Chipmunk T.10 Wheels (648699 for Airfix) 1:48
1:48 Eduard Brassin
Kit wheels are generally in two halves, which means you have the resultant joins to deal with, possible mould-slip issues on single part wheels, and sometimes less than stellar detail due to the moulding limitations of styrene injection technology, especially in the tread department.  That's where replacement resin wheels come in, with their lack of seamline and superior detail making a compelling argument.  They are also usually available at a reasonable price, and can be an easy introduction to aftermarket and resin handling, as they are usually a drop-in replacement.
As usual with Eduard's Photo-Etch (PE), small Brassin, and Mask sets, they arrive in a flat resealable package, with a white backing card protecting the contents and the instructions that are sandwiched between.  There are two wheels included in the package, each one on its own casting block, and there is also a small sheet of pre-cut kabuki tape masks, allowing you to cut the demarcation between tyres and hubs with little effort. Detail is excellent, and includes the raised Good Year name with winged boot and tyre stats on the sidewalls, a circumferential tread on the contact patch, and hub detail in the centre.  The tyres have a very slight sag to simulate the weight of the aircraft on them, and they are joined to the casting block there, so clean-up is simple and you don’t risk damaging the detail.  Once liberated from their block, they are a straight-forward drop-in replacement.
Highly recommended.
Review sample courtesy of
