70ft 9in British Power Boat Company MGB 1942 1:48th Scale
Steve - that's one of the best pics I've seen of a Carley float.
It's really beginning to look like a properly used Coastal Forces gunboat
Rob
Thanks Rob,
For completeness, here are the other two pictures I took.  Not sure they add much, but maybe worth posting nonetheless.  If I ever built at a larger scale, I would definitely have a go at this level of detail
IMG_3092
IMG_3094
Steve
Odd jobs
Canvas finished off with a coat of B15, love the wrinkled effect
DSCN2640
Then cut into sections and crammed into the deck bin.  Checking the pictures, this really is what they looked like, I guess they didn't bother to be too neat, wet canvas is a bugger to fold anyway
DSCN2641
Then I turned my attention to the mast and rigging (I hate knots...)...
First, painting the ensign, same as I have described previously using Tulip fabric paint and fine linen (from a cheap handkerchief, £10 buys enough handkerchiefs for a lifetime of flags)..  This flag is 4ft by 2ft so quite small
DSCN2642
After attaching the hoist, the flag is soaked in weak PVA and hung to set its shape.  This small hand clamp seems to be just right for achieving a realistic shape (I may have mentioned before my dislike of flags that stick out as though they were starched  :doh: ).  Plus the curled up shape has the added benefit of covering up any painting mistakes👍
DSCN2644
I made up the signal flag blocks from a scrap of 4 mm x 1.5mm walnut with the end sanded down to around 1.8 mm x 1.  The ropes are then tied in place before the each length is cut off, sanded flat and drilled out 0.5mm for the hoist line.  Before drilling, I rolled the blocks in cyno to harden them and darken the wood.  Helps prevent the walnut splintering when drilled.  This is all tiny stuff for me..  Everyone on this forum is better at rigging than I am, even the ones who have never tried it......:rofl:
Very unhelpful out of focus picture that doesn't really help...
DSCN2643
Finally, secured to the signal yard (from 1.2 mm brass wire, tapered in the lathe).  The yard stay lines and of course the main mast stays (in wire rope) will be added when it is finally fitted for good, just about the last activity
DSCN2646
I guess it'll do.  Note I've also glazed the windscreen, probably needs a little more sanding flat on the top edge.  The glazing sticks above the metal frame
Steve
  • Like 10
The last item of brass, the anchor.  This is the 5th one of these I've made so getting used to it now.
Articulated with 16BA nuts and screws 👍
DSCN2655
The revised transfers are on the post so hopefully, I can get them on and varnish ahead of rigging, nearly done now :phew:
Steve
  • Like 9
Well, all builds come to an end and this is the end of this build thread.  The model will be back with an RFI thread once the base and stand is made.
Today I finished off the rigging.  The wire-rope handrails are made from SoftFlex Softtouch 7 strand thread sold for threading beads.  The Very Fine size has a diameter of 0.25mm and is used for the stays and Fine (diameter 0.36 mm) was used for the rear handrails.  These are finished with loops that are clenched up with thin wall brass tube.  0.8 mm for the very fine and 1 mm for the fine.  In the past I've struggled cutting these thin walled tubes (0.1mm wall thickness) but this time I made this cutting jig and it worked a treat with the piercing saw
DSCN2657
The model still needs a few more rope coils, some helmets, a bucket and my signature sailor to allow people to understand the scale, but for the basic vessel build, it's done
DSCN2658
The forecastle has the emergency tow rope coiled up and held in the waterline bow fitting.  This rope was made up on my ropewalk, described in an earlier thread.  The anchor is stowed on the starboard ahead of the breakwater with a length of ground chain and a rope coil.
DSCN2659
It's all had a coat of matt varnish to level up the finish.  Dirty I know, but hopefully it is reminiscent of a working boat in wartime
DSCN2660
I'll be back soon with more progress on the Räumboote thread but meanwhile many thanks for your interest, comments, advice and likes.
I hope I've managed to impart some useful information in between my ramblings.
Cheers and thanks again
Steve
  • Like 10
I might not have made many comments during this build, but I’ve watched in awe as you made parts I can only dream of making.
To watch a true craftsman at work, is always a joy.
The end result is superb and I shall definitely be looking out for the next one.
:worthy:
Jon
Steve, I thank you for the pleasure I got watching this build. The ship turned out great!
Your builds are also a great tutorial of different ways to work with natural materials.
Thanks!
Dmitriy
Thanks Jon, I'll be back soon
Thanks Dmitriy, I will continue to champion traditional methods, it's all I know how to do
1 hour ago, Bertie McBoatface said:
That was most interesting, informative, entertaining
Thanks Bertie, I really enjoy writing this stuff up and if people find it entertaining, my job is done
It's no real surprise that this has turned out beautifully. Your approach throughout had guaranteed that. Thanks for an interesting thread and a beautiful model!
(And I'm not even a maritime guy!)
Ian
On 31/07/2022 at 22:01, Jerry L said:
I have been a lurker during your build
Thanks Jerry, next thread ask questions, I want to make this type of modelling more accessible and will happily explain anything at great and tedious length....:book:
Thanks Ian, there is always time to rectify this character flaw :rofl:
4 hours ago, steve5 said:
it's just a credit to you
Thanks Steve, next time the painting will be better, I promise
3 hours ago, stevehnz said:
catches the look of them exactly right to my mind
Thanks Steve, I'll take that 👍
  • 3 weeks later...
Wow, Steve what a magnificent build. I've just trolled through all eight pages at one sitting! The hull construction reminded me of a couple of model boats I had built in my teens. all hand cut formers in those days, no laser cutting! Excellent work with the planking, veneer has many uses in the modelling game.
I do like the deck parts and the brass guns, excellent work, and the drooping flag, superb.
Colin
Thanks Colin, I've also done it by hand many times, but the laser cutting I'm afraid is just better and more accurate than I can do these days.  In my build treads< I'm hoping to get people away from plastic kits and open up the world of possibilities scratchbuilding presents.  BTW, that's the first time I've used veneer on a hull, I'll use it again, so quick and simple
Steve
