Tamiya 1/12 martini porsche 935
Hi all well I'm back from Scotland so did some work on this today, this is as much detail as the kit supplies I've done a trial fit in the body to see how it looks, I've got more pipework and wiring to add yet.
Added some of the missing pipework, did the first bit of masking, started weathering the underneath and started on the brakes.
And a trial fit of the rear end.
Looking good, kpnuts... just suggest you test fit the engine exhaust through the rear bumper... that was a minor annoyance for me as i hadn't done it and the fit required a bit  of 'encouragement' at final assembly
Hi all added the crossover pipes for the calipers
And added the bleed nipples
And did some work on the suspension
Just need to talk to the blokes at work for the routing of the brake pipes.
Hi all I've added some of the missing details to the fire suppression system.
And added a few other missing details.
On 4/22/2022 at 9:56 PM, DoctorB said:
Strong glue for the suspension... especially the rear... i made the schoolboy error of using tamiya extra thin... just not strong enough
On 4/23/2022 at 11:45 AM, kpnuts said:
I use superglue for most of it.
Nice progress,
Can I ask why it is necessary to use "strong glue" for the rear suspension?
surely if you are gluing the parts "styrene to styrene" the Tamiya extra thin, will "weld" them into place, or are you finding that the Extra thin won't glue painted surfaces sufficiently?
Regards, Keith.
Mpfiend, not 100% sure why it didn’t work so well for me with Tamiya extra thin. One contributing factor is definitely the weight of the finished model. It’s a good point you raise about painting then gluing. It’s so long ago now I can’t remember but it’s quite possible. Point noted for the next 1/12 build.
Added a few decals
And a try of the body
I'm really enjoying this kit, I quite like the look of this car.
OK so masked the boot (that was confusing to say the least)
Did the safety cage.
A trial of the body
Hi all did the drive shafts, I think they look good, but what a pita they were
Got the suspension done.
And added some decals.
Edited by kpnuts
Added the missing CDI units wires.
Added the low tension leads (I know they're not to scale but it's all I've got)
Added the body, getting there.
  • Like 10
