Mike Posted March 19, 2022 Posted March 19, 2022 F/A-18F Super Hornet Update Sets (for Meng LS-013) 1:48 Eduard Meng’s second Super Hornet of at least three is the two-seat -F, and it’s another great kit. Eduard's new range of sets are here to improve on the kit detail in the usual modular manner. Get what you want for the areas you want to be more of a focal point. As usual with Eduard's Photo-Etch (PE) and Mask sets, they arrive in a flat resealable package, with a white backing card protecting the contents and the instructions that are sandwiched between. Upgrade Set (491253) Two frets are included, one nickel-plated and pre-painted, the other bare brass. A complete set of new layered instrument panels with layered MFD panels, sidewalls and side consoles with added levers for both cockpits are in full colour, with a partial floor skin and rudder pedals for the front; sidewall skins; HUD with acetate film glazing; rear deck details; windscreen hoop insert and canopy interior details that include hooks and rear-view mirrors for the interior. Externally, there are hinge parts for many of the gear bay doors plus a complete laminated replacement of the largest nose bay door; a highly detailed crew access ladder with scale-thickness doors; hosing for the main and nose gear legs; a box for inside the nose gear bay; a full set of skins for the pylon contact-points, which should come in handy, as other than fuel and practice rounds modern jets often fly with empty pylons. Seatbelts STEEL (FE1254) These belts are Photo-Etch (PE) steel, and because of their strength they can be etched from thinner material, which improves realism and flexibility in one sitting. Coupled with the new painting method that adds perceived extra depth to the buckles and other furniture by shading, they are more realistic looking and will drape better than regular brass PE. As well as the two sets of crew belts, you also get a set of the pull-handles between the pilot's knees that gets him out of there in case of an emergency, the anti-flail leg straps, and a number of stencil placards for the sides of the headboxes and seats. Masks (EX840) Supplied on a sheet of yellow kabuki tape, these pre-cut masks supply you with a full set of masks for the canopy, with compound curved handled by using frame hugging masks, while the highly curved gaps are in-filled with either liquid mask or offcuts from the background tape. In addition, you get a set of hub/tyre masks for all the wheels, allowing you to cut the demarcation perfectly with little effort. Masks Tface (EX841) Supplied on two sheets of yellow kabuki tape, these pre-cut masks supply you with everything above, but also give you another set of canopy masks tailored to fit the interior of the glazing so that you can paint the interior and give your model that extra bit of realism. Review sample courtesy of
