Big_Bad_Bill Posted January 13 Share Posted January 13 Hi all, it the third time if doing this kit - it is my favourite although it needs the Edvard PE. I always loved the Warrior after spending a week in the back of a 511 bouncing around Salisbury Plain. Paints are Mig - NATO green (with a few drops of oily ochre) and black lighted with white. Apart from the Edvard etch, I drilled out the lights (head and side), filled them with resin, and used stick on mirrors for the drivers mirrors. 31 2 Link to comment Share on other sites More sharing options...
Homer Posted January 14 Share Posted January 14 Congratulations on a fine piece of work well done 1 Link to comment Share on other sites More sharing options...
LeeM Posted January 14 Share Posted January 14 Hello Bill Nicely done. I am currently having a go at the Iraq 2003 version. Will not be anywhere as good as yours though. 1 Link to comment Share on other sites More sharing options...
Big_Bad_Bill Posted January 14 Author Share Posted January 14 Cheers Folks. Thank you for your kind words. I'm chuffed with how well it come out. @LeeM - good luck with the Iraq 2003 version, I'm sure yours will come out as good if not better. I can't face doing anything sand coloured although a lot of the wagons were virtually green and black by the end due to sand blasting by the wind and the paint being applied in freezing conditions back in Germany. Link to comment Share on other sites More sharing options...
LeeM Posted January 14 Share Posted January 14 1 hour ago, Big_Bad_Bill said: Cheers Folks. Thank you for your kind words. I'm chuffed with how well it come out. @LeeM - good luck with the Iraq 2003 version, I'm sure yours will come out as good if not better. I can't face doing anything sand coloured although a lot of the wagons were virtually green and black by the end due to sand blasting by the wind and the paint being applied in freezing conditions back in Germany. I did toy with having the green and black coming through but a bit beyond my skill level at the moment. Link to comment Share on other sites More sharing options...
Steve 1602 Posted January 14 Share Posted January 14 Excellent build! I think the base vehicle still looks the part. Much cleaner than with all the special armour and other fits for operational deployments. It’s such a shame that the decision was taken to remove Warrior from service. A great bit of kit. Steve 1 Link to comment Share on other sites More sharing options...
Lazy Modeller Posted January 14 Share Posted January 14 Excellent build you have there! Too bad the photos do not help to show the work done. Cheers LM 1 Link to comment Share on other sites More sharing options...
Big_Bad_Bill Posted January 14 Author Share Posted January 14 3 hours ago, LeeM said: I did toy with having the green and black coming through but a bit beyond my skill level at the moment. There are plenty of video guides on youtube. The trick is to paint the green and black, add a layer of hairspray and then the desert yellow. The hairspray dissolves in water so when you gently rub it with a wet brush it lifts parts of the top coat. 1 Link to comment Share on other sites More sharing options...
Big_Bad_Bill Posted January 14 Author Share Posted January 14 3 hours ago, Steve 1602 said: Excellent build! I think the base vehicle still looks the part. Much cleaner than with all the special armour and other fits for operational deployments. It’s such a shame that the decision was taken to remove Warrior from service. A great bit of kit. Steve Completely agree. It never looked right with the add on armour and I'm not convinced Boxer will cut it, even though it is meant to be excellent. It's a bit melancholy for me as Warrior came into service as I joined the Army and it'll leave about the same time I do. Link to comment Share on other sites More sharing options...
MRMRL Posted January 14 Share Posted January 14 That's a really nice build and paint job, I'd be very happy if I could pull that off, well done 1 Link to comment Share on other sites More sharing options...
Steve 1602 Posted January 14 Share Posted January 14 1 hour ago, Big_Bad_Bill said: Completely agree. It never looked right with the add on armour and I'm not convinced Boxer will cut it, even though it is meant to be excellent. It's a bit melancholy for me as Warrior came into service as I joined the Army and it'll leave about the same time I do. I think from a protection level Boxer claims to have as good protection as WR base armour, but whether it has the stretch to accommodate additional armour packs - I don’t know. The mobility of Boxer is apparently very impressive, but it’s a massive vehicle and I do wonder about it’s ability to manoeuvre in urban environments- there’s no neutral turn option That’s a long shift you’ve put in! Good effort. I’m starting to get to the point where time outside is catching up with time inside! Steve 1 Link to comment Share on other sites More sharing options...
Big_Bad_Bill Posted January 14 Author Share Posted January 14 31 minutes ago, Steve 1602 said: I think from a protection level Boxer claims to have as good protection as WR base armour, but whether it has the stretch to accommodate additional armour packs - I don’t know. The mobility of Boxer is apparently very impressive, but it’s a massive vehicle and I do wonder about it’s ability to manoeuvre in urban environments- there’s no neutral turn option That’s a long shift you’ve put in! Good effort. I’m starting to get to the point where time outside is catching up with time inside! Steve 34 years and counting, regular and FTRS. And I'm still called a redarse!. Between Ajax and Boxer Chally is looking positively petite. Link to comment Share on other sites More sharing options...
Steve 1602 Posted January 14 Share Posted January 14 1 hour ago, Big_Bad_Bill said: 34 years and counting, regular and FTRS. And I'm still called a redarse!. Between Ajax and Boxer Chally is looking positively petite. Haha! That’s a phrase I haven’t heard for a while - everyone is a sprog to someone! Link to comment Share on other sites More sharing options...
Bish Posted January 14 Share Posted January 14 That came out really well, very nicely finished, weathering is spot on. A tarp over the side bin would be a nice addition. Have you tried any of the Accurate Armour sets, there 511 one is nice though has some ommisions. Link to comment Share on other sites More sharing options...
Big_Bad_Bill Posted January 14 Author Share Posted January 14 11 minutes ago, Bish said: That came out really well, very nicely finished, weathering is spot on. A tarp over the side bin would be a nice addition. Have you tried any of the Accurate Armour sets, there 511 one is nice though has some ommisions. Thanks. Thought about the AA add-ons, but they cost more than the original kit. Link to comment Share on other sites More sharing options...
Bullbasket Posted January 15 Share Posted January 15 Nice build, well painted with just the right amount of weathering. Great work. John. 1 Link to comment Share on other sites More sharing options...
StuartH Posted January 15 Share Posted January 15 Brilliant model. I love the paintwork and the slightly hazy colour effects you've achieved 1 Link to comment Share on other sites More sharing options...
ivan-o Posted January 15 Share Posted January 15 Nicely done if you do a fourth one though I recommend this kit for the interior Ivan Link to comment Share on other sites More sharing options...
Bish Posted January 15 Share Posted January 15 18 hours ago, Big_Bad_Bill said: Thanks. Thought about the AA add-ons, but they cost more than the original kit. Your not worng but they are nice. I might well get another one and do a 510 with the sets ivan mentioned. Only thing that puts me off is the wheel stations on the right side which can't be corrected. Link to comment Share on other sites More sharing options...
Big_Bad_Bill Posted January 15 Author Share Posted January 15 18 minutes ago, Bish said: Your not worng but they are nice. I might well get another one and do a 510 with the sets ivan mentioned. Only thing that puts me off is the wheel stations on the right side which can't be corrected. Yep but it's the only option if you want a bog standard 510, although they are like rocking horse poo. I had to get this one from Poland. I don't understand why Airfix doesn't re-box it - they do other Academy kits. Link to comment Share on other sites More sharing options...
Bish Posted January 15 Share Posted January 15 Airfix might get round to it. There are a couple on e-bay, pity Academy only did it with the Chobham, i prefer it without the extra armour. Its how i remember them best. I am hoping Meng back date there then we might get a more accurate one. Link to comment Share on other sites More sharing options...
ivan-o Posted January 15 Share Posted January 15 26 minutes ago, Bish said: Airfix might get round to it. There are a couple on e-bay, pity Academy only did it with the Chobham, i prefer it without the extra armour. Its how i remember them best. I am hoping Meng back date there then we might get a more accurate one. No problem with the armour Bish you just leave it off Link to comment Share on other sites More sharing options...
edjbartos Posted January 15 Share Posted January 15 Very nicely built, painted and weathered. Well done, really excellent... Ed 1 Link to comment Share on other sites More sharing options...
vytautas Posted January 15 Share Posted January 15 On 1/14/2022 at 6:14 PM, Lazy Modeller said: Excellent build you have there! Too bad the photos do not help to show the work done. Seconded. Photos of a model so well done should be bigger. Vytautas Link to comment Share on other sites More sharing options...
Bish Posted January 16 Share Posted January 16 3 hours ago, ivan-o said: No problem with the armour Bish you just leave it off Ye, that's what i did on my 511, i just hate having all that extra plastic. 1 Link to comment Share on other sites More sharing options...
