Old John Posted February 4, 2022 Share Posted February 4, 2022 I have little trouble stripping chrome off my models, the varnish underlay is a different story. This is often very uneven. anyone successfully chemically removed it.? Link to comment Share on other sites More sharing options...
Black Knight Posted February 4, 2022 Share Posted February 4, 2022 MrMuscle oven cleaner Link to comment Share on other sites More sharing options...
Old John Posted February 4, 2022 Author Share Posted February 4, 2022 Thank you. I have found oven cleaner takes off the chrome but not the varnish underneath. Link to comment Share on other sites More sharing options...
keefr22 Posted February 4, 2022 Share Posted February 4, 2022 DOT 4 Brake fluid? I've used it to strip all types of paint off car bodies, only once had a problem with it making some parts of the body slightly brittle - and that was probably because I forgot about it and left it soaking for over three months! Don't know if it will work on the varnish you mention as I've never had a problem with it, I just strip the chrome, prime and respray. Keith Link to comment Share on other sites More sharing options...
Old John Posted February 4, 2022 Author Share Posted February 4, 2022 Hi Keith Thank you Strip & spray is my usual way,but I find on a some old 70s manufactured kits the varnish is pretty rough.The one at the moment is a 1 16th scale Rolls Royce Balloon car & it has lots of very small & fragile chromed parts which I want to do brass.Never used brake fluid ( well not for a model car) will give it a try on spare sprue & see. The chrome is off it is just the dodgy varnish I would still like to remove. Some you can scrape off, but i may just have to live with the others if brake fluid doesn't work well. 1 Link to comment Share on other sites More sharing options...
Six97s Posted February 5, 2022 Share Posted February 5, 2022 Try isopropyl alcohol. It will need a good soak and you'll still have to scrub it with an old toothbrush, but it usually works for me. 1 Link to comment Share on other sites More sharing options...
Alan R Posted February 5, 2022 Share Posted February 5, 2022 (edited) I can echo the DOT 4 brake fluid. Always worked for me. It can make the plastic a bit brittle, juts leave it in long enough to remove the varnish. Edited February 7, 2022 by Alan R typo 1 Link to comment Share on other sites More sharing options...
