Julien Posted February 4, 2022 Share Posted February 4, 2022 PLA ZTQ15 Light Tank (TS-048) Chinese Light Tank 1:35 Meng via Creative Models Ltd The catchily titled ZTQ15 Light Tank has been developed by the PLA for what they call Plateau Operations. The tank is light enough to be transported by air but still has a 105mm main gun able to fire a diverse selection of rounds. The engine is specifically developed for a high altitude low oxygen environment where a second stage turbo charger will kick in if needed. The tank features newly designed reactive armour with the ability to add on other armour if needed. Crew is reduced by the use of an auto loader, The tank is fitted with an electroptical countermeasures system and a radar warning system. An export version the VT-5 has been ordered by Bangladesh where no doubt the low ground weight is seen as an advantage in the country. The Kit This is a new kit from Meng of this new PLA light Tank. As well as the two hull parts and the turret there are 3 major sprues, and 1 smaller clear one, and a flexible part for the gun cover. There are a set of poly caps for the suspension and a set of rubber band tracks. Construction starts with the running gear. 12 pairs of road wheels, two drive sprockets; and two idler wheels. Each is in two halves with a polycap going in between. We can then move to the lower hull with 6 torsion bars going in from each side. At the front the mud guards are added. Other parts for the suspension are added along with the gearbox housings, return rollers, and tow hooks. All the wheels can now be added to the lower hull, and at the front the lower armour is fitted. Next on the upper hull the engine deck is added along with the drivers vision blocks. The upper and lower hulls can now be joined. Next up the tracks are added. At the rear the bulkhead is constructed and added to the hull. The side armour pates can now be added. If wanted the rear mounted extra fuel drums can be made up ad fitted. Pioneer tools and additional hull fittings can then be added. Work now moves to the turret. The vision blocks for the commanders hatch go in followed by the gun mount. The upper and lower turret parts can be joined with the rear and side armour plates being fitted. Sensor parts are added along with the AA gun copula. The flexible gun mantlet cover goes on followed by the 7 part gun barrel To both sides of the turret supports for additional spaced armour are fitted followed by the armour. Smoke dischargers and turret baskets are fitted to both sides at the rear of the turret. Additional top armour and the crew hatches are added to the turret. The last item to be built up added is the 12.7mm Anti Aircraft gun, once this is on the turret can be mounted to the hull. Markings A small decal sheet printed in China is enclosed. This gives marking for the digi camo vehicle shown on the box art at the 70th Anv of the founding of the PLA parade Oct 2019, and a 3 colour camo vehicle as used in Tibet. Conclusion This is an usual Tank fielded by the PLA for a specific use, it will make an interesting addition to any collection of modern armour. Recommended. Review sample courtesy of 1 Link to comment Share on other sites More sharing options...
