Academy 1/48 Mig21MF (Probably) in Egyptian colours
Marklo
20 minutes ago, modelling minion said:
, I don't know what the issue is but I can't see any of your pictures though.
Me too, not doing anything different but images aren't showing :( Time for some research...
73-C99301-68-B6-4-FED-BCCE-7-D18216018-AAssembly started. Fit is mostly good but sometimes meets a bit of fettling. For example the wing roots in particular didn’t sit quite right without a lot of fitting.
Good start there, looks like it'll  be together in a flash, i too am having problems with imgur, most of mine are sharing problems from my pad tho, imgur doesn't show in the sharing apps like it used to,i have to do quite a lengthy workaround
C4-A26555-76-F9-4-BE9-8-BCB-B3820-DA4-EC
Wings, rear fuselage, tailplane, spine and lower strake assembled. Actually went together quite well, some fine gaps but nothing a little ppp won’t fix.
99-F15-C25-AC17-476-F-9-EA6-D007-CBABE19
Started on the office and dry fitted the nose. Next task is to paint the interior and then figure where to put weights.
  • 3 weeks later...
  • 4 weeks later...
ED5949-B4-3-E6-A-4-E8-D-9-F4-D-30-DC2-BCA coat of primer on the main subassemblies. Needs a tiny bit of work on the spine. Once I attach the forward section I’ll revisit the primer s as me fo some preshading.
  • 3 weeks later...
21 hours ago, Marklo said:
Time to get stuck in, only three weeks left so this and my three ground attack builds get priority.
Nothing like a deadline to sharpen the focus!
It's coming along quite nicely 👏
But I have to correct you and point out that this is the Academy kit not Eduard, no bad thing as the Academy kits are pretty good in themselves, but the Eduard ones are just that little more detailed.
  • Marklo changed the title to Academy 1/48 Mig21MF (Probably) in Egyptian colours
Right you are, don’t know what made me think it was Eduard, still a nice kit though.
