Mike Posted February 20, 2022 Share Posted February 20, 2022 10.5cm leFH 16(Sf) Auf Geschutzwagen FCM36(f) (35340) 1:35 ICM via Hannants Ltd The Geschutzwagen (gun vehicle) series of Self-Propelled Howitzers were originally created to fill a need for mobile artillery that could be self-sufficient and yet work in unison with troops and tanks at the high speed of Blitzkrieg, similar to the Marder, but with indirect fire from behind the lines their stock-in-trade. The concept was to mount a large diameter howitzer on a captured tank chassis that had been stripped of its superstructure and given an extended splinter shield around the gun and its crew, whilst leaving the roof open to the elements. Like the early Marders, they were built on captured French tank chassis, such as the obsolete FCM 36, with a large shield that extended almost the whole length of the vehicle, housing a WWI era 105mm leFH 16(Sf) howitzer, which was of 1916 vintage. Incidentally, FCM stands for Forges et Chantiers de la Méditerranée, who were based at Toulon in the French Riviera. Only a very few of these vehicles were made due to the relatively small number of FCM36 chassis that were originally captured, and some say that as few as eight were built, although there are numbers as high as 12 mentioned elsewhere. Either way, there weren’t many. They saw service in Europe during the relatively inactive period after their conquest of France and before D-Day, and by 1944 there weren’t any on charge according to records, which up until that point were pretty reliable. The tank was only lightly armoured to protect their crews from shrapnel, shell splinters or small arms fire from all-round, which is somewhat better than a standard artillery piece would afford its crew, although the open roof would make a tempting target for grenades or demolition packs in close combat. However, they weren’t meant to be near the front line under normal circumstances, so it mattered less than it did with direct fire vehicles such as Marders. It would however have been uncomfortable for the crew in bad weather necessitating a temporary tarpaulin roof to keep the precipitation out, but very little of the cold. The Kit This is another re-tool of ICM’s previous FCM 36 kit, adding the specialised parts for the conversion undertaken by Baustokommando Becker at the time. It arrives in a standard ICM top-opening box that has a captive inner lid, with seven sprues in grey styrene, two flexible black sprues of track links, a decal sheet and glossy instruction booklet with colour profiles in the back pages for painting and markings. The original FCM 36 kit was only released in 2020, so it’s a modern tooling with plenty of detail and this boxing includes the majority of the interior due to the open roof. Construction begins with the lower hull, which is made up initially of the floor and two sides that are cut back slightly to accommodate the different upper hull, as shown in an accompanying diagram, with bulkheads added to the sides to support the lower sponson panels that give the vehicle more ground clearance. The running gear is made up from a three-part drive sprocket, eighteen sets of twin wheels that are fitted to eight double bogies and two singles, then the big idler wheels at the rear of the hull on adjustable tensioning axles. The sloped armoured upper sponsons are installed along the way, with the mud-shedding apertures on each side, idler adjustment mechanisms and some towing eyes on the back plate. Two pairs of return rollers on the top run are glued inside the sponson, then the flexible black “rubberband” tracks are glued together, the instructions neglecting to mention that styrene glues won’t join them, so you should use super glue or epoxy instead. Each run has two sections, with the joints best placed in the centre of each run so they stand less chance of being seen on the finished model. Detail on the tracks is very nice, with twin guide horns and perforated centres like the real thing, but of course the links will curve round the ends, rather than having the correct faceted look that individual links provide. The upper hull is a new part that was also seen on the recent Marder I kit, and has an opening at the front where the turret would have been, and has the two fender sides fitted to the rear before it is joined to the lower hull, hiding most of the upper track run. At the rear a large louvered panel and fixtures on the final-drive access hatches are glued on first, with the two shrouded exhausts and their mufflers slotted into grooves to their side, and a shallow C-shaped manifold joining them at the top. Pioneer tools and towing eyes are fitted later, because the gun must be made up first, after adding a driver’s panel and vision slit it fixed into the top of the glacis plate. The WWI era 10.5cm leFH 16(Sf), is begun by making up the combined cradle and breech, then adding the cradle trunnions and elevation mechanism on both sides, after which the floor is made up with the underfloor ammo storage depicted by gluing the 36 striking plate charge sections of the two-part ammunition into the box-sections in the forward floor. It is mated to the hull on a substantial C-shaped plinth with a locking washer, covering up the former turret aperture, then adding aim adjustment wheels before the gun’s splinter shield is begun by adding the two faceted side panels and the cheek parts, the former having been fitted out with shell racks, radio boxes and machine gun ammo canisters. The forward splinter shield that moves with the gun barrel is added outside the main shield, preventing stray rounds or shrapnel from entering the cab or damaging the gun slide, the latter part comprising two sides with angled front to deflect frontal shots. A louvered panel is fixed into depressions on each of the side walls, and the back panel with moulded-in access hatch are glued onto the rear of the crew compartment, then two sets of 21 x 105mm shells and a few more separate charges with striker plates are placed next to them. At this stage the pioneer tools can be attached to the exterior compartment walls at the rear of the vehicle, with light cluster, spare track links and barrel cleaning rods at the front, plus an antenna perched atop the side wall to the rear, and a self-defence MG34 machine gun on the front, then you can put on the two-part muzzle brake that gives the impression of a hollow barrel. Markings There are three markings options on the small decal sheet, with variation between them and some interesting camouflage schemes, all of which saw service in 1943. From the box you can build one of the following: Mobile Brigade West, 1943 931st Assault Gun Division, France, 1943 Training Camp of Mobile Brigade West, Summer 1943 The decals are printed by ICM’s usual partner, which is a guarantee of good registration, sharpness and colour density, with a thin gloss carrier film cut close to the printed areas. Conclusion Another peculiar, niche, but interesting example of German re-use of captured vehicles, and a nicely detailed one too. Of course, it looks a bit strange and top heavy, but that’s part of its appeal. Available in the UK from importers H G Hannants Ltd. Review sample courtesy of 1 Link to comment Share on other sites More sharing options...
Milan Mynar Posted April 23, 2022 Share Posted April 23, 2022 Model looks good and simple to build. Link to comment Share on other sites More sharing options...
