Mike Posted March 1, 2022 Share Posted March 1, 2022 USAAF Pilots 1944-45 Paint Set (3012) ICM via Hannants Ltd ICM have long been a plastic model company that is well-known to most of us, but until recently they haven’t had their own paint range, which has now changed. There are 77 acrylic colours in the initial collection, plus three varnishes in matt, satin and gloss, all in the same 12ml plastic bottles. A conversion chart is available that will give you equivalents in AK, Tamiya, Humbrol, Gunze, Testors, RLM, RAL, FS, Revell, AK Real Color, and even Citadel paints, although there aren’t many direct cross-overs in that last one. The paint is undiluted, so will need thinning by between 40-60% with water or acrylic thinner for use with an airbrush, and they naturally have a semi-gloss finish that can be adjusted later by the use of varnishes, and are waterproof when dry like most acrylics. During my testing I used Ultimate Thinners, my go-to thinners for any acrylic paint, which helps keep the number of large bottles in my spray booth to a minimum. The paint comes out of the bottle quite thick and viscous, so it’s possible you’ll have to dilute for serious brush painting use although I used it neat during testing, so a small bottle will go a long way in either case. It sprays well when diluted, and like a lot of acrylics a light coat is best initially, then followed quickly after by heavier coats until you have the coverage you require. It dries quite quickly, and is touch-dry in 5-10 minutes in those long-gone summery 20-23oc temperatures, unless you’re in the antipodes as I write this. I have used them to create a number of spray-out cards and spoons for other sets in the range, and they both spray and brush very well, with little issue other than my inexpert application by brush. We recently reviewed a 1:32 figure set from ICM called “A Photo to Remember”, which depicted three pilots posing for a portrait in front of their aircraft, which you can read here. This set is intended to complement these figures, and it includes the following colours, but it would be useful to add white if you don’t already have it for lightening the colours to create many other shades: 1002 Black 1008 Deep Brown 1052 Hull Red 1068 Olive Green 1044 Basic Skin Tone 1059 Green Ochre On the rear of the box are drawings of the figures that are identical to the set mentioned above, with colour call-outs in their own codes, and suggests that they may also be useful for additional ICM kits, such as 1:48 USAF Pilots & Groundcrew 48088, 1:32 A Photo to Remember 32116 and 1:32 USAF Pilots 1941-45 32104. That’s just a few ICM models, but I doubt they’d complain if you used them in conjunction with other manufacturers’ kits. Highly recommended. Available in the UK from importers H G Hannants Ltd. Review sample courtesy of Link to comment Share on other sites More sharing options...
