Airfix Chipmunk wing issue
Ray S
Hello all. I am not quite sure if I have a problem with this kit.
I am just starting the Airfix 1/48 Chipmunk T.10, and the first thing I looked at was trying to avoid the known wing droop issue. I cut the wings out and taped them together straight from the box:
DSCN8404
Although the wing has sat at an angle, there is clearly a droop on both sides (I think!) Then I removed the outboard location pins from the port wing leading edge on the right of this picture) and got this when I taped them back together again:
DSCN8405
It straightened up quite a bit (I think!). However, it still looks like there is a downward droop but looks better than the starboard (un-modified) wing. Then I had a look at the wing upper halves, and found a downward kink which when I taped the two uppers together inner to inner, produced this:
DSCN8406
To my eyes, and the way my mind is working at the moment, that would lead me to think that these could also be causing some of the droop - the kink starts about 1/3rd from the left, near a slightly darker patch on the trailing edge. The trailing edges are not very good at meeting each other on this particular kit either.
Has anyone else had this issue? I have not seen it mentioned elsewhere.
I will end up building it anyway, the rest of the kit looks fine, I am just wondering if there has been some warping on my kit rather than just the pin issue causing the droop problem.
Cheers from one confused Ray
Recommend you remove the pins as you have then, one wing at a time, glue upper and lower. Then, immediately, trap the wing between a very flat surface and a very heavy book. After the first is cured, repeat again with the other wing. This approach has worked for me in the past.m
