Faraway Posted February 3, 2022 Share Posted February 3, 2022 29 minutes ago, Steve D said: Hard 0.5mm brass wire painted white or silver may work to support it I guess it all depends on the weight of the balloon, but that might work. I tried a lump of blutac on 0.5mm wire and it didn’t bend too much. It might be further support by the other wires, all depends how high the balloon will be flying. Jon Link to comment Share on other sites More sharing options...
robgizlu Posted February 5, 2022 Author Share Posted February 5, 2022 On 2/1/2022 at 2:31 PM, Iceman 29 said: @robgizlu Great project! Knowing your previous assembly, it should be a nice model.👍 Rob, you should have asked me about the balloon, it is very quick to draw and print. It would have been much finer than Shapeways. All it had to do was cross the Channel to get to you in a letter Pacal - That was very kind and generous. You'll have to be careful or you'll have a stream of begging letters. I would have asumed it would be difficult to 3D model. The sculp is very good - the printing not so much. On 2/2/2022 at 11:25 PM, Courageous said: ...a raft! Stuart On 2/3/2022 at 1:47 PM, beefy66 said: Oh Yee of little faith. beefy Children!........................Daddy will be furious when he comes home On 2/3/2022 at 1:41 PM, Rob G said: Hi Rob, I was doing a bit of digging and found this website that just may be of interest, if you haven't yet seen it. http://www.bbrclub.org/Site Directory.htm There's sections there about mooring balloons and also a bit about balloon vessels. HTH. Thanks Rob - That was one of my research references and very inspiring On 2/3/2022 at 6:17 AM, beefy66 said: Rob have you considered a back drop so you could attach the balloon from the rear you could make it ala Longshanks method of display as a picture frame and still have the thin wire as support from below just my thoughts Stay Safe beefy I have Beefy and it remains an option though not a preferred one. Thanks for all the comments and suggestions Fellas Rob 3 Link to comment Share on other sites More sharing options...
Bobs_Buckles Posted February 6, 2022 Share Posted February 6, 2022 Ernie Ball 14 gauge steel guitar string may do the trick. Depends (obviously) on the weight of the gasbag. Whatever way you go, GOOD LUCK! Cheers, Bob 😀 1 Link to comment Share on other sites More sharing options...
robgizlu Posted February 7, 2022 Author Share Posted February 7, 2022 On 2/6/2022 at 9:23 AM, Bobs_Buckles said: Ernie Ball 14 gauge steel guitar string may do the trick. Depends (obviously) on the weight of the gasbag. Whatever way you go, GOOD LUCK! Cheers, Bob 😀 Thanks Bob Following the instructions of my Zen Master ( @longshanks) I penned the ribs for them to show through at the sanding stage and then opened th car filler ...... The first time I've ever used - smells great but not so easy to apply though I agree about it drying fast I thought I'd work little by little And then ignoring the advice of you all and my Zen master I couldn't resist uasing Sylmasta "A&B" modelling putty to fill the stern. Possibly harder to sand BUT you are able to smooth it and contour it unlike the S-38 car filler The A&B putty was old so I'm waiting for some replacement "Magic Sculp" to arrive. The next stage I feel is the hardest and that's to model the Bulwarks, particularly the transom and bow. The plan is to stick som 0.16mm plastic sheet into a groove at the level of the deck and once it's fixed, fill and sand to get a flush join - that at least is the plan. I'm aiming to do one side at a time. Fillets were added, the lower Bulwark contour cut and the process of "welding" it with Tamiya Extra Thin styrene cement, bit by bit Looks a flippin mess at the moment We'll see Thanks for looking Rob 18 Link to comment Share on other sites More sharing options...
ArnoldAmbrose Posted February 7, 2022 Share Posted February 7, 2022 Gidday Rob, yeah it looks a mess at the moment but it's the final photo in the WIP thread, and those in the RFI section that matter. 🙂 Actually, so do all the other photos, including these ones, that matter. In a sort of "how to" or "how not to" sort of way. I'm still following your method with keen interest. Regards, Jeff. 1 1 Link to comment Share on other sites More sharing options...
Steve D Posted February 7, 2022 Share Posted February 7, 2022 Rob, It's a bit late for this build, but what I do in these circumstances is infill the frames with balsa wood (marked to the largest frame each time) and then sand that back to the frames. This is quick and easy, the filler can then be added as a thin layer to finish the job. May be a little easier for next time Cheers Steve 5 1 Link to comment Share on other sites More sharing options...
PAUL67 Posted February 8, 2022 Share Posted February 8, 2022 Rob it may look rough at the moment but then most builds do at this stage …don’t give up with this miniature… Paul 1 Link to comment Share on other sites More sharing options...
foeth Posted February 8, 2022 Share Posted February 8, 2022 For both the balloon and the hull: did you consider vacuum forming? Really easy to do and you get a very light balloon and a nice hollow hull? 1 Link to comment Share on other sites More sharing options...
robgizlu Posted February 9, 2022 Author Share Posted February 9, 2022 On 2/7/2022 at 1:24 PM, ArnoldAmbrose said: Gidday Rob, yeah it looks a mess at the moment but it's the final photo in the WIP thread, and those in the RFI section that matter. 🙂 Actually, so do all the other photos, including these ones, that matter. In a sort of "how to" or "how not to" sort of way. I'm still following your method with keen interest. Regards, Jeff. Thanks Jeff On 2/7/2022 at 2:16 PM, Steve D said: Rob, It's a bit late for this build, but what I do in these circumstances is infill the frames with balsa wood (marked to the largest frame each time) and then sand that back to the frames. This is quick and easy, the filler can then be added as a thin layer to finish the job. May be a little easier for next time Cheers Steve Thanks Steve - filed away in my hints and tips though don't forget this is precisley 8.5cm long - I think I'd have more trouble cutting the balsa On 2/8/2022 at 7:28 AM, PAUL67 said: Rob it may look rough at the moment but then most builds do at this stage …don’t give up with this miniature… Paul Thanks Paul, it does take a minor act of faith On 2/8/2022 at 7:37 AM, foeth said: For both the balloon and the hull: did you consider vacuum forming? Really easy to do and you get a very light balloon and a nice hollow hull? Thanks EJ - No - well outside of my comfort zone and despite the print/surface qaulity the ballon is really very detailed. I'm still absorbing basic hull building steps So once again with Thanks to my Zen Master - Obi Wan Longshanks and acknowledging his patience taking me through steps that a Drunken Donkey would have picked up 5 x faster, it's on with the show...... the Bulwark topping is 0.3 x0.5mm strip I elected to sand and fill the port side completely before progressing to the starboard bulwark Getting the transom rail to "curve" with a single sheet of plastic was a trial It was neater () than I anticipated but the overhanging upward angle was not present I was really happy for a couple of hours until the demons came. So I cut the rear bulwark away and attempted to "salvage" the build and try to get that overhang more realistic which in many respects is the visual signature for these vessels The problem really arose by trying to use just one piece of palstic each side - even the thin stuff just isn't pliable enough I cut pieces of plastic by trial and error to get the right angle - it took 6 You can see the sort of thing in the next pic at the top Hugely more realistic stern, which still needs sanding down Hull and Deck now complete to my satisfaction ......unless the demons come again Zen Master is happy and has welcomed me to his world - jes suis arriviste! Rob Oh and the tip about felt-penning the ribs was Soooo right-on 23 Link to comment Share on other sites More sharing options...
Faraway Posted February 9, 2022 Share Posted February 9, 2022 Well. That’s looking amazing. A master builder at work. Jon 1 Link to comment Share on other sites More sharing options...
stevehnz Posted February 9, 2022 Share Posted February 9, 2022 That is looking really good Rob, your bulwarks are things of beauty. Steve. 1 Link to comment Share on other sites More sharing options...
longshanks Posted February 9, 2022 Share Posted February 9, 2022 Nice one Rob Remember Grasshopper Wipe on, Wipe off Excellent start, the world is now your oyster. Go for it Stay safe Kev 2 Link to comment Share on other sites More sharing options...
ArnoldAmbrose Posted February 10, 2022 Share Posted February 10, 2022 5 hours ago, robgizlu said: So once again with Thanks to my Zen Master - Obi Wan Longshanks and acknowledging his patience taking me through steps that a Drunken Donkey would have picked up 5 x faster, it's on with the show...... 😁👍 Does Obi Wan have a brother named Kev by any chance? 🙂 Seriously, I think you can thank the demons too. That stern looks like it was worth the effort. And . . . 3 hours ago, longshanks said: Remember Grasshopper Wipe on, Wipe off Would "Sand the Floor" be appropriate here too? Keep up the excellent work. Regards, Jeff. 1 Link to comment Share on other sites More sharing options...
Steve D Posted February 10, 2022 Share Posted February 10, 2022 11 hours ago, robgizlu said: don't forget this is precisley 8.5cm long It's looking very nice Rob, well done, those bulwarks look like a real nightmare. If I may correct your point, the ships boats hulls which I produce in tissue paper on a mould go down to 5 cm (and could be smaller) using balsa between frames quite successfully. The other point on taking a tissue shell off a mould is that you can produce many very quickly once you have the mould so a fleet of trawlers is within reach. 6-8 layers of tissue soaked in weak pva make a very strong shell that can include the bulwarks and is easy to sand. As ever I unapologetically lead the charge re using more traditional materials Cheers Steve 2 1 Link to comment Share on other sites More sharing options...
Dmitriy1967 Posted February 10, 2022 Share Posted February 10, 2022 On 07/02/2022 at 16:16, robgizlu said: We'll see Thanks for looking Rob My God! Where could you buy such a huge jar?! She's bigger than a ship! I could only find a small one. 1 9 Link to comment Share on other sites More sharing options...
Dmitriy1967 Posted February 10, 2022 Share Posted February 10, 2022 13 hours ago, robgizlu said: The problem really arose by trying to use just one piece of palstic each side - even the thin stuff just isn't pliable enough Rob Have you tried heating the plastic to make it bend better? Or is this plastic not worth warming? Link to comment Share on other sites More sharing options...
Courageous Posted February 10, 2022 Share Posted February 10, 2022 Glad you stuck with it, she's looking pretty neat. Stuart 1 Link to comment Share on other sites More sharing options...
robgizlu Posted February 10, 2022 Author Share Posted February 10, 2022 10 hours ago, Dmitriy1967 said: Have you tried heating the plastic to make it bend better? Or is this plastic not worth warming? Errrm.......yes Rob 2 5 Link to comment Share on other sites More sharing options...
Courageous Posted February 10, 2022 Share Posted February 10, 2022 11 minutes ago, robgizlu said: Errrm.......yes Got there in the end though . Stuart 1 Link to comment Share on other sites More sharing options...
ArnoldAmbrose Posted February 11, 2022 Share Posted February 11, 2022 Gidday Rob, that tiny dinghy at the stern, what's that made of, if I may ask? Regards, Jeff. 1 Link to comment Share on other sites More sharing options...
robgizlu Posted February 12, 2022 Author Share Posted February 12, 2022 On 2/11/2022 at 4:07 AM, ArnoldAmbrose said: Gidday Rob, that tiny dinghy at the stern, what's that made of, if I may ask? Regards, Jeff. Hi Jeff - it's a resin dinghy from a Black Cat models LCI. I was just test fitting it to the stern to check on clearance. With hull nearly cleanly sanded, it's superstucture and fittings next. Rob 3 1 Link to comment Share on other sites More sharing options...
robgizlu Posted February 15, 2022 Author Share Posted February 15, 2022 Well - a couple fo sanding sticks later tkes to this... I ran a light spray of Alclad primer over just to check for "dings" - it was remarkably clear And then sanded it off to get to thepastic surface as it 's easier to weld thin strips of gunwhale rail and rubbing strips The rubbing strips themeslves are sanded back to reduce their height resulting in several "fractures" - especially where I used CA glue over the resin Scupper holes were also drilled and carefully filed And while all this has been going on I've given 2 separate coats of Mig Ammo One Shot to the ballon and sanded it back The surface is just Horrible! The plan is another coat of acrylic primer then some Alcald primer. More soon I'm enjoying this Rob 20 Link to comment Share on other sites More sharing options...
Bobs_Buckles Posted February 15, 2022 Share Posted February 15, 2022 I'm enjoying this too! Excellent work, Rob 😉 Cheers, Bob Link to comment Share on other sites More sharing options...
ArnoldAmbrose Posted February 15, 2022 Share Posted February 15, 2022 Gidday Rob, I just lurve what you've done to that hull. Superb. Regards, Jeff. Link to comment Share on other sites More sharing options...
Faraway Posted February 15, 2022 Share Posted February 15, 2022 All coming together very nicely. Jon Link to comment Share on other sites More sharing options...
