Mike Posted March 29, 2022 Posted March 29, 2022 Martin Baker GRU-7A Ejection Seat for (3DF48001 For Tamiya F-14A) 1:48 3DF via Hobby Colours Martin Baker have been saving pilot lives since just after WWII, due in part to the sad death of Mr Baker during a test flight of one of their prototype aircraft, although they were already investigating the possibility of emergency escape systems for aircraft. By the 70s the seats had progressed markedly from the rudimentary seats that were initially used, and were zero-zero rated, enabling ejection from a stationary aircraft by means of a rocket motor that automatically oriented the seat so that it gained sufficient altitude to allow successful separation and ‘chute deployment, bringing the pilot down safely with a bit of luck and some flat ground. This set is from a company that is new to us, called 3DF with the motto 'Precision to Perfection' from Greece, who have been brought to us by our friends at Hobby Colours who are also Greek. They create their products in 3D and print each one out using high-definition 3D SLA printing, which guarantees exceptional detail and quality, using minimal parts. SLA printing requires the parts to be supported by fine tendrils of resin during printing until after the resin has been fully cured, or you’d end up with a rather saggy-looking product. These fine ‘fingers’ vary in width, and are easy to remove with a pair of nippers, taking care not to damage the part itself, although the resin is surprisingly rugged during handling. Arriving in a cardboard box with a push-out inner tray, there are two seats inside with instructions, cocooned in small sections of bubble-wrap, and attached to their printing base by the aforementioned fingers. The F-14 was a 2-seater, so you have one for each cockpit, and once you have removed the supports you have two parts for each seat of incredible finesse. The main part is the seat, which has all the details moulded-in, including the crew belts, fine hoses and controls for the equipment of the seat. The ejection handles for the headbox are separate, and are mounted on a wedge-shaped sliver that slots easily into the corresponding slot in the front of the headbox. It’s difficult to see the detail with all the supports around them, so I removed one and put it together, which didn’t take very long at all. Because of the slightly translucent resin used and the finesse of the parts, the detail photographs a bit “funny” (technical term), and bear in mind the actual size of the seat when looking at the photo below, so I have duplicated the photo at nearly actual size in the corner to give a more accurate impression. Conclusion A new company to us, and yet they have hit the ground sprinting, with a stunning product that once painted will truly shine. Detail is excellent, and the parts are easy to liberate from the supports with nippers, so even a total novice could handle it. They’re also available in 1:72 and 1:32 scale if you’re interested. Very highly recommended. Review sample courtesy of 1
