tonyot Posted March 16, 2022 Share Posted March 16, 2022 Hiya Folks,..... I might jump in with this one if it is OK,..... although the interior parts are mostly pre painted, I have otherwise not touched it yet; I also have this Revell kit combined with the CMR conversion set,.... although it may be too far gone as I recently closed the fuselage halves,.... I may just utilise some decals? ; Although the CMR conversion set was designed for the Revell kit,.... the Mk.II style resin bomb bay doors are too short and not deep enough, so will need some work,...... here they are compared with the Revell bomb doors and the separate Airfix doors on the right hand side. Cheers Tony 6 Link to comment Share on other sites More sharing options...
dogsbody Posted March 16, 2022 Share Posted March 16, 2022 Chair pulled up and coffee brewing. Let the show begin! Chris 1 Link to comment Share on other sites More sharing options...
Ravnos Posted March 16, 2022 Share Posted March 16, 2022 Ooo, I've got the Airfix kit on my shelf so will be watching with interest 2 Link to comment Share on other sites More sharing options...
Christer A Posted March 17, 2022 Share Posted March 17, 2022 What Ravnos said goes for me too! That Lanc mkII in the stash looks mighty tempting, Link to comment Share on other sites More sharing options...
Adam Poultney Posted March 18, 2022 Share Posted March 18, 2022 On 16/03/2022 at 14:05, tonyot said: I also have this Revell kit combined with the CMR conversion set,.... although it may be too far gone as I recently closed the fuselage halves,.... I may just utilise some decals? ; Ehhhh looks about 25% done to me, if you want to add this to the group build go for it. 1 Link to comment Share on other sites More sharing options...
tonyot Posted March 18, 2022 Author Share Posted March 18, 2022 36 minutes ago, Adam Poultney said: Ehhhh looks about 25% done to me, if you want to add this to the group build go for it. Thanks Adam. Link to comment Share on other sites More sharing options...
tonyot Posted March 18, 2022 Author Share Posted March 18, 2022 Well I got a full day in today, so with a box set on the telly and a brew,...... I started off with the cockpit and interior; All I added was a set of etched brass seat straps on the pilots seat; Then with all of the windows added,..... and then masked off (as it was easier to mask them now, without the danger of poking them inside later),..... the fuselage halves were joined and the wheel well construction began. I also drilled out the windows for the roof escape hatches plus the hole for the camera hatch under the nose; Then the upper wing halves were attached,..... with a fresh brew added to the table!; The the lower wing halves were added too; Followed by the tail feathers,... and the fairing around the mid upper gun position; Next onto the engines and nacelles,...... the propeller hubs are beautifully detailed and it will be a shame to hide them underneath spinners,..... although some Mk.II`s did fly without spinners; Nacelles fitted to the model; Then on with the engines and the cowlings, with their intakes and exhausts; And the engines and cowlings test fitted to the model,..... note the lack of filler (so far),...... this kit is engineered beautifully, although I may fill in some of the panel lines?; So that is it for now,...... sanding next after it has been left for a day or so for the glue to dry properly. As I said, I may add some filler to some panel lines, especially those under the cockpit area. As with the Merlin engined boxing,....l can highly recommend this kit, Cheers Tony 3 Link to comment Share on other sites More sharing options...
tonyot Posted March 18, 2022 Author Share Posted March 18, 2022 And here are a few reference pics, including some Lanc`s which are the subject of decal options available in both kits; And they were used in various test roles into the post war years too; And a generic Lanc pic, a useful top view of the cockpit in the IWM London; Cheers Tony, 5 Link to comment Share on other sites More sharing options...
Pete in Lincs Posted March 18, 2022 Share Posted March 18, 2022 On 3/16/2022 at 6:16 PM, dogsbody said: Chair pulled up and coffee brewing. With the speed that he's building this at, I'll be in the garden digging an Anderson shelter! Makes a nice change to see a Mark 2. Much as I love the sound of four Merlins together... That's a great set of pictures. I wonder if the Metrovic engined version will inspire @Head in the clouds. 1 Link to comment Share on other sites More sharing options...
Head in the clouds. Posted March 18, 2022 Share Posted March 18, 2022 10 minutes ago, Pete in Lincs said: I wonder if the Metrovic engined version will inspire @Head in the clouds. You bet, already got the Airfix Mk2 on the shelf ready and waiting.... 1 1 Link to comment Share on other sites More sharing options...
Pete in Lincs Posted March 18, 2022 Share Posted March 18, 2022 10 minutes ago, Head in the clouds. said: You bet, already got the Airfix Mk2 on the shelf ready and waiting.. I'll look forward to seeing the build! 2 Link to comment Share on other sites More sharing options...
dogsbody Posted March 18, 2022 Share Posted March 18, 2022 A few more B.II photos, just because. Chris 4 Link to comment Share on other sites More sharing options...
tonyot Posted March 18, 2022 Author Share Posted March 18, 2022 1 hour ago, dogsbody said: A few more B.II photos, just because. Chris Great pics Chris,..... I do like the one where the exhaust ring has graffitti scrored into the paint,..... or delivery instruction for a spare part? 2 Link to comment Share on other sites More sharing options...
Pete in Lincs Posted March 19, 2022 Share Posted March 19, 2022 If you look closely most of them have something on there. Written in chalk perhaps? On the first one I can make out 24 and PO. Port Outer? 1 Link to comment Share on other sites More sharing options...
