AliGauld Posted October 15, 2022 Share Posted October 15, 2022 Ach all my hopes dashed but you'll get that all sorted. Of that I have no doubt. Nice progress. Cheers, Alistair 2 Link to comment Share on other sites More sharing options...
giemme Posted October 16, 2022 Share Posted October 16, 2022 Gloop sounds like a nice idea, Simon Ciao 2 Link to comment Share on other sites More sharing options...
Spookytooth Posted October 16, 2022 Author Share Posted October 16, 2022 Thanks @mark.au, @giemme, @AliGauld, @Hamden, @elger, @Biggles87 and @Dr. Quack. Filler and gloop. And after sanding... Still work to be done there, but not much. Still bits to do here as well, but getting there. You all have a great day. Stay safe. Simon. 10 Link to comment Share on other sites More sharing options...
giemme Posted October 16, 2022 Share Posted October 16, 2022 A bit more sanding and you'll be there, Simon Ciao 1 Link to comment Share on other sites More sharing options...
Spookytooth Posted October 16, 2022 Author Share Posted October 16, 2022 1 hour ago, giemme said: A bit more sanding and you'll be there, Simon Ciao Well, we will find out tomorrow if I get chance to do some spraying... Just to say that things don`t look that bad now. Simon. 2 Link to comment Share on other sites More sharing options...
Spookytooth Posted December 13, 2022 Author Share Posted December 13, 2022 Hi all, @mark.au, @giemme, @Biggles87, @Dr. Quack, @Hamden, @elger and @AliGauld. Well, it`s been nearly two months since I last posted anything on this build and I apologise, life got in the way. But today I found chance to continue with her. Some re-scribing done. Plus the exhaust mounts fitted. Undersides prepped for prime, again. Hopefully I will be able to make some more progress over the festive period. Anyhow, you all keep warm or cool wherever you are. Stay safe. Simon. 11 Link to comment Share on other sites More sharing options...
AliGauld Posted December 13, 2022 Share Posted December 13, 2022 All looking good from here, Simon. No need for any apologies. Life stuff happens and is usually more important than plastic bothering. Cheers, Alistair 1 Link to comment Share on other sites More sharing options...
giemme Posted December 13, 2022 Share Posted December 13, 2022 Good to see you're back at this, Simon Ciao 1 Link to comment Share on other sites More sharing options...
corsaircorp Posted December 13, 2022 Share Posted December 13, 2022 Nice recovery Simon !! Go on, you're almost there.... These Mustangs are addictive, be warned..... Well done Man !! Sincerely. CC 1 Link to comment Share on other sites More sharing options...
Spookytooth Posted December 15, 2022 Author Share Posted December 15, 2022 On 13/12/2022 at 19:30, AliGauld said: All looking good from here, Simon. No need for any apologies. Life stuff happens and is usually more important than plastic bothering. Cheers, Alistair On 13/12/2022 at 19:35, giemme said: Good to see you're back at this, Simon Ciao On 13/12/2022 at 21:41, corsaircorp said: Nice recovery Simon !! Go on, you're almost there.... These Mustangs are addictive, be warned..... Well done Man !! Sincerely. CC Yes lads, but see below. Thanks @Biggles87, @elger, @Hamden, @Dr. Quack, @franky boy, And @mark.au. Right, yesterday I decided to dry fit some of the external parts. The intake lip on the underside went well, after a bit of cleaning up. Next up this bit. This is where the fun starts. It should of been fitted while gluing the two halves together. The arrow left to where it is suppose to go, the other arrow points to the seam, join line which has cracked open. And this bit fits on top of it. So, now for some serious deliberations on how to fix it. Well you all keep warm Stay safe. Simon. 8 Link to comment Share on other sites More sharing options...
AliGauld Posted December 15, 2022 Share Posted December 15, 2022 Good luck with the retrofit Simon. I feel your pain. Cheers, Alistair 1 Link to comment Share on other sites More sharing options...
corsaircorp Posted December 15, 2022 Share Posted December 15, 2022 3 hours ago, Spookytooth said: Yes lads, but see below. Thanks @Biggles87, @elger, @Hamden, @Dr. Quack, @franky boy, And @mark.au. Right, yesterday I decided to dry fit some of the external parts. The intake lip on the underside went well, after a bit of cleaning up. Next up this bit. This is where the fun starts. It should of been fitted while gluing the two halves together. The arrow left to where it is suppose to go, the other arrow points to the seam, join line which has cracked open. And this bit fits on top of it. So, now for some serious deliberations on how to fix it. Well you all keep warm Stay safe. Simon. You're not alone... I forgot one too on my first Eduard kit..... For the second, I was aware.... Sincerely. CC 1 Link to comment Share on other sites More sharing options...
The Spadgent Posted December 16, 2022 Share Posted December 16, 2022 Glad to see this back up and running dear boy. Good luck fitting that awkward bit. Johnny 3 Link to comment Share on other sites More sharing options...
Spookytooth Posted December 24, 2022 Author Share Posted December 24, 2022 On 15/12/2022 at 14:54, AliGauld said: Good luck with the retrofit Simon. I feel your pain. Cheers, Alistair On 15/12/2022 at 17:55, corsaircorp said: You're not alone... I forgot one too on my first Eduard kit..... For the second, I was aware.... Sincerely. CC On 16/12/2022 at 06:18, The Spadgent said: Glad to see this back up and running dear boy. Good luck fitting that awkward bit. Johnny Thanks @giemme, @Dr. Quack, @Hamden, @elger, @cobraleader. Thanks lads, it took just few minutes with a file. I wiped some TET around the joins, also along the cracked seam then taped. I am going to leave that to set before trying anything else foolish. You all stay safe. Simon. 9 Link to comment Share on other sites More sharing options...
Biggles87 Posted December 24, 2022 Share Posted December 24, 2022 I always seem to have trouble with Mustang fuselage undersides too, I’m sure you’ll sort it. Have a good Christmas. John 1 Link to comment Share on other sites More sharing options...
Spookytooth Posted December 24, 2022 Author Share Posted December 24, 2022 8 minutes ago, Biggles87 said: I always seem to have trouble with Mustang fuselage undersides too, I’m sure you’ll sort it. Have a good Christmas. John And you good sir. Simon. Link to comment Share on other sites More sharing options...
AliGauld Posted December 24, 2022 Share Posted December 24, 2022 A fantastic save and result Simon, Nicely played. Looking forward to more. Cheers, Alistair 1 Link to comment Share on other sites More sharing options...
corsaircorp Posted December 25, 2022 Share Posted December 25, 2022 Well done Simon !! It now look as nothing wrong happened..... Don't you forget.... Don't ask... Don't tell !! Carry on with the Pony, you're on the right way !! Happy Christmas to you and yours !! Sincerely. CC 3 Link to comment Share on other sites More sharing options...
Spookytooth Posted December 25, 2022 Author Share Posted December 25, 2022 2 minutes ago, corsaircorp said: Well done Simon !! It now look as nothing wrong happened..... Con't you forget.... Don't ask... Don't tell !! Carry on with the Pony, you're on the right way !! Happy Christmas to you and yours !! Sincerely. CC Cheers, and to you and your family . Simon. 1 Link to comment Share on other sites More sharing options...
Spookytooth Posted December 25, 2022 Author Share Posted December 25, 2022 Thanks @giemme, @corsaircorp, @Hamden, @Memphis, @AliGauld, @Biggles87, and @elger. Well we hope that you all had a great Xmas day. We did, and found time to do a bit as well. Added the gunsight to the coaming then painted (No Pics, sorry). Then added the IP panel. Again, I am going to leave that to set overnight. I will see what to do tomorrow. Stay safe. Simon. 8 Link to comment Share on other sites More sharing options...
Memphis Posted December 25, 2022 Share Posted December 25, 2022 1 hour ago, Spookytooth said: Thanks @giemme, @corsaircorp, @Hamden, @Memphis, @AliGauld, @Biggles87, and @elger. Well we hope that you all had a great Xmas day. We did, and found time to do a bit as well. Thank you for your congratulations. Although we don't celebrate Christmas, my youngest daughter and I made a bullfinch for our Christmas tree today. 1 hour ago, Spookytooth said: Then added the IP panel. Great work. 3 Link to comment Share on other sites More sharing options...
AliGauld Posted December 25, 2022 Share Posted December 25, 2022 IP is looking really good Simon, Looking forward to more. Cheers, Alistair 1 Link to comment Share on other sites More sharing options...
corsaircorp Posted December 26, 2022 Share Posted December 26, 2022 Such a nice little bird !! Congrats !! This IP is top notch !! CC 1 Link to comment Share on other sites More sharing options...
giemme Posted December 26, 2022 Share Posted December 26, 2022 I concur with the others, nice IP Simon! Ciao 1 Link to comment Share on other sites More sharing options...
Spookytooth Posted December 26, 2022 Author Share Posted December 26, 2022 15 hours ago, Memphis said: Thank you for your congratulations. Although we don't celebrate Christmas, my youngest daughter and I made a bullfinch for our Christmas tree today. Great work. Lovely handicraft work there sir. 14 hours ago, AliGauld said: IP is looking really good Simon, Looking forward to more. Cheers, Alistair 11 hours ago, corsaircorp said: Such a nice little bird !! Congrats !! This IP is top notch !! CC 2 hours ago, giemme said: I concur with the others, nice IP Simon! Ciao Thanks lads, take a good look at it now, once fitted it all but disappears. Thanks @cobraleader and @Biggles87. Well things have progressed at a snails pace LOL IP fitted (Dry). The windscreen dry fitted. A bit of work needed there. And the little flap on the underside fitted. She is gradually coming together.... Stay safe. Simon. 9 Link to comment Share on other sites More sharing options...
