9018
And the real thing
Has to be for injection moulding purpose' they did it that way.
And will be tough to fix.
Count the fins above it - 3 on the model , 2 on the real thing.
Its only me who sees it , most wont care.
Now the rocker box upper profile looks a little off too...lol
Edited by krow113
Little update
It's coming along slowly, but surely
Starter motor
IMG_9075
Rigid rear brake line and brake light switch
IMG_9083 IMG_9093
Gearbox
IMG_9039
Neutral switch
IMG_9072
Mounted to chain case
IMG_9051 IMG_9054
Oil tank. With vent pipe and "groove"  added to top. Drain plug moved to correct location
IMG_9064 IMG_9062
Clutch cable
IMG_9100
Various scratch built brackets now painted
IMG_9094
Electrical parts assembled. Wiring harnesses made up
IMG_9098 IMG_9088
Frame is painted, so I can finally start putting stuff in it
Thanks for looking
Gary
Looks splendid. 👍
Don't think I could cope with the amount of scratch-building required on these 1/6 kits. The urge to keep getting closer to the real thing must be almost impossible to resist. Certainly a cut above from where I am.
On 30/04/2022 at 04:53, slippers said:
Looks splendid. 👍
Thank you.
Yes it is very difficult where to draw the line. I just take one sub assembly at a time and think about whether I can be really bothered to do more to it. Trouble is, sometimes you just have to step away and have a break. I've been wanting to do this for years, but I'm pretty sure it will be the last time. The time it is taking, and the cost is ridiculous. I can't believe how many nuts and bolts I've bought.
Not sure what I'll do next. I've got another Harley police bike, a Harley FXE sport and a Honda Monkey bike. I should have put this much effort into the FXE, as a lot of the detailed parts are not covered by trim panels, but hey ho
Gary
On 30/04/2022 at 10:04, kpnuts said:
Amazing work.
Thanks very much
Quick update
Finally started fitting everything into the frame. Still a lot to do, but it's coming along nicely
Engine, gearbox, coil, clutch cable fitted
Oil tank in
Starter solenoid
There are a lot of nuts and bolts on this bike
Battery in. Wiring harness in. Thing under battery is the starter relay. Also the brake light switch and oil pressure switch are wired up. All the oil hoses connected up.
Close up
Rectifier
Battery cover, main circuit breaker and battery vent hose added
Brake pedal, rear wheel and calliper on
Chain and chain guard
Hinged rear fender
Still waiting for the black cherry paint to arrive, so can't paint and final fit the bodywork yet
Thanks for looking
Gary
During a while, I thought you'd taken photos of the real bike in a garage, not of a scale model !
Wonderful job 👍
I've this Tamiya Fat Boy 1:6 in my stash, and you make me want to start it !
CC
That's looking completely convincing - great job.
Nick
Wonderful job 👍
CC
Thank you. That's a big compliment. Definitely start the fat boy!!
