Marklo Posted January 16, 2022 Posted January 16, 2022 (edited) I’ve been threatening to build a Salamander for ages so here goes. I have a Mr Craft Camel earmarked as a donor kit, now afaik the Salamander is not all that similar to the camel ( a bit like the Nimrod vs the Fury of the Gladiator vs the Gauntlet) so it may be a case that the wheels snd the engine ( possibly) are the only transferable parts, it may also be the case that it’s easier to make new components, so onwards and we’ll see how we go. Next step is to organise a set of 1/48 plans. Blueprints.com I think . Since virtually nothing from the Camel matches the Salamander I’m going to make it as a TF1, which is pretty much a standard camel but had a pair of downward facing Lewis guns installed, the twin Vickers removed and a third overwing Lewis as well as 300lbs of armour plate. Edited May 28, 2022 by Marklo 12
Col. Posted January 16, 2022 Posted January 16, 2022 Fine subject choice and it's always good to watch one of your scratch-built projects take shape Must say though that the Salamander looked more like a camel to me than the Sopwith Camel did. 1
CliffB Posted January 17, 2022 Posted January 17, 2022 I've just Googled it Mark, as it doesn't look much like a ground attack aircraft to me! So I now know that it was in fact designed specifically for ground attack - complete with an armoured forward fuselage. Every day's a school day Cheers 1
desert falcon Posted January 17, 2022 Posted January 17, 2022 That is so sweet, will be following with great interest. 1
Marklo Posted January 18, 2022 Author Posted January 18, 2022 I have my plans, next to scale them; oddly the wingspan of the one I’m modelling was 30 feet and 1 1/2 inches strange, anyhoo that’s 191 mm in 1/48. 1
Marklo Posted January 19, 2022 Author Posted January 19, 2022 So I’ve scaled my plans and compared my camel and basically the wheels, seat, engine ( although it should be a Bentley for the Salamander) and cowl are the only parts that would be worth reworking. Sooo I think I’ll snag wheels, seats and a Bentlybfrom my homemade resin parts and just scratch the rest. The Camel gets built as a TF 1 ( the TF stood for trench fighter btw) 2
John Masters Posted January 20, 2022 Posted January 20, 2022 I will be following this one if you don't mind! 1
Marklo Posted January 21, 2022 Author Posted January 21, 2022 The Camel, molded on markings and trenches for wing ribs. Good decal sheet though. The ‘sprue shot’ for the salamander scaled plans and homemade resin wheels, engine and seat. 2
Marklo Posted January 22, 2022 Author Posted January 22, 2022 (edited) Plastic has been cut. I’m going to cut a slot in both wings and set a brass rod in then score the wing and set the diehedral, before skinning the wing in lined 10 thou card. It’s the same method I used for the Sage and gives a sturdy result that’s easy to set correctly. In case you’ve noticed the different wing profile from the plan, I’m modelling one of the early prototypes that had unbalanced ailerons so as to be able to finish it in the experimental camouflage scheme above. Fuselage blanks next. I’ll probably need to mold a cowl and the foredeck/turtledeck. On the TF1 front all trenches and molded insignia have been sanded off. Need to find a few extra lewises from the spares box. Edited January 22, 2022 by Marklo 3
Marklo Posted January 23, 2022 Author Posted January 23, 2022 (edited) Plastic has been stuck together. The wing blanks need to be shaped and skinned next. I also need to figure out how I’ll handle the ‘cheeks’ and the upper decking. ( probably need to mold both) Definitely molded and probably multiple parts, quite a complex shape. Edited January 23, 2022 by Marklo 4
Marklo Posted January 23, 2022 Author Posted January 23, 2022 (edited) A bit more progress. On the left is the fuselage, now with cowling, and on the right is the start of the buck for the cheeks and upper decking. Also based on the photo above my scale drawings are clearly incorrect, so I will be shaping the nose area as per the photo not my plans. Edited January 23, 2022 by Marklo 7
Marklo Posted January 26, 2022 Author Posted January 26, 2022 Horizontal tail skinned, scribed and attached, cowl nearly finished, just needs a bit of dremelling out and the wings are sanded but not shaped, should be able to get them finished by the weekend. The buck is finished. I think I’ll split into Tom and two sides for molding. I may get a chance to do some molding tomorrow; the cheeks should plung mold easily enough but I think I’ll Vac the decking. 5
Marklo Posted January 27, 2022 Author Posted January 27, 2022 (edited) split the buck into three and bent for a vac form. I managed to get all three in one go, not perfect as I had some issues with clamping but not bad. Agtrr a bit of cleanup. The headrest is a little too wide but I’ll fix that with filler and a bit of sanding, otherwise good. The upper wing is nearly done. Probably need to work on the interior next. Edited January 27, 2022 by Marklo 6
Col. Posted January 27, 2022 Posted January 27, 2022 I'm not seeing your photos at the moment but the descriptions read like good progress
psdavidson Posted January 27, 2022 Posted January 27, 2022 3 hours ago, Col. said: I'm not seeing your photos at the moment Same for me. It looks like the image links are HTTP instead of HTTPS. Allowing insecure content in the settings will fix it but the links should be updated if possible. /P
81-er Posted January 27, 2022 Posted January 27, 2022 I can see them if I right click on the link and select "open image in new tab". Good progress however, Marklo 👍 James
Marklo Posted January 27, 2022 Author Posted January 27, 2022 Not sure what is happening I’m not doing anything different (at least I don’t think I am) for now I’m going to assume that either the forum or village photos are changing something and try again tomorrow 1
desert falcon Posted January 28, 2022 Posted January 28, 2022 I see them, just takes a bit longer than usual to show them (size?). Good work !!
Marklo Posted January 29, 2022 Author Posted January 29, 2022 Wings trimmed and dihedral set. Lower wing attached. Interior snd finishing the upper decking next. Although I may add the undercarriage first. Must get the TF1 going. 5
Toryu Posted January 29, 2022 Posted January 29, 2022 Nice progress on the wings Marklo. Sorry if I missed this: What do you use as skin over the stringers? 1
Marklo Posted January 30, 2022 Author Posted January 30, 2022 (edited) 20 hours ago, Toryu said: Sorry if I missed this: What do you use as skin over the stringers? I use a variant of the Harry Woodward method of 10 thou card ruled with a ballpoint pen then attached to the shaped blank with double sided sticky tape and ca on the trailing edges. When ruling the card I make sure to have about three or four sheets of paper under it, this compresses and allows for a fairly deep embossed line from the pen. It gives a subtle ribbing effect. Edited January 30, 2022 by Marklo 1 1
Marklo Posted February 3, 2022 Author Posted February 3, 2022 The upper deck fitted and ready for the interior. 4
John Masters Posted February 8, 2022 Posted February 8, 2022 Looking great Marklo. This is a brave endeavour. 1
Marklo Posted February 20, 2022 Author Posted February 20, 2022 Undercarriage ( cocktail sticks and brass rod) dry fitted on the salamander which is now sporting a coat of grey primer. 3
Col. Posted February 20, 2022 Posted February 20, 2022 Are the cocktails sticks a mock-up or the start of the manufacturing process? 1
