Guerre d'Algérie...1/48 De Havilland Vampire Mk.5 , Armée de l’Air
  • Reini78 changed the title to Guerre d'Algérie...1/48 De Havilland Vampire Mk.5 , Armée de l’Air
This looks like it's going to be another very interesting build. Sad to see it that this theme is coming to a close.
Colin
fast progress with the cockpit
the kit comes with two seats, one with molded on seatbelts and one without, if you want to use the included pilot figure or aftermarket belts
51981238473_4354651a66_b.jpgDSC_0001 by grimreaper110, auf Flickr
51981238338_363c1533cf_b.jpgDSC_0002 by grimreaper110, auf Flickr
51980163612_1a4c568b6b_b.jpgDSC_0003 by grimreaper110, auf Flickr
51980163497_8d00d8bfaa_b.jpgDSC_0004 by grimreaper110, auf Flickr
51981237888_88b738c089_b.jpgDSC_0005 by grimreaper110, auf Flickr
51981448999_a2017949bb_b.jpgDSC_0006 by grimreaper110, auf Flickr
the easy times are over...
fit problems with joining upper and lower fuselage halves, had to sand and cut away areas of the side instruments and bulkhead behind the seat
now filling and sanding necessary on the outside of the joints...
51985046990_cc1177462f_b.jpgDSC_0003 by grimreaper110, auf Flickr
51984497546_6d496a21da_b.jpgDSC_0004 by grimreaper110, auf Flickr
51984497326_7c0598ee4b_b.jpgDSC_0005 by grimreaper110, auf Flickr
51984497131_79b750b606_b.jpgDSC_0006 by grimreaper110, auf Flickr
1 hour ago, exdraken said:
Very nice progress  thanks for sharing!!
:thumbsup:
looking forward to this rare, green/ blue? French scheme!
Thanks!
Yes, upperside green, underside blue-grey. The French used their own paints, exact colour tones aren´t known.
Gonna use RLM76 for the underside and most probably a RLM green for the upperside.
2 hours ago, Reini78 said:
Thanks!
great!
something like this, no?
DH100niceweb.jpg?1649235938501
https://www.wikiwand.com/de/De_Havilland_DH.100_Vampire
applied some primer to see where still work is necessary
51990770182_a6abbc671c_b.jpgDSC_0004 by grimreaper110, auf Flickr
The instructions suggest to add 17g noseweight, but to be sure its better to add more. Not much space in the nose to add weight, so put some weight into the tanks too. My dad already glued one tank together before thinking of that. So he drilled a hole and filled some airgun ammo in the tank and sealed the hole again.
51990769727_7bfd696063_b.jpgDSC_0005 by grimreaper110, auf Flickr
51992049459_65d5abce00_b.jpgDSC_0006 by grimreaper110, auf Flickr
The position light covers for the Mk5 are too large, needed to be sanded down.
51992049374_8699172f54_b.jpgDSC_0007 by grimreaper110, auf Flickr
18 hours ago, GiampieroSilvestri said:
Sehr schön!
Womit wird die armee de l'air Sammlung komplettiert?
Gruss
Giampiero
for now, with the already started Thunderbolt
let´s see if i can persuade my dad for more...😁
Vieleicht hilft Euch dies dabei.🙂
Indochina:Curtiss SB2C-5,Fieseler Storch (Morane Saulnier MS505 Criquet),Nakajima Ki-43 Hayabusa,Nakajima A6M2-N,DeHavilland Canada DHC-2,Junkers Ju-52 Toucan,Douglas C-47
Algerien:Douglas A-26,T-28 Fennec,F-100 Super Sabre (von Frankreich aus eingesetzt)
Grüsse
Giampiero
Grüsse
Giampiero
maybe the Ki43 and very maybe the Invader..
When I did a Heller Mistral last year, there were no tail stripes, just the makers marks. Painting by hand was not so hard, all white, mask the middle, one side red, one side blue. A bit of paint mixing to match as best I could, the roundel colours.
This is looking very smart now, well done your Dad. :)
Steve.
14 hours ago, heloman1 said:
Paint is looking good. Shame about the fin decals, maybe a mask and airbrush job would be better?
Colin
Steve.
Masking would have been better and my dad has done a lot and also difficult masking jobs in the past time, but this time he was too lazy....
