Rick Martens Posted February 24, 2022 Share Posted February 24, 2022 Although I usually build aeroplanes, this will be my first ship. I really like the looks of the Iowa class ships and I came across the USS Iowa 1/200 scale from Trumpeteer. Big one. I collected some PE designed for the Missouri but I can use a lot on the Iowa and got some books for reference. Well anyway I have been on and off this build for almost one year. This is how I want it to be when finished, only with the straight lines, I am not sure wether I can duplicate the feathered lines. And it is big The only part that is finished, number 1 turret, and the easiest one to build.... The PE and paperwork I have a couple of questions to begin with. What sort of paint do I use. The scheme is a measure 32 design 1B but I cannot seem to find which brand has the paint to use for this or which one to use. To make thing less static I want to raise the number 2 turret guns and turn the gun like it is now. But I run into troubles with the blast bags. On no1 turret I used alufoil to make it look a bit more like a blastbag, but when the guns are up the kit part is useless. Anyone has an idea how to solve this? That is all for now. I am a terrible slow builder and quite easily distracted so this will take a couple of years I guess. Cheers Rick. 11 Link to comment Share on other sites More sharing options...
foeth Posted February 24, 2022 Share Posted February 24, 2022 There's a lengthy tread at ModelWarships where Iowa's camo(u)flage pattern was discussed recently. Apparently the camo pattern was updated in April 1944 so you don't have to add that feathering (which looks terrible IMO) 1 Link to comment Share on other sites More sharing options...
Faraway Posted February 24, 2022 Share Posted February 24, 2022 4 hours ago, Rick Martens said: What sort of paint do I use. Rick. I will strongly recommend https://www.sovereignhobbies.co.uk/ These are the most accurate colours you will find. This looks an interesting build, way out of my price range and SIZE range, I don’t think my work bench is big enough. I look forward to your progress, no matter how fast or slow. Jon Link to comment Share on other sites More sharing options...
johndon Posted February 24, 2022 Share Posted February 24, 2022 Good to see someone else building this beast, I've been working on mine, on and off (mostly off) for 5 years now... Link to comment Share on other sites More sharing options...
Alan P Posted February 24, 2022 Share Posted February 24, 2022 Unless you're stuck on doing the MS32 scheme, I would take @foeth advice and do the smart MS22 repaint, you also get to do the final AA and radar fit which is busier on such a large 1/200 canvas. 1 Link to comment Share on other sites More sharing options...
Alan P Posted February 24, 2022 Share Posted February 24, 2022 8 hours ago, Rick Martens said: To make thing less static I want to raise the number 2 turret guns and turn the gun like it is now. But I run into troubles with the blast bags. On no1 turret I used alufoil to make it look a bit more like a blastbag, but when the guns are up the kit part is useless. Anyone has an idea how to solve this? On my 1/350 New Jersey I used a Dremel to carve out the kit blast bag to make it the correct shape: Might be an option, but I don't know the Trumpeter kit 🤔 2 Link to comment Share on other sites More sharing options...
Rich75 Posted February 24, 2022 Share Posted February 24, 2022 Hi there, I would also recommend Sovereign Hobbies for your colours, you just need to know which colours make the scheme you want, look forward to seeing how you get on I do like the Iowa class BB's.... 1 Link to comment Share on other sites More sharing options...
johndon Posted February 24, 2022 Share Posted February 24, 2022 (edited) 9 hours ago, Rick Martens said: The only part that is finished, number 1 turret, and the easiest one to build.... One small point, it's not finished, as you've not got the ladders on the side of the turret fitted. 🙂 Edited February 24, 2022 by johndon Link to comment Share on other sites More sharing options...
Whitewolf Posted February 24, 2022 Share Posted February 24, 2022 2 hours ago, Alan P said: Unless you're stuck on doing the MS32 scheme, I would take @foeth advice and do the smart MS22 repaint, you also get to do the final AA and radar fit which is busier on such a large 1/200 canvas. The only problem with that is the kit depicts Iowa as built with open bridge, she was i believe painted in MS22 after a refit during which she was fitted with the later fully enclosed bridge.. . 1 1 Link to comment Share on other sites More sharing options...
Alan P Posted February 24, 2022 Share Posted February 24, 2022 11 minutes ago, Whitewolf said: The only problem with that is the kit depicts Iowa as built with open bridge, she was i believe painted in MS22 after a refit during which she was fitted with the later fully enclosed bridge.. . Ah, really? Like I said, I'm not familiar with the kit...that's a shame! 1 Link to comment Share on other sites More sharing options...
Rick Martens Posted February 25, 2022 Author Share Posted February 25, 2022 20 hours ago, foeth said: There's a lengthy tread at ModelWarships where Iowa's camo(u)flage pattern was discussed recently. Apparently the camo pattern was updated in April 1944 so you don't have to add that feathering (which looks terrible IMO) I checked that post, and I will go for the straight lines. The feathered lined look terrible I agree 1 Link to comment Share on other sites More sharing options...
Rick Martens Posted February 25, 2022 Author Share Posted February 25, 2022 17 hours ago, Faraway said: Rick. I will strongly recommend https://www.sovereignhobbies.co.uk/ These are the most accurate colours you will find. This looks an interesting build, way out of my price range and SIZE range, I don’t think my work bench is big enough. I look forward to your progress, no matter how fast or slow. Jon Hi Jon, Thanks for the advise. Do need to find a Dutch retailer because ordering in the UK wakes up customs I am afraid. Link to comment Share on other sites More sharing options...
Rick Martens Posted February 25, 2022 Author Share Posted February 25, 2022 14 hours ago, johndon said: Good to see someone else building this beast, I've been working on mine, on and off (mostly off) for 5 years now... Thanks, looked at your build log and yup a long way to go....... Link to comment Share on other sites More sharing options...
Rick Martens Posted February 25, 2022 Author Share Posted February 25, 2022 13 hours ago, johndon said: One small point, it's not finished, as you've not got the ladders on the side of the turret fitted. 🙂 I checked pictures and drawnings but the ladders on the side are not there Link to comment Share on other sites More sharing options...
Faraway Posted February 25, 2022 Share Posted February 25, 2022 13 minutes ago, Rick Martens said: Hi Jon, Thanks for the advise. Do need to find a Dutch retailer because ordering in the UK wakes up customs I am afraid. Here you go...... https://www.navalmodels.com/ Jon 1 Link to comment Share on other sites More sharing options...
Rick Martens Posted February 25, 2022 Author Share Posted February 25, 2022 13 hours ago, Alan P said: On my 1/350 New Jersey I used a Dremel to carve out the kit blast bag to make it the correct shape: Might be an option, but I don't know the Trumpeter kit 🤔 Thank you, I will give that a try. I am stucked with the MS 32 scheme because of the bridge and because I really like it. Link to comment Share on other sites More sharing options...
johndon Posted February 25, 2022 Share Posted February 25, 2022 6 hours ago, Rick Martens said: I checked pictures and drawnings but the ladders on the side are not there My apologies, it looks like Iowa didn't have the ladders on the sides of turret 1... Link to comment Share on other sites More sharing options...
