bootneck Posted January 11, 2022 Share Posted January 11, 2022 I normally use a spray can of Humbrol 86 Light Olive for some of my painting; however, the cost has risen to £6.29 and I cannot afford that now ( No comments about pricing please!) The markings on the can state the RGB is 100, 105, 83. which leads me to ask if other paints can be identified by the RGB colours? I have quite a lot of Vallejo Model Air paints and wondered if there was a way I could match the RGB of Humbrol's 86 Light Olive to that of Vallejo paints. Any recommendations please? Mike Link to comment Share on other sites More sharing options...
Jamie @ Sovereign Hobbies Posted January 11, 2022 Share Posted January 11, 2022 There's a long answer and a short one. I'll aim for a happy medium. (Almost) Any colour can be described by RGB coordinates although that is but one colourspace model and not one favoured by modern industry. There are variants on RGB in the modern world, sRGB and AdobeRGB being common ones. They give slightly different 3-number descriptions of the same colour, so one needs to be clear which colourspace model is in use. Next is the determination of those coordinates. There's are variations on the right way to do it, and probably more terrible ways than I am aware of. To do it correctly, you need a dried sample on a flat surface, illumination exclusively from a source you know the temperature and spectral quality of (i.e. you need to know which wavelengths of light in the visible spectrum are there from the source, not just the average wavelength) and you need your sample orientated correctly to the light source, and a calibrated instrument to measure the reflected light from the source bouncing off your sample, and you need to know the geometric angles of this light source - sample - receiving instrument arrangement. The exact same sample will give different results as you play with any of these parameters. Thus, for objective colour work, there are scientific conventions to fix these. Some conventions have been more robust than others; illuminants have improved since some were colourblind in certain wavelengths, and the observer angle has evolved over time too. You can work with old data, but you need to know how it was all set up in the first place, or the same results will reverse-engineer a different colour to the one they measured at the time. That's the right way to do it. It involves equipment most don't have, and a knowledge of stuff most don't care about. The health warning on sets of RGB values anyone may give you either directly or via websites is how they got their RGB values. Only last year a certain author conceded on this forum that they didn't understand colourspace models and the RGB samples on their website were just guesses arrived at by playing with the 3 RGB numbers - which you can do in Microsoft Paint. Probably few are quite this naive, but there are some who think it's possible to get good results from scanning a sample with a plain old scanner plugged into their computer then use the colour sampler tool in e.g. Microsoft Paint. This doesn't work. It still doesn't work even if the person tries to baffle you with some BS intermediate compensatory steps to change the scan. Scanners do not have calibrated broad-spectrum light sources nor do they have offset observer angles. You might be best using one of the popular mobile phone apps. I'd still be hessitant to endorse apparent matches and still don't know for sure how they gather their numeric colour data - one such developer just asked me for mine* which if others did may mean at least some of it is reliable. It would probably give you better results than trying to handball this yourself without having to spend a lot of money gathering samples. *I politely declined to feature on the app 4 Link to comment Share on other sites More sharing options...
PhantomBigStu Posted January 11, 2022 Share Posted January 11, 2022 an interesting question, I’d ask the same but for decals as I have a shade of green to find a paint for Link to comment Share on other sites More sharing options...
CFster Posted February 28 Share Posted February 28 On 1/11/2022 at 5:57 AM, bootneck said: I normally use a spray can of Humbrol 86 Light Olive for some of my painting; however, the cost has risen to £6.29 and I cannot afford that now ( No comments about pricing please!) The markings on the can state the RGB is 100, 105, 83. which leads me to ask if other paints can be identified by the RGB colours? I have quite a lot of Vallejo Model Air paints and wondered if there was a way I could match the RGB of Humbrol's 86 Light Olive to that of Vallejo paints. Any recommendations please? Mike If you’re talking about shopping online for a match, all colors can identified by RGB colors provided the manufacturer has posted correct color swatches on their websites. More on this later. The are “color picker” tools that you can download onto your computer or mobile device that will return the RGB, or HEX value of any color you point it at on your screen. This takes the guesswork out of if your screen is calibrated correctly or not, because Tamiya or Vallejo entered a specific color RGB/HEX code onto their webpage when they created it. That never changes no matter who or how it’s looked at. The problem is there are 16,777,216 possible colors in the RGB gamut. So it’s not as if you can get a value, then say it’s “close” to your paint. Chances are it’s actually thousands of shades different. There are some online color converters such as https://www.modelshade.com, which uses a computer algorithm to determine which colors in its database are “close”. Problem is it’s updated rarely and lacks many lines of paints. Getting back to manufacturers posting swatches on their sites, one company that infuriates me is Gunze Sangyo. They don’t post any color samples for their paints on their webpage. Instead, they provide a link to their catalog, which is a PDF file. In my experience many of the colors displayed in the PDF aren’t even remotely close to what’s actually in the bottle. This probably happened when they converted whatever the source document was into PDF and the color gamut got screwed up. That they let this go is remarkable… Link to comment Share on other sites More sharing options...
Troy Smith Posted February 28 Share Posted February 28 (edited) On 11/01/2022 at 10:57, bootneck said: I have quite a lot of Vallejo Model Air paints and wondered if there was a way I could match the RGB of Humbrol's 86 Light Olive to that of Vallejo paints. Any recommendations please? Hi Mike As other have noted about RGB... But, Creative Models have a paint conversion chart, which has various pages and "matches" It most likely gives manufacturers stated equivalents, but that as i said gives a ballpark idea of a "match" It does at least give you some idea http://www.creativemodels.co.uk/paint_conversion.php/manufacturers_id/9/page/2 HUM086 Humbrol - Matt Light Olive + Model Color 895 Taniya -X-26 XF26 Model Air - 007 Revell - 361 RAL 6003 which come out as VAL007 Model Air - Olive Green , note it does have a RAL code as well. the conversion pages is not that obvious, right down at the bottom left of the page is a drop down menu "paint conversion" this is the Model Air page http://www.creativemodels.co.uk/paint_conversion.php?manufacturers_id=2 One thing, if pennies are tight, buy Model Color and thin it, as Model Air is pre thinned..... Model Color http://www.creativemodels.co.uk/paint_conversion.php?manufacturers_id=1 it's a larger range of colours as well. HTH PS if you have RAL, FS595 or BSC381 e-paint have various paint charts EG RAL 6003 https://www.e-paint.co.uk/lab-hlc-rgb-lrv-values.asp?cRange=RAL+Classic&cRef=RAL+6003&cDescription=Olive+green this has various digital descriptors and then a page of matches with a degree of closeness if nothing else it give an idea of what the colour is, noet that RAL 6003 is a very close match to FS 34095 and close to BS831C 220 Olive Green E-paint also sell fan decks, the RAL -K7 classic is the cheapest set of chips that I know of. Hours of fun await.... or endless rabbit hole loops..... Edited February 28 by Troy Smith added a PS 1 Link to comment Share on other sites More sharing options...
Casey Posted February 28 Share Posted February 28 (edited) 1 hour ago, Troy Smith said: I have quite a lot of Vallejo Model Air paints and wondered if there was a way I could match the RGB of Humbrol's 86 Light Olive to that of Vallejo paints. Any recommendations please? Yes. Measure Humbrol 86, and all Vallejo paints with a spectrophotometer and compare the readouts. And never use RGB for color matching unless you have no other choice. It is an old thread, but I have a partial answer for that question now - partially because I only have 122 Vallejo paints measured so far. Target: DB0085 | No 86 | Light Olive - Matt | GU 9.2, RGB: #5B5D4E (L*=38.62, a=-2.76, b=8.37) Found a match in: Vallejo (compared with 122 paints) DE00: 1.44 - #585A4B - Vallejo - 71.294 | US Forest Green | US Verde Bosque | FS34079 | ANA631 | GU 3.1 (L*=37.30, a=-2.06, b=8.10) This is a pretty close match. ... re-reading @Jamie @ Sovereign Hobbies post, I should mention how and where I got to those RGB values from. I made Humbrol 86 (and Vallejo Paints, too) paint drawdowns on a clear-coated black&white drawdown chart using a 10mil wet film applicator. It looked more or less like that: Then I let them dry for at least a week and measured them with D65/10deg SCI calibrated spectrophotometer (D65 is a standard daylight light source, 10deg is a CIE standard color observer, SCI means I included specular component inside measurements, which removes gloss level factor from readouts). My device uses d/8 integrating sphere geometry. (It means it uses a titanium white-covered hollow sphere that illuminates the target sample from all directions (letter d in geometry) and the measurement is taken at an 8-degree angle from being fully vertical over the sample.) The resulting data were converted to CIE L*a*b* color space to calculate the color difference - using mentioned daylight (D65) white point and observer (model based on empirical data from measurements of average human color vision). The color difference is expressed as the DE00 value - see https://en.wikipedia.org/wiki/Color_difference). This was the data used for finding the closest color match. Only then I've used conversion to sRGB. Not the Adobe RGB or any other RGB. And the two colored squares you see on the screen are your monitor's interpretation of those RGB numbers. I know it is a bit overkill, considering commercial model paint vendors have batch variations larger than 2.5 DE, but it is still better than their label-slapped equivalences to targets they are SUPPOSED to be matching. Why? Because this: Target: 34079, RGB: #4A4E40 (L*=32.05, a=-3.25, b=7.39) Found a match in: Vallejo (compared with 122 paints) DE00: 1.26 - #4B4D41 - Vallejo - 71.011 | Dark Green RLM83 | RLM83 Dunkelgrün | RLM83 | GU 1.2 (L*=32.11, a=-2.24, b=7.01) The labeled 34079 color equivalence from Vallejo is not the best color match for 34079 from the real FS color deck in their paint range. It is actually way too light for all FS samples I have. 1956 FS34079 | 1984 FS34079 | 1994 FS34079 | 34079 AMS 595A | Vallejo 71.294 Edited February 28 by Casey 5 1 Link to comment Share on other sites More sharing options...
CFster Posted March 4 Share Posted March 4 On 2/28/2023 at 3:43 PM, Casey said: Yes. Measure Humbrol 86, and all Vallejo paints with a spectrophotometer and compare the readouts. And never use RGB for color matching unless you have no other choice. It is an old thread, but I have a partial answer for that question now - partially because I only have 122 Vallejo paints measured so far. Target: DB0085 | No 86 | Light Olive - Matt | GU 9.2, RGB: #5B5D4E (L*=38.62, a=-2.76, b=8.37) Found a match in: Vallejo (compared with 122 paints) DE00: 1.44 - #585A4B - Vallejo - 71.294 | US Forest Green | US Verde Bosque | FS34079 | ANA631 | GU 3.1 (L*=37.30, a=-2.06, b=8.10) This is a pretty close match. ... re-reading @Jamie @ Sovereign Hobbies post, I should mention how and where I got to those RGB values from. I made Humbrol 86 (and Vallejo Paints, too) paint drawdowns on a clear-coated black&white drawdown chart using a 10mil wet film applicator. It looked more or less like that: Then I let them dry for at least a week and measured them with D65/10deg SCI calibrated spectrophotometer (D65 is a standard daylight light source, 10deg is a CIE standard color observer, SCI means I included specular component inside measurements, which removes gloss level factor from readouts). My device uses d/8 integrating sphere geometry. (It means it uses a titanium white-covered hollow sphere that illuminates the target sample from all directions (letter d in geometry) and the measurement is taken at an 8-degree angle from being fully vertical over the sample.) The resulting data were converted to CIE L*a*b* color space to calculate the color difference - using mentioned daylight (D65) white point and observer (model based on empirical data from measurements of average human color vision). The color difference is expressed as the DE00 value - see https://en.wikipedia.org/wiki/Color_difference). This was the data used for finding the closest color match. Only then I've used conversion to sRGB. Not the Adobe RGB or any other RGB. And the two colored squares you see on the screen are your monitor's interpretation of those RGB numbers. I know it is a bit overkill, considering commercial model paint vendors have batch variations larger than 2.5 DE, but it is still better than their label-slapped equivalences to targets they are SUPPOSED to be matching. Why? Because this: Target: 34079, RGB: #4A4E40 (L*=32.05, a=-3.25, b=7.39) Found a match in: Vallejo (compared with 122 paints) DE00: 1.26 - #4B4D41 - Vallejo - 71.011 | Dark Green RLM83 | RLM83 Dunkelgrün | RLM83 | GU 1.2 (L*=32.11, a=-2.24, b=7.01) The labeled 34079 color equivalence from Vallejo is not the best color match for 34079 from the real FS color deck in their paint range. It is actually way too light for all FS samples I have. 1956 FS34079 | 1984 FS34079 | 1994 FS34079 | 34079 AMS 595A | Vallejo 71.294 I’m curious what you do with this information? Unless you’ve used this physical method on every paint out there and built a database, then you can’t use it to obtain matches. Better to use the RGB value of color swatches posted by the manufacturer. Link to comment Share on other sites More sharing options...
Casey Posted March 4 Share Posted March 4 (edited) 1 hour ago, CFster said: I’m curious what you do with this information? Unless you’ve used this physical method on every paint out there and built a database, then you can’t use it to obtain matches. Better to use the RGB value of color swatches posted by the manufacturer. RGB is sadly not a defined standard, the colors can be more off than is acceptable for paints. But I agree it is usually all you have from vendors. It is also not even possible to directly compare RGB between one vendor's swatches and another unless they are measured by the same spectrometer setup (which means: the same geometry and other settings) and uncorrected for web/printing. I am aware of only one relatively modeller-related database that does provide these details - https://www.e-paint.co.uk/ It is also next to impossible to match RGB from photo to paint without some extra information, like a good color reference card on the same photo, context, some other reference, or at least information about camera settings and date and time. That's why I make my own databases. I did indeed use this physical method on all paints that I have and I do it because paints and colors are my passion. For Humbrol and Revell I can now give definite answers since I have all their paints on their ranges (or all I could get in Humbrol's case). Here are the paint samples I have for comparison so far (open spoiler to see, it is a long list): Spoiler A1701 | No 157 | Azure Blue - Matt | GU 1.3 A6238 | No 187 | Dark Stone - Matt | GU 1.5 AA0046 | No 46 | Orange - Matt | GU 8.5 AA0059 | No 5 | Dark Admiralty Grey - Gloss | GU 90.8 AA0076 | No 7 | Light Buff - Gloss| GU 95.2 AA0134 | No 12 | Copper - Metallic | GU 8.7 | Metallic AA0173 | No 173 | Track Colour - Matt | GU 1.3 AA0234 | No 234 | Dark Flesh - Matt | GU 4.4 AA0343 | No 31 | Slate Grey - Matt | GU 7.5 AA0360 | No 33 | Black - Matt | GU 2.2 AA0549 | No 50 | Green Mist - Metallic | GU 94.3 | Metallic AA0552 | No 51 | Sunset Red - Metallic | GU 95.3 | Metallic AA0583 | No 53 | Gunmetal - Metallic | GU 1.2 | Metallic AA0727 | No 65 | Aircraft Blue - Matt | GU 5.0 AA0770 | No 66 | Olive Drab - Matt | GU 5.9 AA0775 | No 70 | Brick Red - Matt | GU 3.1 AA0802 | No 73 | Wine - Matt | GU 1.3 AA0816 | No 74 | Linen - Matt | GU 7.9 AA0833 | No 75 | Bronze Green - Matt | GU 2.0 AA0847 | No 76 | Uniform Green - Matt | GU 2.1 AA0850 | No 77 | Navy Blue - Matt | GU 1.7 AA0878 | No 79 | Blue Grey - Matt | GU 4.3 AA0905 | No 82 | Orange Lining - Matt | GU 4.1 AA0919 | No 83 | Ochre - Matt | GU 5.3 AA0922 | No 84 | Mid Stone - Matt | GU 4.1 AA0967 | No 87 | Steel Grey - Matt | GU 6.9 AA0970 | No 88 | Deck Green - Matt | GU 2.0 AA1105 | No 100 | Red Brown - Matt | GU 3.8 AA1119 | No 101 | Mid Green - Matt | GU 2.9 AA1167 | No 105 | Marine Green - Matt | GU 7.1 AA1287 | No 116 | US Dark Green - Matt | GU 2.1 AA1314 | No 119 | Light Earth - Matt | GU 4.5 AA1328 | No 120 | Light Green - Matt | GU 3.1 AA1331 | No 121 | Pale Stone - Matt | GU 7.0 AA1376 | No 125 | US Dark Grey - Satin | GU 11.4 AA1393 | No 126 | US Medium Grey - Satin | GU 37.9 AA1417 | No 128 | US Compass Grey - Satin | GU 31.6 AA1420 | No 129 | US Gull Grey - Satin | GU 21.6 AA1448 | No 131 | Mid Green - Satin | GU 21.1 AA1451 | No 132 | Red - Satin | GU 11.0 AA1465 | No 133 | Brown - Satin | GU 33.0 AA1496 | No 28 | Camouflage Grey - Matt | GU 17.2 AA1523 | No 140 | Gull Grey - Matt | GU 5.4 AA1568 | No 144 | Intermediate Blue - Matt | GU 4.8 AA1571 | No 145 | Medium Grey - Matt | GU 11.6 AA1599 | No 147 | Light Grey - Matt | GU 6.1 AA1609 | No 148 | Radome Tan - Matt | GU 19.1 AA1612 | No 149 | Dark Green - Matt | GU 2.9 AA1626 | No 150 | Forest Green - Matt | GU 1.4 AA1729 | No 159 | Khaki Drab - Matt | GU 2.0 AA1780 | No 164 | Dark Sea Grey - Satin | GU 25.9 AA1804 | No 166 | Light Aircraft Grey - Satin | GU 54.6 AA2240 | No 240 | RLM 02 Grau - Matt | GU 3.9 AA2241 | No 241 | RLM 70 Schwartzgrun - Matt | GU 2.2 AA2241 | No 241 | RLM 70 Schwartzgrun - Matt | GU 3.0 AA2242 | No 242 | RLM 71 Dunkelgrun - Matt | GU 1.0 AA2247 | No 247 | RLM 76 Lichtblau - Matt | GU 13.9 AA2248 | No 248 | RLM 78 Himmelblau - Matt | GU 3.0 AA2252 | No 252 | RLM 82 Olivgrun - Matt | GU 2.2 AA2253 | No 253 | RLM 83 Dunkelgrun - Matt | GU 2.4 AA6330 | No 195 | Dark Green - Satin | GU 31.5 AA6344 | No 196 | Light Grey - Satin | GU 29.9 AA6389 | No 200 | Pink - Gloss | GU 91.8 AA6392 | No 201 | Black - Metallic | GU 91.3 | Metallic AA6608 | No 220 | Racing Red - Gloss | GU 100.0 AA7222 | No 222 | Moonlight Blue - Metallic | GU 95.0 | Metallic AA7224 | No 224 | Dark Slate Grey - Matt | GU 3.0 AA7225 | No 225 | Middle Stone - Matt | GU 2.6 AB0047 | No 47 | Sea Blue - Gloss | GU 65.0 AB0052 | No 52 | Baltic Blue - Metallic | GU 78.7 | Metallic AB0065 | No 65 | Aircraft Blue - Matt | GU 6.3 AB0078 | No 78 | Cockpit Green - Matt | GU 4.1 AB0090 | No 90 | Beige Green - Matt | GU 9.5 AB0091 | No 91 | Black Green - Matt | GU 1.6 AB0094 | No 94 | Brown Yellow - Matt | GU 2.2 AB0104 | No 104 | Oxford Blue - Matt | GU 1.4 AB0145 | No 145 | Medium Grey - Matt | GU 2.4 AB0165 | No 165 | Medium Sea Grey - Satin | GU 17.2 AB0167 | No 167 | RAF Barley Grey - Satin | GU 9.2 AB0168 | No 168 | Hemp - Satin | GU 33.8 AB0226 | No 226 | Interior Green - Matt | GU 2.3 AB0230 | No 230 | Pru Blue - Matt | GU 1.3 AB0237 | No 237 | Desert Tan - Matt | GU 1.3 AB0238 | No 238 | Arrow Red - Gloss | GU 65.7 AB0239 | No 239 | British Racing Green - Gloss | GU 56.0 AB0240 | No 240 | RLM 02 Grau - Matt | GU 1.3 AB0241 | No 241 | RLM 70 Schwartzgrun - Matt | GU 4.0 AB0243 | No 243 | RLM 72 Grun - Matt | GU 1.5 AB0244 | No 244 | RLM 73 Grun - Matt | GU 1.4 AB0245 | No 245 | RLM 74 Graugrun - Matt | GU 0.9 AB0246 | No 246 | RLM 75 Grauviolett - Matt | GU 1.3 AB0247 | No 247 | RLM 76 Lichtblau - Matt | GU 12.9 AB0249 | No 249 | RLM 79 Sandgelb - Matt | GU 1.5 AB0251 | No 251 | RLM 81 Dunkelbraun - Matt | GU 0.7 AB0252 | No 252 | RLM 82 Olivgrun - Matt | GU 0.7 AB0253 | No 253 | RLM 83 Dunkelgrun - Matt | GU 0.8 DB0001 | No 1 | Primer | GU 5.6 DB0002 | No 2 | Emerald Green - Gloss | GU 79.8 DB0003 | No 3 | Brunswick Green - Gloss | GU 63.0 DB0009 | No 9 | Tan - Gloss | GU 76.9 DB0010 | No 10 | Service Brown - Gloss | GU 78.0 DB0011 | No 11 | Silver - Metallic | GU 6.7 | Metallic DB0012 | No 12 | Copper - Metallic | GU 48.2 | Metallic DB0014 | No 14 | French Blue - Gloss | GU 80.5 DB0015 | No 15 | Midnight Blue - Gloss | GU 79.7 DB0016 | No 16 | Gold - Metallic | GU 6.4 | Metallic DB0018 | No 18 | Orange - Gloss | GU 78.0 DB0019 | No 19 | Red - Gloss | GU 90.2 DB0020 | No 20 | Crimson - Gloss | GU 84.2 DB0021 | No 21 | Black - Gloss | GU 45.3 DB0022 | No 22 | White - Gloss | GU 65.9 DB0023 | No 23 | Duck Egg Blue - Matt | GU 4.3 DB0024 | No 24 | Trainer Yellow - Matt | GU 3.6 DB0025 | No 25 | Blue - Matt | GU 5.1 DB0026 | No 26 | Khaki - Matt | GU 3.4 DB0027 | No 27 | Sea Grey - Matt | GU 10.5 DB0029 | No 29 | Dark Earth - Matt | GU 3.6 DB0030 | No 30 | Dark Green - Matt | GU 3.2 DB0032 | No 32 | Dark Grey - Matt | GU 11.2 DB0033 | No 33 | Black - Matt | GU 3.9 DB0034 | No 34 | White - Matt | GU 6.5 DB0036 | No 36 | Pastel Green - Matt | GU 6.9 DB0037 | No 37 | Bright Green - Matt | GU 3.9 DB0038 | No 38 | Lime - Gloss | GU 82.8 DB0040 | No 40 | Pale Grey - Gloss | GU 65.2 DB0041 | No 41 | Ivory - Gloss | GU 58.2 DB0042 | No 42 | Pastel Violet - Matt | GU 4.8 DB0044 | No 44 | Pastel Blue - Matt | GU 7.0 DB0048 | No 48 | Mediterranean Blue - Gloss | GU 71.1 DB0053 | No 53 | Gunmetal - Metallic | GU 6.1 | Metallic DB0054 | No 54 | Brass - Metallic | GU 8.0 | Metallic DB0055 | No 55 | Bronze - Metallic | GU 6.7 | Metallic DB0056 | No 56 | Aluminium - Metallic | GU 14.6 | Metallic DB0057 | No 57 | Pink - Matt | GU 5.2 DB0058 | No 58 | Magenta - Matt | GU 6.4 DB0060 | No 60 | Scarlett - Matt | GU 3.5 DB0061 | No 61 | Flesh - Matt | GU 5.9 DB0062 | No 62 | Leather - Matt | GU 3.5 DB0063 | No 63 | Sand - Matt | GU 7.1 DB0064 | No 64 | Light Grey - Matt | GU 5.9 DB0067 | No 67 | Matt Tank Grey - Matt | GU 5.2 DB0068 | No 68 | Purple - Gloss | GU 79.1 DB0069 | No 69 | Yellow - Gloss | GU 93.5 DB0071 | No 71 | Oak - Satin | GU 19.7 DB0072 | No 72 | Khaki Drill - Matt | GU 6.8 DB0080 | No 80 | Grass Green - Matt | GU 3.6 DB0081 | No 81 | Pale Yellow - Matt | GU 1.9 DB0085 | No 85 | Black - Satin | GU 19.5 DB0085 | No 86 | Light Olive - Matt | GU 9.2 DB0089 | No 89 | Middle Blue - Matt | GU 5.4 DB0093 | No 93 | Desert Yellow - Matt | GU 4.5 DB0096 | No 96 | RAF Blue - Matt | GU 6.6 DB0098 | No 98 | Chocolate - Matt | GU 3.0 DB0099 | No 99 | Lemon - Matt | GU 8.5 DB0102 | No 102 | Army Green - Matt | GU 4.6 DB0103 | No 103 | Cream - Matt | GU 6.1 DB0106 | No 106 | Ocean Grey - Matt | GU 4.4 DB0109 | No 109 | WWI Blue - Matt | GU 4.7 DB0110 | No 110 | Natural Wood - Matt | GU 6.4 DB0113 | No 113 | Rust - Matt | GU 4.9 DB0117 | No 117 | US Light Green - Matt | GU 3.5 DB0118 | No 118 | US Tan - Matt | GU 5.6 DB0123 | No 123 | Extra Dark Sea Grey - Satin | GU 18.4 DB0127 | No 127 | US Ghost Grey - Satin | GU 19.7 DB0130 | No 130 | White - Satin | GU 27.3 DB0153 | No 153 | Insignia Red - Matt | GU 4.1 DB0154 | No 154 | Insignia Yellow - Matt | GU 9.6 DB0155 | No 155 | Olive Drab - Matt | GU 6.2 DB0156 | No 156 | Dark Camouflage Grey - Satin | GU 7.3 DB0160 | No 160 | German Camouflage Red - Matt | GU 4.9 DB0163 | No 163 | Dark Green - Satin | GU 21.8 DB0171 | No 171 | Antique Bronze - Metallic | GU 7.1 | Metallic DB0174 | No 174 | Signal Red - Satin | GU 25.2 DB0186 | No 186 | Brown - Matt | GU 4.5 DB0189 | No 189 | Chrome Silver - Metallic | GU 89.6 | Metallic DB0208 | No 208 | Fluorescent Signal Green - Gloss | GU 11.3 | Fluorescent DB0209 | No 209 | Fire Orange - Gloss | GU 20.2 | Fluorescent DB0242 | No 242 | RLM 71 Dunkelgrun - Matt | GU 1.5 MET27001 | No 27001 | Aluminium - Metalcote | GU 5.2 | Metallic MET27002 | No 27002 | Polished Aluminium - Metalcote | GU 10.8 | Metallic MET27003 | No 27003 | Polished Steel - Metalcote | GU 47.4 | Metallic MET27004 | No 27004 | Gunmetal - Metalcote | GU 5.2 | Metallic Paint set: Revell (86 paints) 36104 | White | RAL 9010 | GU 72.8 36105 | White | RAL 9001 | GU 5.7 36106 | Tar black | RAL 9021 | GU 2.3 36107 | Black | RAL 9005 | GU 79.8 36108 | Black | RAL 9011 | GU 1.4 36109 | Anthracite | RAL 7021 | GU 4.7 36112 | Yellow | RAL 1018 | GU 79.5 36115 | Yellow | RAL 1017 | GU 6.5 36116 | Sandy yellow | RAL 1024 | GU 2.6 36117 | Africa brown | GU 3.1 36125 | Luminous orange | GU 3.5 | Fluorescent 36130 | Orange | RAL 2004 | GU 87.7 36131 | Fiery red | RAL 3000 | GU 90.5 36134 | Italian Red | GU 88.5 36135 | Flesh | GU 5.9 36136 | Carmine red | RAL 3002 | GU 3.0 36137 | Reddish brown | RAL 3009 | GU 1.8 36139 | Dark green | GU 2.2 36140 | Black green | GU 2.1 36142 | Yellowish olive | GU 1.8 36143 | Medium grey USAF | GU 2.9 36145 | Light olive | RAL 7003 | GU 2.2 36146 | Nato olive | RAL 7013 | GU 1.6 36147 | Mouse grey | RAL 7005 | GU 2.4 36148 | Sea green | RAL 6028 | GU 2.1 36149 | Light blue | GU 3.1 36150 | Light blue | RAL 5012 | GU 72.9 36151 | Ultramarine | RAL 5002 | GU 85.4 36152 | Blue | RAL 5005 | GU 82.7 36154 | Night blue | RAL 5022 | GU 85.3 36155 | Light green | RAL 6027 | GU 3.3 36156 | Blue | RAL 5000 | GU 2.2 36157 | Grey | RAL 7000 | GU 3.5 36159 | Sky RAF | GU 3.4 36161 | Emerald green | RAL 6029 | GU 82.3 36162 | Sea green | RAL 6005 | GU 88.5 36165 | Bronze green | RAL 6031 | GU 2.9 36166 | Olive grey | RAL 7010 | GU 2.2 36167 | Greenish grey | RAL 7009 | GU 2.3 36168 | Dark green RAF | GU 2.1 36169 | Granite grey | RAL 7026 | GU 1.6 36174 | Gunship grey | GU 3.1 36175 | Stone grey | RAL 7030 | GU 3.5 36176 | Light grey USAF | GU 4.1 36177 | Dust grey | RAL 7012 | GU 3.8 36178 | Tank grey | RAL 7024 | GU 2.9 36179 | Greyish blue | RAL 7031 | GU 1.9 36180| Mud brown | RAL 8003 | GU 82.2 36182 | Dark earth RAF | GU 2.1 36183 | Rust | GU 1.9 36184 | Leather brown | RAL 8027 | GU 1.9 36185 | Brown | RAL 8023 | GU 2.5 36186 | Olive brown | RAL 7008 | GU 2.2 36187 | Earth brown | RAL 7006 | GU 4.8 36188 | Ochre brown | RAL 1011 | GU 2.4 36189 | Beige | RAL 1019 | GU 2.9 36190 | Silver | GU 76.6 | Metallic 36191 | Steel | GU 4.9 | Metallic 36192 | Brass | GU 54.8 | Metallic 36193 | Copper | GU 60.8 | Metallic 36194 | Gold | GU 53.0 | Metallic 36195 | Bronze | GU 61.5 | Metallic 36199 | Aluminium | GU 9.6 | Metallic 36301 | White | RAL 9010 | GU 20.9 36302 | Black | RAL 9005 | GU 11.1 36310 | Lufthansa Yellow | RAL 1028 | GU 25.6 36312 | Luminous yellow | RAL 1026 | GU 4.9 | Fluorescent 36314 | Beige | RAL 1001 | GU 18.8 36330 | Fiery red | RAL 3000 | GU 16.2 36331 | Purple red | RAL 3004 | GU 17.8 36332 | Luminous red | RAL 3026 | GU 3.7 | Fluorescent 36350 | Lufthansa blue | RAL 5013 | GU 19.6 36360 | Fern green | RAL 6025 | GU 22.2 36361 | Olive green | RAL 6003 | GU 24.5 36362 | Greyish green | RAL 6013 | GU 12.4 36363 | Dark green | RAL 6020 | GU 21.6 36364 | Leaf green | RAL 6001 | GU 20.4 36365 | Patina green | RAL 6000 | GU 38.1 36371 | Light grey | RAL 7035 | GU 17.8 36374 | Grey | RAL 7001 | GU 20.7 36378 | Dark grey | RAL 7012 | GU 28.0 36381 | Brown | RAL 8025 | GU 42.5 36382 | Wood brown | RAL 8001 | GU 24.0 36730 | Orange | GU 87.2 | Opacity 34.45% | Transparent 36731 | Red | GU 93.0 | Opacity 42.21% | Transparent 36752 | Blue | GU 88.5 | Opacity 48.3 | Transparent Paint set: Vallejo (123 paints) 71.001 | White | Blanco | FS37925 | RAL9016 | RLM21 | GU 3.5 71.002 | Medium Yellow | Amarillo Medio | GU 3.0 71.003 | Red RLM 23 | RLM23 Rot | RLM23 | GU 1.6 71.004 | Blue | Azul | GU 1.4 71.005 | Grey Blue | Azul Gris | RAL5008 | GU 1.5 71.006 | Light Green Chromate | Verde Claro Chromo | GU 1.3 71.007 | Olive Green | Verde Oliva | GU 1.2 71.008 | Pale Blue | Azul Claro | FS35414 | GU 2.0 71.009 | Eau De Nil "D.E. Green" | Verde Huevo Pato | BS216 | GU 1.8 71.010 | Interior Green | Verde Interior | FS34098 | GU 3.5 71.011 | Dark Green RLM83 | RLM83 Dunkelgrün | RLM83 | GU 1.2 71.012 | Dark Green | Verde Oscuro | GU 2.6 71.013 | Yellow Olive | Oliva Amarillo | FS34062 | RAL6016 | GU 3.7 71.014 | Gunship Green | Verde Acorazado | GU 2.7 71.015 | Dark Green RLM71 | RLM71 Dunkelgrün | RLM71 | GU 2.0 71.015 | Dark Green RLM71 | RLM71 Dunkelgrün | RLM71 | GU 2.6 71.016 | USAF Olive Drab | USAF Verde Oliva | FS34088 | ANA613 | GU 2.6 71.017 | Russian Green 4BO | Verde Ruso 4BO | FS34082 | GU 2.6 71.018 | Black Green | Verde Negro | GU 3.2 71.019 | Cam. Dark Green | RAL6007 Grün | FS34083 | RAL6007 | GU 3.5 71.020 | Green Brown | Verde Pardo | GU 2.0 71.021 | Black Green RLM70 | RLM70 Schwarzgrün | RLM70 | GU 0.6 71.021 | Black Green RLM70 | RLM70 Schwarzgrün | RLM70 | GU 3.3 71.022 | Light Green RLM82 | RLM82 Hellgrün | RLM82 | GU 0.8 71.022 | Light Green RLM82 | RLM82 Hellgrün | RLM82 | GU 1.3 71.023 | Hemp | Tan Green | FS34201 | GU 2.8 71.024 | Khaki Brown | Marron Caqui | GU 2.4 71.025 | Dark Yellow | RAL7028 Dunkelgelb | RAL7028 | GU 3.0 71.026 | US Flat Brown | Marron US | FS30215 | GU 2.5 71.027 | Light Brown | Marron Claro | GU 5.2 71.028 | Sand Yellow | Amarillo Arena | GU 4.2 71.029 | Dark Earth | Tierra Oscura | GU 1.0 71.030 | Brown Green | Marron Verdoso | GU 1.7 71.031 | Middlestone | Piedra Medio | GU 1.5 71.032 | Golden Brown | Marron Dorado | GU 1.2 71.033 | Yellow Ochre | RAL1006 Gelb | RAL1006 | GU 1.7 71.034 | Sand Brown | Marron Arena | GU 1.6 71.035 | Cam. Pale Brown | Cam. Pardo Claro | FS30140 | RAL8025 | GU 2.1 71.036 | Mahogany | Caoba | GU 1.9 71.037 | Mud Brown | Marron Lodo | GU 2.0 71.038 | Cam. Medium Brown | Cam Pardo Medio | FS30097 | GU 1.3 71.039 | Hull Red | Marron Rojizo | GU 2.6 71.040 | Burnt Umber | Sombra Tostada | RAL8014 | GU 1.6 71.041 | Armour Brown | RAL8017 Rotbraun | RAL8017 | GU 1.1 71.042 | Dark Brown RLM61 | RLM61 Dunkelbraun | RLM61 | GU 1.3 71.042 | Dark Brown RLM61 | RLM61 Dunkelbraun | RLM61 | GU 1.6 71.043 | US Olive Drab | US Verde Oliva | FS34087 | GU 3.0 71.044 | Grey RLM02 | RLM02 Grau | RLM02 | GU 1.8 71.044 | Grey RLM02 | RLM02 Grau | RLM02 | GU 1.9 71.045 | Cement Grey | Gris Cemento | RAL7033 | GU 2.8 71.046 | Pale Blue Grey | Azul Gris Claro | GU 3.6 71.047 | Grey | Gris | GU 2.0 71.048 | Engine Grey | Gris Motor | FS36076 | GU 2.2 71.049 | Sea Grey | Gris Mar | GU 3.2 71.050 | Light Gray | Gris Claro | FS36300 | RAL7046 | GU 3.1 71.051 | Neutral Gray | Gris Neutral | FS36173 | GU 3.4 71.052 | Anthracite Grey | Gris Antracita | GU 2.2 71.053 | Dark Sea Grey | Gris Mar Osc. | FS36099 | RAL7011 | GU 2.9 71.054 | Dark Grey Blue | Gris Azul Oscuro | RAL7024 | GU 2.2 71.055 | Black Grey RLM66 | RLM66 Schwarzgrau | RLM66 | GU 1.7 71.055 | Black Grey RLM66 | RLM66 Schwarzgrau | RLM66 | GU 3.3 71.056 | Panzer Dk. Grey | RAL7021 Dunkelgrau | RAL7021 | GU 1.6 71.057 | Black | Negro | FS37038 | RAL9004 | RLM22 | ANA604 | BS642 | GU 1.3 71.062 | Aluminium | Aluminio | GU 45.5 | Metallic 71.063 | Silver RLM01 | RLM01 Silber | RLM01 | GU 38.8 | Metallic 71.064 | Chrome | Cromo | FS17178 | GU 41.7 | Metallic 71.065 | Steel | Acero | GU 29.0 | Metallic 71.066 | Gold | Oro | FS17043 | GU 19.8 | Metallic 71.067 | Bright Brass | Laton | GU 32.1 | Metallic 71.068 | Copper | Cobre | GU 11.1 | Metallic 71.069 | Rust | Oxido | GU 7.1 | Metallic 71.070 | Signal Red | Rojo Señal | GU 6.2 | Metallic 71.071 | Arctic Blue | Azul Artico | GU 6.3 | Metallic 71.072 | Gunmetal | Fusil | FS37200 | GU 17.3 | Metallic 71.075 | Ivory | RAL1001 Elfenbein | RAL1001 | GU 3.9 71.076 | Skin Tone | Color Piel | GU 5.1 71.078 | Yellow RLM04 | RLM04 Gelb | FS33538 | RLM04 | ANA614 | BS356 | GU 2.5 71.078 | Yellow RLM04 | RLM04 Gelb | FS33538 | RLM04 | ANA614 | BS356 | GU 2.7 71.080 | Rust | Oxido | FS30111 | BS435 | GU 2.7 71.084 | Fire Red | Rojo Fuego | GU 3.1 71.090 | Deep Sky | Azul Oscuro | FS35056 | GU 1.9 71.092 | Medium Olive | RAL6003 Olivgrün | RAL6003 | GU 1.9 71.097 | Medium Gunship Gray | Gris Medio USAF | FS36118 | ANA603 | GU 3.1 71.101 | Light Blue RLM78 | RLM78 Hellblau | RLM78 | GU 5.3 71.103 | Grey Blue RLM84 | RLM84 Graublau | FS36559 | RLM84 | GU 1.7 71.104 | Green RLM62 | RLM62 Grün | RLM62 | GU 3.4 71.107 | US Interior Green | US Amarillo Inter. | GU 3.0 71.108 | Uk Azure Blue | Uk Azul Azure | FS35231 | ANA609 | GU 3.1 71.109 | Faded P.R.U. Blue | M485 Blue Gray | FS35189 | BS636 | GU 1.6 71.115 | Blue Grey | RAL7016 Blaugrau | RAL7016 | GU 2.0 71.116 | Camouflage Grey Green | RAL7008 Graugrün | RAL7008 | GU 2.3 71.117 | Camouflage Brown | RAL8020 Braun | RAL8020 | GU 3.0 71.118 | Camouflage Grey | RAL7027 Grau | RAL7027 | GU 2.7 71.119 | White Grey | RAL9002 Grauweiss | RAL9002 | GU 5.2 71.121 | Light Gull Gray | Gris Gaviota USN | FS36440 | ANA620 | GU 2.6 71.124 | USAF Green | Verde USAF | FS34092-ANA612 | GU 2.7 71.125 | USAF Brown | Marrón USAF | FS30219 | ANA628 | GU 2.6 71.137 | US Light Green | US Verde Claro | FS34151 | ANA611 | GU 3.1 71.139 | US Field Drab | US Marrón Verdoso | FS30118 | ANA617 | GU 3.9 71.140 | US Desert Sand | US Arena Desierto | FS30279 | ANA616 | GU 3.1 71.255 | Light Blue RLM65 | RLM65 Hellblau | RLM65 | GU 1.7 71.256 | Green RLM73 | RLM73 Grün | RLM73 | GU 3.2 71.257 | Light Blue RLM76 | RLM76 Lichtblau | RLM76 | GU 1.7 71.258 | Grey Green RLM74 | RLM74 Graugrün | RLM74 | GU 1.4 71.259 | Grey Violet RLM75 | RLM75 Grauviolett | RLM75 | GU 1.5 71.260 | Light Grey RLM63 | RLM63 Hellgrau | RLM63 | GU 1.5 71.263 | Green RLM72 | RLM72 Grün | RLM72 | GU 2.6 71.264 | Brown Violet RLM81 | RLM81 Braunviolett | RLM81 | GU 1.2 71.268 | German Grey | RAL6006 Feldgrau | RAL6006 | GU 2.2 71.270 | Off-White | RAL9001 Weiss | RAL9001 | GU 4.9 71.271 | German Red Brown | RAL8012 Rotbraun | RAL8012 | GU 3.2 71.272 | German Yellow Brown | RAL8000 Gelbbraun | RAL8000 | GU 2.3 71.277 | Dark Gull Gray | Gris Gaviota Oscuro | FS36231 | ANA621 | GU 1.7 71.278 | Sand Yellow RLM79 | RLM79 Sandgelb | RLM79 | GU 3.7 71.279 | Insignia White | Blanco Insignia | FS37875 | ANA601 | GU 5.2 71.294 | US Forest Green | US Verde Bosque | FS34079 | ANA631 | GU 3.1 71.295 | USN Sea Blue | USN Azul Marino | FS35042 | ANA607 | GU 2.2 71.296 | USAAF Light Gray | Curtiss Grey | FS36622 | GU 5.1 71.298 | M495 Light Gray | M495 Gris Claro | FS36357 | GU 1.8 71.299 | Intermediate Blue | Azul Intermedio | FS35164 | ANA608 | GU 2.5 71.300 | Glossy Sea Blue | Azul Mar Brillante | FS15042 | ANA623 | GU 24.6 71.306 | Sky Blue | Azul Cielo | FS35550 | GU 3.5 71.316 | N. 41 Dark Olive Drab | N. 41 Verde Oliva Oscuro | GU 2.9 Paint set: Hataka (10 paints) HTK-A009 | Dark Earth | GU 9.1 HTK-A015 | Black-Green (RLM70) | GU 7.9 HTK-A016 | Dark Green | GU 9.6 HTK-A017 | Dark Green (RLM71) | GU 10.5 HTK-A023 | Grey (RLM02) | GU 14.1 HTK-A025 | Interior Grey-Green | GU 17.4 HTK-A026 | Sky "Type S" | GU 13.1 HTK-A029 | Light Blue (RLM65/78) | GU 13.2 HTK-A032 | Ocean Grey | GU 13.3 HTK-A034 | Medium Sea Grey | GU 14.2 Paint set: Tamiya (40 paints) XF-1 | Flat Black | GU 3.5 XF-10 | Flat Brown | GU 4.1 XF-11 | J.N. Green | GU 3.9 XF-12 | J.N. Gray | GU 1.9 XF-13 | J.A. Green | GU 8.2 XF-14 | J.A. Grey | GU 8.8 XF-15 | Flat Flesh | GU 15.2 XF-16 | Flat Aluminum | GU 6.7 | Metallic XF-17 | Sea Blue | GU 4.6 XF-18 | Medium Blue | GU 6.5 XF-19 | Sky Grey | GU 7.1 XF-2 | Flat White | GU 7.3 XF-20 | Medium Grey | GU 3.8 XF-21 | Sky | GU 6.7 XF-22 | RLM Grey | GU 4.3 XF-23 | Light Blue | GU 4.5 XF-24 | Dark Grey | GU 5.8 XF-25 | Light Sea Grey | GU 4.5 XF-26 | Deep Green | GU 5.3 XF-27 | Black Green | GU 2.1 XF-28 | Dark Copper | GU 5.3 | Metallic XF-3 | Flat Yellow | GU 3.8 XF-4 | Yellow Green | GU 5.1 XF-49 | Khaki | GU 5.5 XF-5 | Flat Green | GU 2.8 XF-50 | Field Blue | 7.1 XF-51 | Khaki Drab | GU 4.9 XF-52 | Flat Earth | GU 5.3 XF-53 | Neutral Grey | GU 6.6 XF-54 | Dark Sea Grey | GU 6.5 XF-55 | Deck Tan | GU 19.1 XF-56 | Metallic Grey | GU 6.3 | Metallic XF-57 | Buff | GU 18.2 XF-58 | Olive Green | GU 6.1 XF-59 | Desert Yellow | GU GU 20.7 XF-6 | Copper | GU 4.5 | Metallic XF-60 | Dark Yellow | GU 13.0 XF-7 | Flat Red | GU 0.9 XF-8 | Flat Blue | GU 3.4 XF-9 | Hull Red | GU 4.2 Paint set: Lifecolor (12 paints) UA 501 | RLM 70 - Schwarzgrün | GU 9.2 UA 502 | RLM 71 - Dunkelgrün | GU 11.3 UA 503 | RLM 65 - Hellblau | GU 9.1 UA 504 | RLM 02 Grau | GU 6.5 UA 505 | RLM 79 - Sandgelb II | GU 8.7 UA 506 | RLM 80 Olivgrün | GU 8.1 UA 546 | Dark Green | *FS 34079 | GU 7.0 UA 547 | Dark Earth | *FS 30118 | GU 6.3 UA 548 | Light Green | FS 34102 | GU 6.4 UA 549 | Light Earth | FS 30257 | GU 6.8 UA 550 | Sky | FS 34424 | GU 6.4 UA 551 | Grey Green | FS 34226 | GU 9.0 Paint set: Golden Fluid Acrylics (53 paints) 2005 | Anthraquinone Blue 2008 | Benzimidazolone Yellow Medium 2009 | Benzimidazolone Yellow Light 2010 | Bone Black 2020 | Burnt Sienna 2035 | Burnt Umber Light 2040 | Carbon Black 2050 | Cerulean Blue, Chromium 2051 | Cerulean Blue Deep 2060 | Chromium Oxide Green 2140 | Cobalt Blue 2147 | Diarylide Yellow 2150 | Dioxazine Purple 2191 | Hansa Yellow Opaque 2210 | Naphthol Red Light 2220 | Naphthol Red Medium 2240 | Payne's Gray 2250B | Permanent Green Light 2255 | Phthalo Blue (Green Shade) 2270 | Phthalo Green (Blue Shade) 2275 | Phthalo Green (Yellow Shade) 2276 | Pyrrole Orange 2277 | Pyrrole Red 2279 | Pyrrole Red Light 2290 | Quinacridone Crimson 2301 | Quinacridone/Nickel Azo Gold 2305 | Quinacridone Magenta 2310 | Quinacridone Red 2330 | Quinacridone Violet 2340 | Raw Sienna 2350 | Raw Umber 2360 | Red Oxide 2369 | Teal 2370 | Titan Buff 2371 | Titan Green Pale 2380 | Titanium White 2385 | Transparent Red Iron Oxide 2386 | Transparent Yellow Iron Oxide 2400 | Ultramarine Blue 2401 | Ultramarine Violet 2403 | Vat Orange 2407 | Yellow Ochre 2410 | Yellow Oxide 2420 | Primary Cyan 2421 | Primary Magenta 2422B | Primary Yellow 2425 | Cadmium Red Medium Hue 2428B | Cadmium Yellow Medium Hue 2436B | Indian Yellow Hue 2439 | Prussian Blue Hue 2440 | Sap Green Hue 2442 | Van Dyke Brown Hue 5002390 | Turquoise (Phthalo) Edited March 4 by Casey 1 2 Link to comment Share on other sites More sharing options...
CFster Posted March 4 Share Posted March 4 1 hour ago, Casey said: RGB is sadly not a defined standard, the colors can be more off than is acceptable for paints. But I agree it is usually all you have from vendors. It is also not even possible to directly compare RGB between one vendor's swatches and another unless they are measured by the same spectrometer setup (which means: the same geometry and other settings) and uncorrected for web/printing. I am aware of only one relatively modeller-related database that does provide these details - https://www.e-paint.co.uk/ It is also next to impossible to match RGB from photo to paint without some extra information, like a good color reference card on the same photo, context, some other reference, or at least information about camera settings and date and time. That's why I make my own databases. I did indeed use this physical method on all paints that I have and I do it because paints and colors are my passion. For Humbrol and Revell I can now give definite answers since I have all their paints on their ranges (or all I could get in Humbrol's case). Here are the paint samples I have for comparison so far (open spoiler to see, it is a long list): Hide contents A1701 | No 157 | Azure Blue - Matt | GU 1.3 A6238 | No 187 | Dark Stone - Matt | GU 1.5 AA0046 | No 46 | Orange - Matt | GU 8.5 AA0059 | No 5 | Dark Admiralty Grey - Gloss | GU 90.8 AA0076 | No 7 | Light Buff - Gloss| GU 95.2 AA0134 | No 12 | Copper - Metallic | GU 8.7 | Metallic AA0173 | No 173 | Track Colour - Matt | GU 1.3 AA0234 | No 234 | Dark Flesh - Matt | GU 4.4 AA0343 | No 31 | Slate Grey - Matt | GU 7.5 AA0360 | No 33 | Black - Matt | GU 2.2 AA0549 | No 50 | Green Mist - Metallic | GU 94.3 | Metallic AA0552 | No 51 | Sunset Red - Metallic | GU 95.3 | Metallic AA0583 | No 53 | Gunmetal - Metallic | GU 1.2 | Metallic AA0727 | No 65 | Aircraft Blue - Matt | GU 5.0 AA0770 | No 66 | Olive Drab - Matt | GU 5.9 AA0775 | No 70 | Brick Red - Matt | GU 3.1 AA0802 | No 73 | Wine - Matt | GU 1.3 AA0816 | No 74 | Linen - Matt | GU 7.9 AA0833 | No 75 | Bronze Green - Matt | GU 2.0 AA0847 | No 76 | Uniform Green - Matt | GU 2.1 AA0850 | No 77 | Navy Blue - Matt | GU 1.7 AA0878 | No 79 | Blue Grey - Matt | GU 4.3 AA0905 | No 82 | Orange Lining - Matt | GU 4.1 AA0919 | No 83 | Ochre - Matt | GU 5.3 AA0922 | No 84 | Mid Stone - Matt | GU 4.1 AA0967 | No 87 | Steel Grey - Matt | GU 6.9 AA0970 | No 88 | Deck Green - Matt | GU 2.0 AA1105 | No 100 | Red Brown - Matt | GU 3.8 AA1119 | No 101 | Mid Green - Matt | GU 2.9 AA1167 | No 105 | Marine Green - Matt | GU 7.1 AA1287 | No 116 | US Dark Green - Matt | GU 2.1 AA1314 | No 119 | Light Earth - Matt | GU 4.5 AA1328 | No 120 | Light Green - Matt | GU 3.1 AA1331 | No 121 | Pale Stone - Matt | GU 7.0 AA1376 | No 125 | US Dark Grey - Satin | GU 11.4 AA1393 | No 126 | US Medium Grey - Satin | GU 37.9 AA1417 | No 128 | US Compass Grey - Satin | GU 31.6 AA1420 | No 129 | US Gull Grey - Satin | GU 21.6 AA1448 | No 131 | Mid Green - Satin | GU 21.1 AA1451 | No 132 | Red - Satin | GU 11.0 AA1465 | No 133 | Brown - Satin | GU 33.0 AA1496 | No 28 | Camouflage Grey - Matt | GU 17.2 AA1523 | No 140 | Gull Grey - Matt | GU 5.4 AA1568 | No 144 | Intermediate Blue - Matt | GU 4.8 AA1571 | No 145 | Medium Grey - Matt | GU 11.6 AA1599 | No 147 | Light Grey - Matt | GU 6.1 AA1609 | No 148 | Radome Tan - Matt | GU 19.1 AA1612 | No 149 | Dark Green - Matt | GU 2.9 AA1626 | No 150 | Forest Green - Matt | GU 1.4 AA1729 | No 159 | Khaki Drab - Matt | GU 2.0 AA1780 | No 164 | Dark Sea Grey - Satin | GU 25.9 AA1804 | No 166 | Light Aircraft Grey - Satin | GU 54.6 AA2240 | No 240 | RLM 02 Grau - Matt | GU 3.9 AA2241 | No 241 | RLM 70 Schwartzgrun - Matt | GU 2.2 AA2241 | No 241 | RLM 70 Schwartzgrun - Matt | GU 3.0 AA2242 | No 242 | RLM 71 Dunkelgrun - Matt | GU 1.0 AA2247 | No 247 | RLM 76 Lichtblau - Matt | GU 13.9 AA2248 | No 248 | RLM 78 Himmelblau - Matt | GU 3.0 AA2252 | No 252 | RLM 82 Olivgrun - Matt | GU 2.2 AA2253 | No 253 | RLM 83 Dunkelgrun - Matt | GU 2.4 AA6330 | No 195 | Dark Green - Satin | GU 31.5 AA6344 | No 196 | Light Grey - Satin | GU 29.9 AA6389 | No 200 | Pink - Gloss | GU 91.8 AA6392 | No 201 | Black - Metallic | GU 91.3 | Metallic AA6608 | No 220 | Racing Red - Gloss | GU 100.0 AA7222 | No 222 | Moonlight Blue - Metallic | GU 95.0 | Metallic AA7224 | No 224 | Dark Slate Grey - Matt | GU 3.0 AA7225 | No 225 | Middle Stone - Matt | GU 2.6 AB0047 | No 47 | Sea Blue - Gloss | GU 65.0 AB0052 | No 52 | Baltic Blue - Metallic | GU 78.7 | Metallic AB0065 | No 65 | Aircraft Blue - Matt | GU 6.3 AB0078 | No 78 | Cockpit Green - Matt | GU 4.1 AB0090 | No 90 | Beige Green - Matt | GU 9.5 AB0091 | No 91 | Black Green - Matt | GU 1.6 AB0094 | No 94 | Brown Yellow - Matt | GU 2.2 AB0104 | No 104 | Oxford Blue - Matt | GU 1.4 AB0145 | No 145 | Medium Grey - Matt | GU 2.4 AB0165 | No 165 | Medium Sea Grey - Satin | GU 17.2 AB0167 | No 167 | RAF Barley Grey - Satin | GU 9.2 AB0168 | No 168 | Hemp - Satin | GU 33.8 AB0226 | No 226 | Interior Green - Matt | GU 2.3 AB0230 | No 230 | Pru Blue - Matt | GU 1.3 AB0237 | No 237 | Desert Tan - Matt | GU 1.3 AB0238 | No 238 | Arrow Red - Gloss | GU 65.7 AB0239 | No 239 | British Racing Green - Gloss | GU 56.0 AB0240 | No 240 | RLM 02 Grau - Matt | GU 1.3 AB0241 | No 241 | RLM 70 Schwartzgrun - Matt | GU 4.0 AB0243 | No 243 | RLM 72 Grun - Matt | GU 1.5 AB0244 | No 244 | RLM 73 Grun - Matt | GU 1.4 AB0245 | No 245 | RLM 74 Graugrun - Matt | GU 0.9 AB0246 | No 246 | RLM 75 Grauviolett - Matt | GU 1.3 AB0247 | No 247 | RLM 76 Lichtblau - Matt | GU 12.9 AB0249 | No 249 | RLM 79 Sandgelb - Matt | GU 1.5 AB0251 | No 251 | RLM 81 Dunkelbraun - Matt | GU 0.7 AB0252 | No 252 | RLM 82 Olivgrun - Matt | GU 0.7 AB0253 | No 253 | RLM 83 Dunkelgrun - Matt | GU 0.8 DB0001 | No 1 | Primer | GU 5.6 DB0002 | No 2 | Emerald Green - Gloss | GU 79.8 DB0003 | No 3 | Brunswick Green - Gloss | GU 63.0 DB0009 | No 9 | Tan - Gloss | GU 76.9 DB0010 | No 10 | Service Brown - Gloss | GU 78.0 DB0011 | No 11 | Silver - Metallic | GU 6.7 | Metallic DB0012 | No 12 | Copper - Metallic | GU 48.2 | Metallic DB0014 | No 14 | French Blue - Gloss | GU 80.5 DB0015 | No 15 | Midnight Blue - Gloss | GU 79.7 DB0016 | No 16 | Gold - Metallic | GU 6.4 | Metallic DB0018 | No 18 | Orange - Gloss | GU 78.0 DB0019 | No 19 | Red - Gloss | GU 90.2 DB0020 | No 20 | Crimson - Gloss | GU 84.2 DB0021 | No 21 | Black - Gloss | GU 45.3 DB0022 | No 22 | White - Gloss | GU 65.9 DB0023 | No 23 | Duck Egg Blue - Matt | GU 4.3 DB0024 | No 24 | Trainer Yellow - Matt | GU 3.6 DB0025 | No 25 | Blue - Matt | GU 5.1 DB0026 | No 26 | Khaki - Matt | GU 3.4 DB0027 | No 27 | Sea Grey - Matt | GU 10.5 DB0029 | No 29 | Dark Earth - Matt | GU 3.6 DB0030 | No 30 | Dark Green - Matt | GU 3.2 DB0032 | No 32 | Dark Grey - Matt | GU 11.2 DB0033 | No 33 | Black - Matt | GU 3.9 DB0034 | No 34 | White - Matt | GU 6.5 DB0036 | No 36 | Pastel Green - Matt | GU 6.9 DB0037 | No 37 | Bright Green - Matt | GU 3.9 DB0038 | No 38 | Lime - Gloss | GU 82.8 DB0040 | No 40 | Pale Grey - Gloss | GU 65.2 DB0041 | No 41 | Ivory - Gloss | GU 58.2 DB0042 | No 42 | Pastel Violet - Matt | GU 4.8 DB0044 | No 44 | Pastel Blue - Matt | GU 7.0 DB0048 | No 48 | Mediterranean Blue - Gloss | GU 71.1 DB0053 | No 53 | Gunmetal - Metallic | GU 6.1 | Metallic DB0054 | No 54 | Brass - Metallic | GU 8.0 | Metallic DB0055 | No 55 | Bronze - Metallic | GU 6.7 | Metallic DB0056 | No 56 | Aluminium - Metallic | GU 14.6 | Metallic DB0057 | No 57 | Pink - Matt | GU 5.2 DB0058 | No 58 | Magenta - Matt | GU 6.4 DB0060 | No 60 | Scarlett - Matt | GU 3.5 DB0061 | No 61 | Flesh - Matt | GU 5.9 DB0062 | No 62 | Leather - Matt | GU 3.5 DB0063 | No 63 | Sand - Matt | GU 7.1 DB0064 | No 64 | Light Grey - Matt | GU 5.9 DB0067 | No 67 | Matt Tank Grey - Matt | GU 5.2 DB0068 | No 68 | Purple - Gloss | GU 79.1 DB0069 | No 69 | Yellow - Gloss | GU 93.5 DB0071 | No 71 | Oak - Satin | GU 19.7 DB0072 | No 72 | Khaki Drill - Matt | GU 6.8 DB0080 | No 80 | Grass Green - Matt | GU 3.6 DB0081 | No 81 | Pale Yellow - Matt | GU 1.9 DB0085 | No 85 | Black - Satin | GU 19.5 DB0085 | No 86 | Light Olive - Matt | GU 9.2 DB0089 | No 89 | Middle Blue - Matt | GU 5.4 DB0093 | No 93 | Desert Yellow - Matt | GU 4.5 DB0096 | No 96 | RAF Blue - Matt | GU 6.6 DB0098 | No 98 | Chocolate - Matt | GU 3.0 DB0099 | No 99 | Lemon - Matt | GU 8.5 DB0102 | No 102 | Army Green - Matt | GU 4.6 DB0103 | No 103 | Cream - Matt | GU 6.1 DB0106 | No 106 | Ocean Grey - Matt | GU 4.4 DB0109 | No 109 | WWI Blue - Matt | GU 4.7 DB0110 | No 110 | Natural Wood - Matt | GU 6.4 DB0113 | No 113 | Rust - Matt | GU 4.9 DB0117 | No 117 | US Light Green - Matt | GU 3.5 DB0118 | No 118 | US Tan - Matt | GU 5.6 DB0123 | No 123 | Extra Dark Sea Grey - Satin | GU 18.4 DB0127 | No 127 | US Ghost Grey - Satin | GU 19.7 DB0130 | No 130 | White - Satin | GU 27.3 DB0153 | No 153 | Insignia Red - Matt | GU 4.1 DB0154 | No 154 | Insignia Yellow - Matt | GU 9.6 DB0155 | No 155 | Olive Drab - Matt | GU 6.2 DB0156 | No 156 | Dark Camouflage Grey - Satin | GU 7.3 DB0160 | No 160 | German Camouflage Red - Matt | GU 4.9 DB0163 | No 163 | Dark Green - Satin | GU 21.8 DB0171 | No 171 | Antique Bronze - Metallic | GU 7.1 | Metallic DB0174 | No 174 | Signal Red - Satin | GU 25.2 DB0186 | No 186 | Brown - Matt | GU 4.5 DB0189 | No 189 | Chrome Silver - Metallic | GU 89.6 | Metallic DB0208 | No 208 | Fluorescent Signal Green - Gloss | GU 11.3 | Fluorescent DB0209 | No 209 | Fire Orange - Gloss | GU 20.2 | Fluorescent DB0242 | No 242 | RLM 71 Dunkelgrun - Matt | GU 1.5 MET27001 | No 27001 | Aluminium - Metalcote | GU 5.2 | Metallic MET27002 | No 27002 | Polished Aluminium - Metalcote | GU 10.8 | Metallic MET27003 | No 27003 | Polished Steel - Metalcote | GU 47.4 | Metallic MET27004 | No 27004 | Gunmetal - Metalcote | GU 5.2 | Metallic Paint set: Revell (86 paints) 36104 | White | RAL 9010 | GU 72.8 36105 | White | RAL 9001 | GU 5.7 36106 | Tar black | RAL 9021 | GU 2.3 36107 | Black | RAL 9005 | GU 79.8 36108 | Black | RAL 9011 | GU 1.4 36109 | Anthracite | RAL 7021 | GU 4.7 36112 | Yellow | RAL 1018 | GU 79.5 36115 | Yellow | RAL 1017 | GU 6.5 36116 | Sandy yellow | RAL 1024 | GU 2.6 36117 | Africa brown | GU 3.1 36125 | Luminous orange | GU 3.5 | Fluorescent 36130 | Orange | RAL 2004 | GU 87.7 36131 | Fiery red | RAL 3000 | GU 90.5 36134 | Italian Red | GU 88.5 36135 | Flesh | GU 5.9 36136 | Carmine red | RAL 3002 | GU 3.0 36137 | Reddish brown | RAL 3009 | GU 1.8 36139 | Dark green | GU 2.2 36140 | Black green | GU 2.1 36142 | Yellowish olive | GU 1.8 36143 | Medium grey USAF | GU 2.9 36145 | Light olive | RAL 7003 | GU 2.2 36146 | Nato olive | RAL 7013 | GU 1.6 36147 | Mouse grey | RAL 7005 | GU 2.4 36148 | Sea green | RAL 6028 | GU 2.1 36149 | Light blue | GU 3.1 36150 | Light blue | RAL 5012 | GU 72.9 36151 | Ultramarine | RAL 5002 | GU 85.4 36152 | Blue | RAL 5005 | GU 82.7 36154 | Night blue | RAL 5022 | GU 85.3 36155 | Light green | RAL 6027 | GU 3.3 36156 | Blue | RAL 5000 | GU 2.2 36157 | Grey | RAL 7000 | GU 3.5 36159 | Sky RAF | GU 3.4 36161 | Emerald green | RAL 6029 | GU 82.3 36162 | Sea green | RAL 6005 | GU 88.5 36165 | Bronze green | RAL 6031 | GU 2.9 36166 | Olive grey | RAL 7010 | GU 2.2 36167 | Greenish grey | RAL 7009 | GU 2.3 36168 | Dark green RAF | GU 2.1 36169 | Granite grey | RAL 7026 | GU 1.6 36174 | Gunship grey | GU 3.1 36175 | Stone grey | RAL 7030 | GU 3.5 36176 | Light grey USAF | GU 4.1 36177 | Dust grey | RAL 7012 | GU 3.8 36178 | Tank grey | RAL 7024 | GU 2.9 36179 | Greyish blue | RAL 7031 | GU 1.9 36180| Mud brown | RAL 8003 | GU 82.2 36182 | Dark earth RAF | GU 2.1 36183 | Rust | GU 1.9 36184 | Leather brown | RAL 8027 | GU 1.9 36185 | Brown | RAL 8023 | GU 2.5 36186 | Olive brown | RAL 7008 | GU 2.2 36187 | Earth brown | RAL 7006 | GU 4.8 36188 | Ochre brown | RAL 1011 | GU 2.4 36189 | Beige | RAL 1019 | GU 2.9 36190 | Silver | GU 76.6 | Metallic 36191 | Steel | GU 4.9 | Metallic 36192 | Brass | GU 54.8 | Metallic 36193 | Copper | GU 60.8 | Metallic 36194 | Gold | GU 53.0 | Metallic 36195 | Bronze | GU 61.5 | Metallic 36199 | Aluminium | GU 9.6 | Metallic 36301 | White | RAL 9010 | GU 20.9 36302 | Black | RAL 9005 | GU 11.1 36310 | Lufthansa Yellow | RAL 1028 | GU 25.6 36312 | Luminous yellow | RAL 1026 | GU 4.9 | Fluorescent 36314 | Beige | RAL 1001 | GU 18.8 36330 | Fiery red | RAL 3000 | GU 16.2 36331 | Purple red | RAL 3004 | GU 17.8 36332 | Luminous red | RAL 3026 | GU 3.7 | Fluorescent 36350 | Lufthansa blue | RAL 5013 | GU 19.6 36360 | Fern green | RAL 6025 | GU 22.2 36361 | Olive green | RAL 6003 | GU 24.5 36362 | Greyish green | RAL 6013 | GU 12.4 36363 | Dark green | RAL 6020 | GU 21.6 36364 | Leaf green | RAL 6001 | GU 20.4 36365 | Patina green | RAL 6000 | GU 38.1 36371 | Light grey | RAL 7035 | GU 17.8 36374 | Grey | RAL 7001 | GU 20.7 36378 | Dark grey | RAL 7012 | GU 28.0 36381 | Brown | RAL 8025 | GU 42.5 36382 | Wood brown | RAL 8001 | GU 24.0 36730 | Orange | GU 87.2 | Opacity 34.45% | Transparent 36731 | Red | GU 93.0 | Opacity 42.21% | Transparent 36752 | Blue | GU 88.5 | Opacity 48.3 | Transparent Paint set: Vallejo (123 paints) 71.001 | White | Blanco | FS37925 | RAL9016 | RLM21 | GU 3.5 71.002 | Medium Yellow | Amarillo Medio | GU 3.0 71.003 | Red RLM 23 | RLM23 Rot | RLM23 | GU 1.6 71.004 | Blue | Azul | GU 1.4 71.005 | Grey Blue | Azul Gris | RAL5008 | GU 1.5 71.006 | Light Green Chromate | Verde Claro Chromo | GU 1.3 71.007 | Olive Green | Verde Oliva | GU 1.2 71.008 | Pale Blue | Azul Claro | FS35414 | GU 2.0 71.009 | Eau De Nil "D.E. Green" | Verde Huevo Pato | BS216 | GU 1.8 71.010 | Interior Green | Verde Interior | FS34098 | GU 3.5 71.011 | Dark Green RLM83 | RLM83 Dunkelgrün | RLM83 | GU 1.2 71.012 | Dark Green | Verde Oscuro | GU 2.6 71.013 | Yellow Olive | Oliva Amarillo | FS34062 | RAL6016 | GU 3.7 71.014 | Gunship Green | Verde Acorazado | GU 2.7 71.015 | Dark Green RLM71 | RLM71 Dunkelgrün | RLM71 | GU 2.0 71.015 | Dark Green RLM71 | RLM71 Dunkelgrün | RLM71 | GU 2.6 71.016 | USAF Olive Drab | USAF Verde Oliva | FS34088 | ANA613 | GU 2.6 71.017 | Russian Green 4BO | Verde Ruso 4BO | FS34082 | GU 2.6 71.018 | Black Green | Verde Negro | GU 3.2 71.019 | Cam. Dark Green | RAL6007 Grün | FS34083 | RAL6007 | GU 3.5 71.020 | Green Brown | Verde Pardo | GU 2.0 71.021 | Black Green RLM70 | RLM70 Schwarzgrün | RLM70 | GU 0.6 71.021 | Black Green RLM70 | RLM70 Schwarzgrün | RLM70 | GU 3.3 71.022 | Light Green RLM82 | RLM82 Hellgrün | RLM82 | GU 0.8 71.022 | Light Green RLM82 | RLM82 Hellgrün | RLM82 | GU 1.3 71.023 | Hemp | Tan Green | FS34201 | GU 2.8 71.024 | Khaki Brown | Marron Caqui | GU 2.4 71.025 | Dark Yellow | RAL7028 Dunkelgelb | RAL7028 | GU 3.0 71.026 | US Flat Brown | Marron US | FS30215 | GU 2.5 71.027 | Light Brown | Marron Claro | GU 5.2 71.028 | Sand Yellow | Amarillo Arena | GU 4.2 71.029 | Dark Earth | Tierra Oscura | GU 1.0 71.030 | Brown Green | Marron Verdoso | GU 1.7 71.031 | Middlestone | Piedra Medio | GU 1.5 71.032 | Golden Brown | Marron Dorado | GU 1.2 71.033 | Yellow Ochre | RAL1006 Gelb | RAL1006 | GU 1.7 71.034 | Sand Brown | Marron Arena | GU 1.6 71.035 | Cam. Pale Brown | Cam. Pardo Claro | FS30140 | RAL8025 | GU 2.1 71.036 | Mahogany | Caoba | GU 1.9 71.037 | Mud Brown | Marron Lodo | GU 2.0 71.038 | Cam. Medium Brown | Cam Pardo Medio | FS30097 | GU 1.3 71.039 | Hull Red | Marron Rojizo | GU 2.6 71.040 | Burnt Umber | Sombra Tostada | RAL8014 | GU 1.6 71.041 | Armour Brown | RAL8017 Rotbraun | RAL8017 | GU 1.1 71.042 | Dark Brown RLM61 | RLM61 Dunkelbraun | RLM61 | GU 1.3 71.042 | Dark Brown RLM61 | RLM61 Dunkelbraun | RLM61 | GU 1.6 71.043 | US Olive Drab | US Verde Oliva | FS34087 | GU 3.0 71.044 | Grey RLM02 | RLM02 Grau | RLM02 | GU 1.8 71.044 | Grey RLM02 | RLM02 Grau | RLM02 | GU 1.9 71.045 | Cement Grey | Gris Cemento | RAL7033 | GU 2.8 71.046 | Pale Blue Grey | Azul Gris Claro | GU 3.6 71.047 | Grey | Gris | GU 2.0 71.048 | Engine Grey | Gris Motor | FS36076 | GU 2.2 71.049 | Sea Grey | Gris Mar | GU 3.2 71.050 | Light Gray | Gris Claro | FS36300 | RAL7046 | GU 3.1 71.051 | Neutral Gray | Gris Neutral | FS36173 | GU 3.4 71.052 | Anthracite Grey | Gris Antracita | GU 2.2 71.053 | Dark Sea Grey | Gris Mar Osc. | FS36099 | RAL7011 | GU 2.9 71.054 | Dark Grey Blue | Gris Azul Oscuro | RAL7024 | GU 2.2 71.055 | Black Grey RLM66 | RLM66 Schwarzgrau | RLM66 | GU 1.7 71.055 | Black Grey RLM66 | RLM66 Schwarzgrau | RLM66 | GU 3.3 71.056 | Panzer Dk. Grey | RAL7021 Dunkelgrau | RAL7021 | GU 1.6 71.057 | Black | Negro | FS37038 | RAL9004 | RLM22 | ANA604 | BS642 | GU 1.3 71.062 | Aluminium | Aluminio | GU 45.5 | Metallic 71.063 | Silver RLM01 | RLM01 Silber | RLM01 | GU 38.8 | Metallic 71.064 | Chrome | Cromo | FS17178 | GU 41.7 | Metallic 71.065 | Steel | Acero | GU 29.0 | Metallic 71.066 | Gold | Oro | FS17043 | GU 19.8 | Metallic 71.067 | Bright Brass | Laton | GU 32.1 | Metallic 71.068 | Copper | Cobre | GU 11.1 | Metallic 71.069 | Rust | Oxido | GU 7.1 | Metallic 71.070 | Signal Red | Rojo Señal | GU 6.2 | Metallic 71.071 | Arctic Blue | Azul Artico | GU 6.3 | Metallic 71.072 | Gunmetal | Fusil | FS37200 | GU 17.3 | Metallic 71.075 | Ivory | RAL1001 Elfenbein | RAL1001 | GU 3.9 71.076 | Skin Tone | Color Piel | GU 5.1 71.078 | Yellow RLM04 | RLM04 Gelb | FS33538 | RLM04 | ANA614 | BS356 | GU 2.5 71.078 | Yellow RLM04 | RLM04 Gelb | FS33538 | RLM04 | ANA614 | BS356 | GU 2.7 71.080 | Rust | Oxido | FS30111 | BS435 | GU 2.7 71.084 | Fire Red | Rojo Fuego | GU 3.1 71.090 | Deep Sky | Azul Oscuro | FS35056 | GU 1.9 71.092 | Medium Olive | RAL6003 Olivgrün | RAL6003 | GU 1.9 71.097 | Medium Gunship Gray | Gris Medio USAF | FS36118 | ANA603 | GU 3.1 71.101 | Light Blue RLM78 | RLM78 Hellblau | RLM78 | GU 5.3 71.103 | Grey Blue RLM84 | RLM84 Graublau | FS36559 | RLM84 | GU 1.7 71.104 | Green RLM62 | RLM62 Grün | RLM62 | GU 3.4 71.107 | US Interior Green | US Amarillo Inter. | GU 3.0 71.108 | Uk Azure Blue | Uk Azul Azure | FS35231 | ANA609 | GU 3.1 71.109 | Faded P.R.U. Blue | M485 Blue Gray | FS35189 | BS636 | GU 1.6 71.115 | Blue Grey | RAL7016 Blaugrau | RAL7016 | GU 2.0 71.116 | Camouflage Grey Green | RAL7008 Graugrün | RAL7008 | GU 2.3 71.117 | Camouflage Brown | RAL8020 Braun | RAL8020 | GU 3.0 71.118 | Camouflage Grey | RAL7027 Grau | RAL7027 | GU 2.7 71.119 | White Grey | RAL9002 Grauweiss | RAL9002 | GU 5.2 71.121 | Light Gull Gray | Gris Gaviota USN | FS36440 | ANA620 | GU 2.6 71.124 | USAF Green | Verde USAF | FS34092-ANA612 | GU 2.7 71.125 | USAF Brown | Marrón USAF | FS30219 | ANA628 | GU 2.6 71.137 | US Light Green | US Verde Claro | FS34151 | ANA611 | GU 3.1 71.139 | US Field Drab | US Marrón Verdoso | FS30118 | ANA617 | GU 3.9 71.140 | US Desert Sand | US Arena Desierto | FS30279 | ANA616 | GU 3.1 71.255 | Light Blue RLM65 | RLM65 Hellblau | RLM65 | GU 1.7 71.256 | Green RLM73 | RLM73 Grün | RLM73 | GU 3.2 71.257 | Light Blue RLM76 | RLM76 Lichtblau | RLM76 | GU 1.7 71.258 | Grey Green RLM74 | RLM74 Graugrün | RLM74 | GU 1.4 71.259 | Grey Violet RLM75 | RLM75 Grauviolett | RLM75 | GU 1.5 71.260 | Light Grey RLM63 | RLM63 Hellgrau | RLM63 | GU 1.5 71.263 | Green RLM72 | RLM72 Grün | RLM72 | GU 2.6 71.264 | Brown Violet RLM81 | RLM81 Braunviolett | RLM81 | GU 1.2 71.268 | German Grey | RAL6006 Feldgrau | RAL6006 | GU 2.2 71.270 | Off-White | RAL9001 Weiss | RAL9001 | GU 4.9 71.271 | German Red Brown | RAL8012 Rotbraun | RAL8012 | GU 3.2 71.272 | German Yellow Brown | RAL8000 Gelbbraun | RAL8000 | GU 2.3 71.277 | Dark Gull Gray | Gris Gaviota Oscuro | FS36231 | ANA621 | GU 1.7 71.278 | Sand Yellow RLM79 | RLM79 Sandgelb | RLM79 | GU 3.7 71.279 | Insignia White | Blanco Insignia | FS37875 | ANA601 | GU 5.2 71.294 | US Forest Green | US Verde Bosque | FS34079 | ANA631 | GU 3.1 71.295 | USN Sea Blue | USN Azul Marino | FS35042 | ANA607 | GU 2.2 71.296 | USAAF Light Gray | Curtiss Grey | FS36622 | GU 5.1 71.298 | M495 Light Gray | M495 Gris Claro | FS36357 | GU 1.8 71.299 | Intermediate Blue | Azul Intermedio | FS35164 | ANA608 | GU 2.5 71.300 | Glossy Sea Blue | Azul Mar Brillante | FS15042 | ANA623 | GU 24.6 71.306 | Sky Blue | Azul Cielo | FS35550 | GU 3.5 71.316 | N. 41 Dark Olive Drab | N. 41 Verde Oliva Oscuro | GU 2.9 Paint set: Hataka (10 paints) HTK-A009 | Dark Earth | GU 9.1 HTK-A015 | Black-Green (RLM70) | GU 7.9 HTK-A016 | Dark Green | GU 9.6 HTK-A017 | Dark Green (RLM71) | GU 10.5 HTK-A023 | Grey (RLM02) | GU 14.1 HTK-A025 | Interior Grey-Green | GU 17.4 HTK-A026 | Sky "Type S" | GU 13.1 HTK-A029 | Light Blue (RLM65/78) | GU 13.2 HTK-A032 | Ocean Grey | GU 13.3 HTK-A034 | Medium Sea Grey | GU 14.2 Paint set: Tamiya (40 paints) XF-1 | Flat Black | GU 3.5 XF-10 | Flat Brown | GU 4.1 XF-11 | J.N. Green | GU 3.9 XF-12 | J.N. Gray | GU 1.9 XF-13 | J.A. Green | GU 8.2 XF-14 | J.A. Grey | GU 8.8 XF-15 | Flat Flesh | GU 15.2 XF-16 | Flat Aluminum | GU 6.7 | Metallic XF-17 | Sea Blue | GU 4.6 XF-18 | Medium Blue | GU 6.5 XF-19 | Sky Grey | GU 7.1 XF-2 | Flat White | GU 7.3 XF-20 | Medium Grey | GU 3.8 XF-21 | Sky | GU 6.7 XF-22 | RLM Grey | GU 4.3 XF-23 | Light Blue | GU 4.5 XF-24 | Dark Grey | GU 5.8 XF-25 | Light Sea Grey | GU 4.5 XF-26 | Deep Green | GU 5.3 XF-27 | Black Green | GU 2.1 XF-28 | Dark Copper | GU 5.3 | Metallic XF-3 | Flat Yellow | GU 3.8 XF-4 | Yellow Green | GU 5.1 XF-49 | Khaki | GU 5.5 XF-5 | Flat Green | GU 2.8 XF-50 | Field Blue | 7.1 XF-51 | Khaki Drab | GU 4.9 XF-52 | Flat Earth | GU 5.3 XF-53 | Neutral Grey | GU 6.6 XF-54 | Dark Sea Grey | GU 6.5 XF-55 | Deck Tan | GU 19.1 XF-56 | Metallic Grey | GU 6.3 | Metallic XF-57 | Buff | GU 18.2 XF-58 | Olive Green | GU 6.1 XF-59 | Desert Yellow | GU GU 20.7 XF-6 | Copper | GU 4.5 | Metallic XF-60 | Dark Yellow | GU 13.0 XF-7 | Flat Red | GU 0.9 XF-8 | Flat Blue | GU 3.4 XF-9 | Hull Red | GU 4.2 Paint set: Lifecolor (12 paints) UA 501 | RLM 70 - Schwarzgrün | GU 9.2 UA 502 | RLM 71 - Dunkelgrün | GU 11.3 UA 503 | RLM 65 - Hellblau | GU 9.1 UA 504 | RLM 02 Grau | GU 6.5 UA 505 | RLM 79 - Sandgelb II | GU 8.7 UA 506 | RLM 80 Olivgrün | GU 8.1 UA 546 | Dark Green | *FS 34079 | GU 7.0 UA 547 | Dark Earth | *FS 30118 | GU 6.3 UA 548 | Light Green | FS 34102 | GU 6.4 UA 549 | Light Earth | FS 30257 | GU 6.8 UA 550 | Sky | FS 34424 | GU 6.4 UA 551 | Grey Green | FS 34226 | GU 9.0 Paint set: Golden Fluid Acrylics (53 paints) 2005 | Anthraquinone Blue 2008 | Benzimidazolone Yellow Medium 2009 | Benzimidazolone Yellow Light 2010 | Bone Black 2020 | Burnt Sienna 2035 | Burnt Umber Light 2040 | Carbon Black 2050 | Cerulean Blue, Chromium 2051 | Cerulean Blue Deep 2060 | Chromium Oxide Green 2140 | Cobalt Blue 2147 | Diarylide Yellow 2150 | Dioxazine Purple 2191 | Hansa Yellow Opaque 2210 | Naphthol Red Light 2220 | Naphthol Red Medium 2240 | Payne's Gray 2250B | Permanent Green Light 2255 | Phthalo Blue (Green Shade) 2270 | Phthalo Green (Blue Shade) 2275 | Phthalo Green (Yellow Shade) 2276 | Pyrrole Orange 2277 | Pyrrole Red 2279 | Pyrrole Red Light 2290 | Quinacridone Crimson 2301 | Quinacridone/Nickel Azo Gold 2305 | Quinacridone Magenta 2310 | Quinacridone Red 2330 | Quinacridone Violet 2340 | Raw Sienna 2350 | Raw Umber 2360 | Red Oxide 2369 | Teal 2370 | Titan Buff 2371 | Titan Green Pale 2380 | Titanium White 2385 | Transparent Red Iron Oxide 2386 | Transparent Yellow Iron Oxide 2400 | Ultramarine Blue 2401 | Ultramarine Violet 2403 | Vat Orange 2407 | Yellow Ochre 2410 | Yellow Oxide 2420 | Primary Cyan 2421 | Primary Magenta 2422B | Primary Yellow 2425 | Cadmium Red Medium Hue 2428B | Cadmium Yellow Medium Hue 2436B | Indian Yellow Hue 2439 | Prussian Blue Hue 2440 | Sap Green Hue 2442 | Van Dyke Brown Hue 5002390 | Turquoise (Phthalo) Interesting. I too have an interest in paints, and as someone who uses mostly Vallejo I was alarmed to find their accuracy is way off in many instances vs. actual FS and RLM colors. This became apparent to me after playing with the ModelShade site for a while, and while an HTML HEX code is the same no matter what platform it’s viewed on, how do I know where the webmaster got his FS or RLM color codes from? With respect to Federal Standard colors, I know you can buy an expensive color chip book from SAE, but haven’t been able to locate an official color chart on SAE site. Your list of tested paints is impressive. I asked my son, who is a computer science major, about coding something to compare a database of HEX or RGB values. He actually called Tamiya, and they’re sending him some kind of database believe it or not. So I started looking at Vallejo’s different lines to see if I could get a handle on first of all how MANY paints they make. It’s more than you think. For example, there are a whole slew of colors that don’t appear in their catalogs. They’re included in kits, but no color swatches are provided on their site. However, occasionally if that part# is Google’d a retailer may stock it, which begs the question how did they get it, and where did they get their swatch they’re displaying on their web site store? My thought was to pickup where ModelShade left off. The site hasn’t been updated for a while and is missing many paint lines. Additionally, how far do you go? Include gaming lines? Candies? Metals? Metallics? Washes? Color shift? Etc. How do you even get an accurate color value? Link to comment Share on other sites More sharing options...
Casey Posted March 4 Share Posted March 4 (edited) 2 hours ago, CFster said: Additionally, how far do you go? Include gaming lines? Candies? Metals? Metallics? Washes? Color shift? Etc. How do you even get an accurate color value? I put my full list in the spoiler above. I do have one full gaming line - from Army Painter - and I did not use those for comparison. To get an accurate color value I use calibrated spectrophotometer with the parameters I described in this post and a gloss meter. Metallics and metals - you can measure color but other properties need more complex geometry measurements. The same goes for color shifts. Candy also has a layered structure that needs to be measured in separate components more than the end effect. Washes are also transparent so their properties are more than just mass tone color. So - not that easy. But thanks to my measurements of Tamiya, I was able to calculate possible answer to your question from February 19: Color swatches on ModelShade do not seem to be based on real measurements. Tamiya does not offer paint with 0,0,0 RGB. Nobody does. Edited March 4 by Casey 2 Link to comment Share on other sites More sharing options...
Jamie @ Sovereign Hobbies Posted March 4 Share Posted March 4 Those usually smaller brands who put in all of the expensive legwork working out what colour some stuff actually is (i.e. which are not simple colour standard call-outs - which many bigger manufacturers still seem to get impressively wrong) do not / will not post accurate RGB renders online for obvious reasons; They (quite reasonably, I'd hope most would agree) would like some potential return on their substantial investment in research and not to literally hand all the homework answers to to a brand of generic high-street brands of paint so people just buy that instead. It's not that it couldn't be reverse engineered by someone particularly motivated to copy someone else's homework, but there seems to be little sense in making it easy for them to do so. 6 Link to comment Share on other sites More sharing options...
PhantomBigStu Posted March 4 Share Posted March 4 (edited) Having spent a little bit of time looking into various paints the last few weeks I absolutely salute the work you’ve done to make it your business Jamie, I’d have probably gone insane in a day. Edited March 4 by PhantomBigStu 1 Link to comment Share on other sites More sharing options...
CFster Posted March 4 Share Posted March 4 (edited) 6 hours ago, Casey said: I put my full list in the spoiler above. I do have one full gaming line - from Army Painter - and I did not use those for comparison. To get an accurate color value I use calibrated spectrophotometer with the parameters I described in this post and a gloss meter. Metallics and metals - you can measure color but other properties need more complex geometry measurements. The same goes for color shifts. Candy also has a layered structure that needs to be measured in separate components more than the end effect. Washes are also transparent so their properties are more than just mass tone color. So - not that easy. But thanks to my measurements of Tamiya, I was able to calculate possible answer to your question from February 19: Color swatches on ModelShade do not seem to be based on real measurements. Tamiya does not offer paint with 0,0,0 RGB. Nobody does. How did you ascertain the real values of those FS numbers? Do you own a physical FS color deck? Edited March 4 by CFster Link to comment Share on other sites More sharing options...
Troy Smith Posted March 4 Share Posted March 4 1 hour ago, CFster said: How did you ascertain the real values of those FS numbers? Do you own a physical FS color deck? AFAIK @Casey owns at least a couple of different issues of FS595 decks from different dates, (I know there are FS595A, FS595B and FS595C issues which have differing colors as well as manufacture dates) as well as other paint standard chips, like RAL and BS381, as well as various books with actual paint chips , like RAF Museum guide with the MAP, chips, various Official Monogram guides on US and German colors, and other specific Luftwaffe books with chips, included. Theses are the ones I have seen referenced, so likely there are more. I own some of these which is why I end up posting in these threads as I have them to refer too, even if they are by eye matches. I wish I liked using enamels, as I'd not have to faff about mixing acrylics to match chips if I did, as I just use Colourcoats. It's been a very sobering and a bit depressing to find out how poor many acrylic paint brands matches are to the known standards. HTH 2 1 Link to comment Share on other sites More sharing options...
Casey Posted March 4 Share Posted March 4 (edited) 5 hours ago, CFster said: How did you ascertain the real values of those FS numbers? Do you own a physical FS color deck? Yes I do. As @Troy Smith noticed I have multiple real FS decks starting from FS595 without any letter (earliest possible) to - and including AMS-STD-595 which superseded FS and uses same identifiers. I also have multiple spectrophotomerers with different geometries to make more comprehensive measurements when needed. On my response I stated which FS595 color deck I used as source for color matching. Edited March 4 by Casey 4 Link to comment Share on other sites More sharing options...
Casey Posted Monday at 11:17 PM Share Posted Monday at 11:17 PM It might be super late for this topic but here is the answer for Acrylic Vallejo Air if anyone stumbles on this topic by random searching: 1 Link to comment Share on other sites More sharing options...
CFster Posted Tuesday at 12:07 AM Share Posted Tuesday at 12:07 AM 46 minutes ago, Casey said: It might be super late for this topic but here is the answer for Acrylic Vallejo Air if anyone stumbles on this topic by random searching: Thank you for your hard work. This is great. Should be made a sticky. I look forward to your comparison of various color ranges. Link to comment Share on other sites More sharing options...
