perdu Posted May 9, 2022 Author Share Posted May 9, 2022 While paint dries and things arrive I am having a go at the unsung Hawker in my stash. Another Airfix build and chalk and cheese to the Kestrel P1127 build also going on here. Look at this Stuff inside the wells Could be good. I understand the wings are a tiny bit inaccurate in that the fabric panels need modifying and metal bits letting in. Frankly I am not over worried about that , so we will see how I feel later on. 7 Link to comment Share on other sites More sharing options...
perdu Posted May 9, 2022 Author Share Posted May 9, 2022 A narrow escape Thinnest pointy bit of the Kestrel tailplane got broken And lost! Need a better look at that Placed on a flattish block of casting rubber and a small droplet of UV setting resin allow to drip down and cover the triangular missing bit. A quickish cursory glance round the room convinced me its probably under Giorgio's bench by now, if it is G, its OK to throw it away. That'll do nicely when painted. Small blemish behind driver's head corrrected with dripping resin too Canopy should fit nicely when finished. Adieu 6 Link to comment Share on other sites More sharing options...
hendie Posted May 9, 2022 Share Posted May 9, 2022 This is coming along in leaps and bounds Bill. 1 Link to comment Share on other sites More sharing options...
giemme Posted May 9, 2022 Share Posted May 9, 2022 3 hours ago, perdu said: its probably under Giorgio's bench by now, if it is G, its OK to throw it away. I'd have preferred of you to drop over that resin and UV curing lamp, Bill... Seriously, any pointers on the stuff you are using, please? (both the resin and the UV lamp) Ciao 1 Link to comment Share on other sites More sharing options...
perdu Posted May 9, 2022 Author Share Posted May 9, 2022 Leaping and bounding, proof it can be done I have finally emptied out a tube of Perfect Plastic Putty. Damaging Maurice Landi's personal trenches, hope his shade will forgive me but trench warfare displeases me. What was that Giorgio, the Resin? This is what I bought for about twelve pounds, inflation post panicdemic goes up a euro or so https://www.ebay.co.uk/itm/193887244122?hash=item2d24948f5a:g:-xcAAOSwyuNgI~VT And its little UV lamp https://tinyurl.com/3x2sac37 Lots of these on the web for no money it seems (the one I bought didnt specify actual canine waste products, I bought it on spec and it seems to work OK) With the lamp off it looks like any other generic cheapo torch, three AAA batteries fit inside that little device, amazing. 4 1 Link to comment Share on other sites More sharing options...
perdu Posted May 9, 2022 Author Share Posted May 9, 2022 Oh yes, I used the block of cured casting rubber because the resin would not stick to it and allowed me to easily take away the excess. 5 Link to comment Share on other sites More sharing options...
giemme Posted May 9, 2022 Share Posted May 9, 2022 3 hours ago, perdu said: What was that Giorgio, the Resin? This is what I bought for about twelve pounds, inflation post panicdemic goes up a euro or so https://www.ebay.co.uk/itm/193887244122?hash=item2d24948f5a:g:-xcAAOSwyuNgI~VT And its little UV lamp https://tinyurl.com/3x2sac37 Much obliged, Bill Ciao 1 Link to comment Share on other sites More sharing options...
perdu Posted May 10, 2022 Author Share Posted May 10, 2022 I did intend not spending a lot of modification time on the Hurri, but I had fears about fabric wingy Hurricane fabric bits. A small time searching got me access to this plan, which seems to be endorsed by a chap actually refabricing a Hurri wing so a small amount of modding took place A small modification seems called for UV resin again G, hope it does the trick. The internal detail knocks me out considering my first ever Hurricane was the Airfix oldest ever one Okeydoke, now it's time for 'Spoons Steak Night reinstalled on the menu post Covidity. Yummy. 7 Link to comment Share on other sites More sharing options...
Brandy Posted May 10, 2022 Share Posted May 10, 2022 Nice work on the wing Bill. I used the Alley Cat resin conversion but your way is a lot cheaper! Ian 1 Link to comment Share on other sites More sharing options...
perdu Posted May 10, 2022 Author Share Posted May 10, 2022 Cheaper, the story of my life Ian I've done it this way because the Airfix offering seems fine otherwise. 👍 1 Link to comment Share on other sites More sharing options...
giemme Posted May 10, 2022 Share Posted May 10, 2022 1 hour ago, perdu said: UV resin again G, hope it does the trick I definitely need to get hold of some! Clever job, Bill! Ciao 1 Link to comment Share on other sites More sharing options...
Brandy Posted May 10, 2022 Share Posted May 10, 2022 2 hours ago, perdu said: Cheaper, the story of my life Ian I've done it this way because the Airfix offering seems fine otherwise. 👍 Absolutely! I don't think I needed to take the route I did, but it seemed a good idea at the time! Ian Edit: mine was actually a "tin wing" conversion, not a correction for the "rag wing". Memory is not what it was! 1 Link to comment Share on other sites More sharing options...
The Spadgent Posted May 11, 2022 Share Posted May 11, 2022 Lovely tinkering Bill. I foresee not much omni file action on that new Hurrie. The moulding looks very neat. 🤩 1 Link to comment Share on other sites More sharing options...
perdu Posted May 11, 2022 Author Share Posted May 11, 2022 I think you are right Johnny, so far only minor and very usual flash lines to remove on mould halves. And the detail pops when you see it, almost a shame it will vanish into the dark isn't it? My 'main' computer has been in a go slow lately, suspect induced by an automatic update imposed by Mr Gates's lot, problem is I am using the big laptop I bought to be able to tackle Fusion360 and its key layout is awfully 'not quite the same' as the tower unit. The tower locked up whilst I was attempting the walkaround for the Hurricane hope to see whether the seat should be green-ish, silver -ish or Bakelitereddish? Catch you later if I ever get the answer. 7 Link to comment Share on other sites More sharing options...
perdu Posted May 11, 2022 Author Share Posted May 11, 2022 Hmm this very unmucked about with, Finnish machine looks about right I will see if I can work in that direction. (On this kit I wasn't expecting to spend much time or effort on. Just can't help myself) 5 2 Link to comment Share on other sites More sharing options...
perdu Posted May 12, 2022 Author Share Posted May 12, 2022 Wine bottle foil, oh I heard so much about that unknown topic. Then Prosecco nights in pubs gave me some unexpected raw materials. Here are a couple of types getting off-whited for war time Sutton harness strapping. And the Hurriseat has its dose of mixed Marron Dorado and Flat Brown over Aged White. The interior is from Xtracrylics RAF Aircraft Grey Green. Nato black will complete the interior detaling when the control column and pedals will get a little finishing Must remember to add the light lens to the wing... 5 Link to comment Share on other sites More sharing options...
giemme Posted May 12, 2022 Share Posted May 12, 2022 56 minutes ago, perdu said: Wine bottle foil, oh I heard so much about that unknown topic. Then Prosecco nights in pubs gave me some unexpected raw materials. Top choice there, Bill I usually paint the straps after cutting them out, so I'm curious to see how previously laid on paint will hold handling Ciao 1 Link to comment Share on other sites More sharing options...
hendie Posted May 12, 2022 Share Posted May 12, 2022 3 hours ago, giemme said: I usually paint the straps after cutting them out, so I'm curious to see how previously laid on paint will hold handling I use the same method as BIll has here but my material of choice is cig liner paper which is thinner and more flexible. I had tried the wine foil method previously but prefer the liner paper. I'm sure Bill has it under control though 3 1 Link to comment Share on other sites More sharing options...
perdu Posted May 12, 2022 Author Share Posted May 12, 2022 Hmm possibly, so far as long as I use a decent paint it stands up quite well. Vallejo Aged White on this lot, touch ups of the sides might be called for. 3 Link to comment Share on other sites More sharing options...
HAMP man Posted May 12, 2022 Share Posted May 12, 2022 6 hours ago, perdu said: And the Hurriseat has its dose of mixed Marron Dorado and Flat Brown over Aged White. I've always thougt that early Hurris had tin seats, I know Spities had theirs replaced/changed from tin to bran bakolite certainly by MkV's. Troy's yer man, and he always points to the Swedish one as the best to see original bits. Hey ho every day's a day in school. I like the youvee filler idea, what's it like to sand? Box On Strickers 2 Link to comment Share on other sites More sharing options...
perdu Posted May 12, 2022 Author Share Posted May 12, 2022 The uv is rather nice to sand/file/cast in situ Strickers I never get this close to my models with a camera, but just for you. It takes nicely to being worked I worked the edge between these three shots just now whilst I decide where to stop. This is the underside view The material feels as if it is part of the original model almost feels as if you could pick at it like a plectrum with that tip, its very strong. Just noticed here was a slight dollop of excess resin under the playpiece, swift sanding stick action has restored it to where I thought it was. Buy some and try some, I fully expect very satisfied responses. 6 Link to comment Share on other sites More sharing options...
giemme Posted May 12, 2022 Share Posted May 12, 2022 27 minutes ago, perdu said: Buy some and try some, I fully expect very satisfied responses. I bought mine, it arrived this morning. A couple of questions for you, if I may, before I try it: how long before it fully cures? And do you wear those fancy protective glasses when using the UV torch? TIA Ciao 1 Link to comment Share on other sites More sharing options...
perdu Posted May 12, 2022 Author Share Posted May 12, 2022 OK back to front If you want goggles have them. I don't It fully cures, well I dont know, but I usually tap the surface with a scalpel blade momentarily as soon as I have put the torch away. Usually hard immediately, sometimes the surface feel a little sticky to the touch but soon feels drier when I start to work the surface with files or sanding sticks. This is very quick use material. 3 2 Link to comment Share on other sites More sharing options...
giemme Posted May 12, 2022 Share Posted May 12, 2022 Wonderful, thanks Bill! Ciao 1 Link to comment Share on other sites More sharing options...
Fritag Posted May 12, 2022 Share Posted May 12, 2022 (edited) 7 hours ago, perdu said: It takes nicely to being worked. I’m gonna have to try this. Lots of delicate sharp pointy corners on ailerons and wot not on the ‘awks wot have been rounded or plain knocked orf with handling. In’t past I’ve repaired em with drops of cyano sanded back as per your resin technique - but the cyano has not proved very durable. Time to try resin. I wonder if I need to invest in the same stuff as you and G, or whether the printing resin will do the same. I’ve already got a UV torch somewhere…. Edited May 12, 2022 by Fritag typo 3 1 Link to comment Share on other sites More sharing options...
