Italian Traffic Signs 1930-40s (35637) 1:35
Mike
1:35 MiniArt via Creative Models Ltd
During WWII Italy joined the war as allies of Nazi Germany alongside Japan, and fought against the Allies in Europe and North Africa.  When the Dictator Mussolini was ousted, Italy changed sides at the will of the people, but German forces stayed in the Italian homeland, attempting to retain Italy as part of their embattled and shrinking 1,000 year Reich.  The Allies were forced to fight their way through Italy as a result, in what is inappropriately known as Europe’s soft underbelly, that was very far from soft, as any of the dwindling number of veterans of that conflict will tell you.  This set is full of signs from Italy from the 30s and 40s, all of which are civilian in nature and some of the names will be familiar because of the notable battles that took place there.
The Kit
These signs relate to Italian civilian roads, and arrives in a shrink-wrapped, end-opening, figure-sized box with a painted example of what’s in the box on the front, and a set of instructions on the rear.  There are six sprues of styrene parts, plus a large decal sheet with the sign fronts to complete the set.  There are 25 signs and a number of text-only signs for the cross-style posts on the decal sheet for you to use, either using the included guide on the box or going off-piste if you see fit.  The posts are of a fairly standard and narrow format, and would have been easily bent in the event of an accident.  The posts are either straight box-section, or circular style, some with slightly wider bases and a round ferrule on the tip, which can be removed with a blade for some of the signs.  The sign boards have cleats on the rear surface to attach them to the poles, with the straps moulded into the posts to guide you in marrying up the two parts.
The decals are printed by DecoGraph, and have good registration, clarity and sharpness, with a thin carrier film fitted closely around the printed areas.  Some of the sign decals have raised reflective rivets that are similar to the early British road signs, and these have been replicated on the decals.  They do a great job considering they are two-dimensional artwork, but if you have access to suitably-sized cabochon rhinestones, you could replace them on top of the 2D versions for extra realism.
Under the instructions on the rear of the box is a paint chart that gives colour swatches plus Vallejo, Mr Color, AK RealColor, Mission Models, AMMO, Tamiya codes, and generic colour names to assist you in choosing the correct paints for your model.  It seems that the Italian sign post poles were almost universally candy-striped, so be prepared with a long length of masking tape to wrap around the post for painting the contrasting colour.
Conclusion
Great diorama fodder, as the devil’s in the details.  The printed decal signs are also so much better than most of us could do with a paint brush, and will add a little extra realism to any diorama or vignette.
Highly recommended.
Review sample courtesy of
