Mike Posted February 26, 2022 Posted February 26, 2022 Allied Mine Detection Equipment (35390) 1:35 MiniArt via Creative Models Ltd Mines have been an unfortunate fact of war for many years, as a way to prevent the enemy encroaching on your territory, and giving you a loud bang and a bright flash as a tip-off if this happens at night. Minefields became a standard military practice during WWI and WWII, and only recently has the laying of mines been frowned upon by many countries due to the damage inflicted on hapless civilians once the combatants have gone home. During WWII there were many methods available to the Allies to counter German minefields, including manually searching for them using some kind of prod or bayonet, but the more efficient method was the use of electronic devices that could detect the presence of metallic objects beneath them. There were several types, but all used a coil, sometimes within a round or oval plate-like surround, held by the operator on a long broom handle-like stale, with a wire leading eventually to a pair of headphones that would alert the operator to an object beneath the ground with an electronic tone. If it wasn’t a rush-job, they would mark the mine with a small flag and move on, otherwise the tools would come out to extract the mine there and then, which although it was much less likely to explode because you were aware of its presence, it was still a very difficult task that could result in you becoming a victim. Of course, the best and safest solution was the flail-tank, but these units were often overwhelmed by requests for their presence, particularly soon after D-Day. The set arrives in a shrink-wrapped end-opening figure box, and inside are eight sprues in grey styrene, and a small decal sheet with some signs as well as stencils for equipment. As is common with this type of set, the instructions and painting guide are on the rear of the box, showing what’s included and giving painting instructions linked to a colour chart at the bottom, giving colour swatches, Vallejo, Mr Color, AK RealColor, Mission Models, AMMO, Tamiya and colour names. You can build the following from the parts within: 4 x Different mine detector handsets with headsets & electronics pouches 2 x Signposts on stakes 2 x triangular mine pins 2 x bayonet style spike 2 x walking stick sized spike 2 x shovels 2 x US electronics pouches 2 x US tapering pouches 3 x Teller Mine 43 2 x Teller Mine 35 The instructions show the cables and handles on the mines as parts that you will need to scratch build from your own stock of wire, but the pictures are enough to give you the information you need. In addition, there are decals for small square flags that you will also need to scratch build for yourself, painting the flags yellow and applying the decals over the top. Two red mine signs on stakes, four small white Ms for the triangular flags, curved stencils for the recovered mines, and nine of the afore mentioned small black Danger signs. Some US Army symbols for the pouches and white stencils for one of the detector plates finish off the small decal sheet, which is printed by DecoGraph to their usual high standards. As usual with MiniArt kits their sculpting is exceptional with crisp detail and sensible parts breakdown, plus loads of extra parts, although a little wire will be needed to make the most of that detail for the wiring, flags, handles and one of the headsets that are joined together with a wire loop. Conclusion A nice set of highly detailed equipment to add to your next project, whether it is stowed aboard a vehicle in anticipation of use, or on the scene of a minefield that needs clearing. Highly recommended. Review sample courtesy of 1
