elger Posted March 21 Share Posted March 21 Usually my builds have some sort of local connection to the north of The Netherlands but not this one. The Airfix 1/48 Hurricane I has been in my stash for a while. I picked it up on a lovely trip to the Bristol area a few years ago. Could have bought it in a local hobby store or online anywhere but it was a nice little memory from that trip. For a long time I was planning to build JX-B but I was inspired to build a 303 Squadron aircraft, so that's what it's going to be. The kit is nicely detailed from the box. Two things I appreciate from Airfix: one, their modern kits are constructed somewhat the way the real thing was constructed which gives you a nice insight into how these aircraft were conceived. Two, their colour call outs in the instructions are in fact mostly correct. They were correct for the 1/72 B-17 and they're also correct for the Hurricane, as far as I can tell. I added some parts from the Eduard set for this kit. It's been painted with my usual combination of Spanish acrylics. AK, Vallejo, and Mig Ammo. I tried to improve the Eduard instruments panel by adding some colour to the gauges on the right hand side. The instruments panel was sprayed with clear flat (Vallejo's flat varnish thinned with 70% alcohol). Tamiya clear was then finally added to the gauges. Going to be putting the wings together, and then adding it into the fuselage. Thanks for looking as always! 10 Link to comment Share on other sites More sharing options...
elger Posted March 24 Author Share Posted March 24 Cockpit finished, assembled the wings, and getting ready to put the fuselage together: As mentioned in the first post I'm using parts of an Eduard interior set. I think they got the setup of the Sutton harness wrong so I modified it a little. I also added two gauges on the left hand side of the cockpit from spare decals (these are actually from a 1/48 FW-190 instruments panel). Finally a picture of the instruments panel and the cockpit assembly: Gluing the fuselage together next. Thanks for looking! 10 Link to comment Share on other sites More sharing options...
mick Posted March 24 Share Posted March 24 great progress 1 Link to comment Share on other sites More sharing options...
elger Posted March 26 Author Share Posted March 26 the fit of the fuselage and wing is problematic - especially at the front out with the Mr Surfacer 500... 8 Link to comment Share on other sites More sharing options...
bigbadbadge Posted March 26 Share Posted March 26 Great start to this lovely kit, cockpit internals look fantastic. Chris Link to comment Share on other sites More sharing options...
franky boy Posted March 26 Share Posted March 26 Nice work Elger Ive built a couple of these kits and problems there both times. The first time I ended up cutting away some of the interior frame work at the front of the cockpit. Second time wasn’t quite so bad. Next should be ok……? James Link to comment Share on other sites More sharing options...
Tweener Posted March 27 Share Posted March 27 The 1/72 kit shares the step on the underside of the nose, among *many* other fit issues. Link to comment Share on other sites More sharing options...
elger Posted March 27 Author Share Posted March 27 Working on some details. I had bought the Eduard Brassin wheels but I remembered there was some discussion them being the wrong size. Just last week there was a discussion over at Hyperscale discussing the size of Hurricane wheels and the thread concluded they had a diameter of 24,5" which should be about 13,5 mm in 1/48. The kit wheels are in fact a lot bigger (almost 15 mm) and the Eduard wheels are a bit too small (just under 13 mm) but they're closer in size and they look much nicer so I'll go with them. 1 Link to comment Share on other sites More sharing options...
elger Posted April 16 Author Share Posted April 16 It's coming together and I'll be able to start painting it soon I decided to add the radiator now - I painted the interior Sky and I added actuator rods Thanks for looking! 2 Link to comment Share on other sites More sharing options...
elger Posted April 17 Author Share Posted April 17 primer on 5 Link to comment Share on other sites More sharing options...
jackroadkill Posted April 17 Share Posted April 17 @elger, she's coming together very well. 303 Sqn are one of my favourite squadrons; as a child when going to see my grandmother in west London I would always look out for the Polish War Memorial new RAF Northolt. I'll be very interested to see her coming together and will follow the build. I have the same kit in my stash and want to do something interesting with it. 1 Link to comment Share on other sites More sharing options...
elger Posted April 24 Author Share Posted April 24 Paint on. After struggling to make my own mix with Mig Ammo paints I went with Vallejo Yellow Olive and English Uniform for Dark Green and Dark Earth. I did use Mig Ammo's Sky for the underside: Next up: decals. Thanks for looking! 5 Link to comment Share on other sites More sharing options...
elger Posted May 1 Author Share Posted May 1 Decals on and I've already done a bit of weathering. Next up final weathering and finishing. Thanks for looking! 9 Link to comment Share on other sites More sharing options...
elger Posted May 15 Author Share Posted May 15 time for the final bits 'n bobs like these thingies should be finished soon! 3 Link to comment Share on other sites More sharing options...
elger Posted May 21 Author Share Posted May 21 Finished! RFI thread here: 5 Link to comment Share on other sites More sharing options...
