10 hours ago, Jasper dog said:
A start has been made on the 6 suspension units, still more work to do, and the infamous Asuka rubber sheet ready to be cut down.
Darryl it's best to replace that rubber sheet with plastic card, that's what I do and the newer Asuka kits provide hard plastic replacements.  The 'working' suspension with the rubber sheet and vinyl tracks end up with a rocking chair effect, front and rear wheels lifted.  Glad you have managed to get started.  :happy:
Following advice from @Retired Bob and @Longbow (thanks chaps) I've replaced the kit supplied rubber sheet with plastic. The kit suggests using two rectangles of rubber, using my desperately accurate measuring device, shatterproof 12inch ruler, I reckon the rubber is approximately 1.456493mm thick, roughly. :whistle:
Sheet of plastic card cut down into suitably sized rectangles ready to pack out the suspension units.
Looks something like this one fitted...
So far four little motorbikes completed!
At least once I've got the suspensions done I can crack on with the build proper, that said its still better than interleaved Tiger roadwheels! :frantic:
Darryl
  • Like 10
7 hours ago, Longbow said:
12 inches, Ehh…
Nice…. 🤣👍
Nudge nudge, wink wink....! :giggle:
  • Haha 2
10 hours ago, Longbow said:
12 inches, Ehh…
Nice…. 🤣👍
I have steel ones, 6 inches and 12 inches but I don't use them as a rule. :facepalm:
  • Haha 3
Ba-Dum... Tishhhh....
I see what you did there ;)
Your coat's in the closet, pick it up on your way out....
  • Haha 2
1 hour ago, Bertie Psmith said:
What's the rubber sheet for? Did I miss something?
The foam rubber sheet was Taska/Asuka's way of having some movement in the suspension units but it isn't firm enough, if the rubber band tracks are used the suspension is lifted at the front and rear giving a rocking chair effect, not good look to your Sherman.
Another one that looked like a great ides on the CAD screen...
  • Haha 2
We had a teacher with a built up shoe, wonder if he had the same affliction....that extra 6" of steel is bound to make its presence felt somewhere!
4 hours ago, Retired Bob said:
 if the rubber band tracks are used....
Yeah, as if, what sort of lowlife self respecting modeller would take that route....:whistle:
12 hours ago, edjbartos said:
The suspensions are looking good Darryl, nice work
Ed
Thanks Ed, very kind of you!
All suspension units complete along with idlers and drive wheels.
And the flat pack lower hull!
  • Like 9
 On newer Tasca/Asuka kits they supply both the silly foam pads, plus some plastic spacers on the sprue, but I've got a sneaky feeling that they don't call it out in the instructions (not sure) but it's always worth checking the sprues for kit supplied spacer parts.
 And that's a damn fine Tasca Hull ;)
Nice work on the lower hull and suspension units Darryl, started on the tracks yet...:whistle:
No sweat, don't know what these drama queens complain about....
Strong and articulated....:whistle:
  • Haha 4
Coming along nicely Darryl, the suspension units do look good, as for the tracks you did a good job on those !  😀
Ed
Looks good ... so far.
Great to see more progress Darryl and well done with the tracks! :thumbsup:
Kind regards,
Stix
The "so far" always such a vote of confidence.....
  • Haha 2
Lower hull complete with back panel...
Replaced the flat 2d pe parts for the air cleaner clamps with plastic rod.
Transmission cover assembled and dry fitted to the hull.
Anyone know what the row of little lugs are or are for on the bottom edge of the hull?
That's all for now folks....
Darryl
That’s delicate work old chum. Well done.
Hi Darryl. The lower hull and your detailing are looking very impressive. Lovely job.
Kind regards,
Stix
Kind regards,
Stix
Thanks, certainly not the neatest, most precise or accurate you'll see on BM but it'll do the job once tucked up under the upper hull.
Much appreciated, as ever
Darryl
