alteregoni Posted February 20, 2022 Share Posted February 20, 2022 (edited) Hi I'm building Tamiya Lexus LFA at the moment. There is some ankward gaps on body shell, where sanding putty is really hard to do right. So I'm thinking to use putty what you don't have to sand. I have tube of Vallejo. My question is does it react under lacquer etc. paints? I'm using Tamiya decanned surface primer and Gravity Spain base coat and 2k clear. Pekka Edited February 20, 2022 by alteregoni Correction Link to comment Share on other sites More sharing options...
Ade H Posted February 20, 2022 Share Posted February 20, 2022 That's one of my favourite fillers when used appropriately. In my experience, it's absolutely fine under hobby lacquers like Tamiya LP and Mr. Color (including GX colours). It even withstands paint stripping (which is just as well for me). But if that Gravity paint is stronger, why not test it first? You have both products, so a dry run will assure you either way. 1 Link to comment Share on other sites More sharing options...
alteregoni Posted February 21, 2022 Author Share Posted February 21, 2022 Thanks, and for the tip too! Link to comment Share on other sites More sharing options...
desert falcon Posted April 11, 2022 Share Posted April 11, 2022 On 2/21/2022 at 8:43 AM, alteregoni said: Thanks, and for the tip too! Hi Pekka, Did you have a chance to do a dry run yet and if yes how did it go please? Think I might be in the same situation as you soon, as I will start a Revell Porsche kit which needs a bit of filling at the rear. Cheers Johnny b Link to comment Share on other sites More sharing options...
alteregoni Posted April 12, 2022 Author Share Posted April 12, 2022 No sorry, I decided to do other project first Link to comment Share on other sites More sharing options...
Lvp Posted April 12, 2022 Share Posted April 12, 2022 On 2/20/2022 at 8:38 AM, alteregoni said: Hi I'm building Tamiya Lexus LFA at the moment. There is some ankward gaps on body shell, where sanding putty is really hard to do right. So I'm thinking to use putty what you don't have to sand. I have tube of Vallejo. My question is does it react under lacquer etc. paints? I'm using Tamiya decanned surface primer and Gravity Spain base coat and 2k clear. Pekka Hi, I've used this under lacquer based primer and painted with paint thinned with Mr. Color leveling thinner with no problems. Also used it in combination with Tamiya gray putty, again no issues. I just find it doesn't sand well until fully cured - 4 to 5 days. In the appropriate situations, it can be very useful. 1 Link to comment Share on other sites More sharing options...
