silver911 Posted May 25, 2022 Author Share Posted May 25, 2022 11 hours ago, Redstaff said: Wow You have been a busy boy haven't you Ron The amount of detail is absolutely superb as usual, I think the painting and weathering of the engine is excellent Ian Many thanks Ian. It's the same old argument...the more you add the more you find to add I admit to enjoying the weathering on the DFV...more so than the flat twelve Boxer...it just looks more race used than the 312T did. Replicating the wear to go along with the weathering is a nice challenge...and lends itself well to my techniques. ATB Ron 1 Link to comment Share on other sites More sharing options...
silver911 Posted May 25, 2022 Author Share Posted May 25, 2022 4 hours ago, Toftdale said: Which you have achieved to absolute perfection - Andy Much appreciated Andy I will admit to having a soft spot for the DFV...they always look so well used in pretty much all the pics you can find...which gives someone like me a lot of fun when trying to replicate it...and allows me to use all the favourite techniques I have in my toolbox. Ron 1 Link to comment Share on other sites More sharing options...
silver911 Posted May 25, 2022 Author Share Posted May 25, 2022 4 hours ago, bigbadbadge said: Great work Ron, the brake assemblies look fab and the gearbox unit looks real, I like the weathered appearance fella, just add the gearbox oil and it's good to go. Chris Glad you like the work so far Chris There will be more detailing and weathering at a later stage on the gearbox...as I tend to tie everything together following the final assembly...which gives a more 'balanced' final presentation to my eye. Ron 1 Link to comment Share on other sites More sharing options...
silver911 Posted May 26, 2022 Author Share Posted May 26, 2022 In response to Dave's (Coors54) comment in being interested to see what I came up with for the 'injectors'...and not being happy with my first/second or third attempts!...here is the Mk4 version. They are now 30% smaller overall than the Mk1 First the spread of parts involved in each one..... Next a test fit..... After 9 hours and much cursing...8 made A comparison to the kit parts..... I am pleased that...even reducing the overall size...the fuel lines will insert into the injector as per the 1:1...and avoid the push on solution of the kit. to be continued............ 8 Link to comment Share on other sites More sharing options...
Pouln Posted May 26, 2022 Share Posted May 26, 2022 As always, beautifull stuff, Ron. And yes, you keep finding additions and improvements. 1 Link to comment Share on other sites More sharing options...
silver911 Posted May 27, 2022 Author Share Posted May 27, 2022 13 hours ago, Pouln said: As always, beautifull stuff, Ron. And yes, you keep finding additions and improvements. Thanks Poul With the BT44b...as opposed to the 312T...it's not so much about what's missing from the kit...more an exercise in what can be replaced/improved/corrected...with extra/missing details added purely for the fun of it. Ron Link to comment Share on other sites More sharing options...
desert falcon Posted May 27, 2022 Share Posted May 27, 2022 Impressing work so far, this kit will end up being better engineered than the real car 1 Link to comment Share on other sites More sharing options...
silver911 Posted May 27, 2022 Author Share Posted May 27, 2022 2 hours ago, desert falcon said: Impressing work so far, this kit will end up being better engineered than the real car Thanks DF It's a fine piece of engineering but...like so many cars of that era...certain areas of engineering were a bit suspect Ron 1 Link to comment Share on other sites More sharing options...
Mumbly Posted May 27, 2022 Share Posted May 27, 2022 4 hours ago, silver911 said: Thanks DF It's a fine piece of engineering but...like so many cars of that era...certain areas of engineering were a bit suspect Ron It is all too easy to forget that that era really was a time when cars were knocked up in a shed. I remember all the manufacturers that were in Slough Trading Estate in tiny workshops, only noticeable by their transport trailers giving the game away. A far cry from today’s surgical clean environments. 2 Link to comment Share on other sites More sharing options...
silver911 Posted May 27, 2022 Author Share Posted May 27, 2022 4 hours ago, Mumbly said: It is all too easy to forget that that era really was a time when cars were knocked up in a shed. I remember all the manufacturers that were in Slough Trading Estate in tiny workshops, only noticeable by their transport trailers giving the game away. A far cry from today’s surgical clean environments. I know people often refer to the golden days of Fangio et al...and indeed there were many such eras you could deem as incredibly dangerous...to which I wholeheartedly concur...but...1975/6 holds many fond memories for me...not least of which F1 Ron Link to comment Share on other sites More sharing options...
silver911 Posted May 27, 2022 Author Share Posted May 27, 2022 Continuing with the fuel rails/trumpets... Having made the injectors from metals...and with Tamiya supplying machined ali trumpets in this 're-release'...I just had to do something about the injector bases ! No point in having metal trumpets sat on blobs of plastic...with the added hassle of trying to fit the metal injectors into them. So...time to create some metal replacements. I used some ali tube that fitted snugly into the cut-outs in the trumpets (sorry about the poor pic but you get the idea) and used industrial strength CA Gel to fix it in place..... These were left over night to harden...then...using a micro saw...the overhang was cut away flush with the trumpet base...and a mounting pin glued into it..... Then I removed the kit injectors from the rails...and drilled holes for the mounting pins in the base of each trumpet..... Then it was a case of base coating the rails and...once dry...attaching the trumpets..... Will let these harden over night...then test fit the primed injectors to be continued............ 10 Link to comment Share on other sites More sharing options...
Toftdale Posted May 28, 2022 Share Posted May 28, 2022 Well worth your efforts, the trumpets look fantastic - Andy 1 Link to comment Share on other sites More sharing options...
silver911 Posted May 28, 2022 Author Share Posted May 28, 2022 3 hours ago, Toftdale said: Well worth your efforts, the trumpets look fantastic - Andy Much appreciated Andy A lot more still to do...add the injectors...weather it all etc. ...but very happy with it so far. Ron Link to comment Share on other sites More sharing options...
silver911 Posted May 28, 2022 Author Share Posted May 28, 2022 (edited) Time to start assembling some bits. First off...coil/distributor/fuel pump/vacuum pump..... Weathered and fitted rails/trumpets and injector assembly to main block..... A few fun hours of making sense of all the lines and leads ahead to be continued............ Edited May 28, 2022 by silver911 8 Link to comment Share on other sites More sharing options...
silver911 Posted May 29, 2022 Author Share Posted May 29, 2022 (edited) Here we are...a day and a headache later..... Pleased to have this stage out of the way to be continued............ Edited May 29, 2022 by silver911 re-posted pics 8 Link to comment Share on other sites More sharing options...
Toftdale Posted May 29, 2022 Share Posted May 29, 2022 Another perfect example of how you always manage to harmonise all the individual elements so nothing looks out off place - Andy 1 Link to comment Share on other sites More sharing options...
silver911 Posted May 29, 2022 Author Share Posted May 29, 2022 5 hours ago, Toftdale said: Another perfect example of how you always manage to harmonise all the individual elements so nothing looks out off place - Andy Many thanks for compliment Andy...always appreciated I have always tried to maintain a 'balance' in my style/techniques...and always work from 1:1 refs...which...IMHO...is the only way to replicate the full size subject. Ron Link to comment Share on other sites More sharing options...
Redstaff Posted May 30, 2022 Share Posted May 30, 2022 Stunning work as usual Ron Looking very realistic Ian 1 Link to comment Share on other sites More sharing options...
silver911 Posted May 31, 2022 Author Share Posted May 31, 2022 12 hours ago, Redstaff said: Stunning work as usual Ron Looking very realistic Ian Many thanks Ian Glad you find the look realistic...must be doing something right then Ron 1 Link to comment Share on other sites More sharing options...
silver911 Posted May 31, 2022 Author Share Posted May 31, 2022 Nothing exciting...just a couple of bits added to the main block...a small tank...on which I replaced the main pipe with ali tube...plus heat shrink and hose clamps..... Next kit part for replacement...and another chance to use the micro UJ's...gear shift linkage..... Then four more tie rods...which have one end unglued for final adjustment when assembling..... Lastly....another pipe modified with ali tubes/heat shrink/ hose clamps..... to be continued............ 10 Link to comment Share on other sites More sharing options...
silver911 Posted June 2, 2022 Author Share Posted June 2, 2022 A fair bit of scratching done today Final eight tie rods made from metals to replace the kit parts..... Then the torsion bar...seen in amongst the kit tie rods above...which...having made the front one from metals...I had to repeat it with the rear one...a lot of tiny bits and careful bending resulted in this..... The two tiny brass sleeves are for the eye bolts (too much play in the holes)...I will cut the brass rod to size when it's ready to be assembled. Another tiny piece modified...just for the hell of it..... A lot of metal priming to be done now. to be continued.............. 6 Link to comment Share on other sites More sharing options...
silver911 Posted June 19, 2022 Author Share Posted June 19, 2022 Not sure if updates are still of interest to others...but work is still progressing. First up...the rear radiator stone guards. In the pic are the three iterations...1 (far left) too big in scale and size...2 (middle) better scale but too small in size...3 (far right) good scale and size..... Then it was time to get all the bits and fixings onto the sub frame...including the above stone guards..... Another area to receive detailing/modifying...the rear wing stays. Instead of using the plastic stubs (moulded onto the gearbox for mounting) they now have proper bolts as per the 1:1...and the kit plastic cross brace has been replaced with metals and end fixing bolts..... Along with the above...work continues on the engine/gearbox assembly. I had to revise and remake the brake lines...the first attempt interfered with the wing stays!...ooopsie. The first of the metal tie bars are bolted in place...along with some added cables and wires..... Still a lot more to be added...but beginning to take shape. to be continued............ 13 Link to comment Share on other sites More sharing options...
Redstaff Posted June 19, 2022 Share Posted June 19, 2022 Hi Ron Your updates are always still welcome mate. The engine looks absolutely superb as is to be expected, need to have a proper read through of the site as I've been away for a week or so, so much progression has gone on all over Ian 1 Link to comment Share on other sites More sharing options...
bigbadbadge Posted June 20, 2022 Share Posted June 20, 2022 Oh wow that engine is fantastic, a masterpiece in fact. Great work on all, love the injectors and trumpets. Cracking work Chris 1 Link to comment Share on other sites More sharing options...
Vesa Jussila Posted June 20, 2022 Share Posted June 20, 2022 Looks really good. And there is always something to learn from you. 1 Link to comment Share on other sites More sharing options...
