Ferrari 288 GTO Engine, F114 B. MWT, 1/4.
Hi Mates,
Something a bit different, but a dream machine: what else?!
I hope that kind of kit is allowed in this section.
Tapping, cutting, drilling…
Studs and gasket…
Preparing, checking, testing…
Few parts of the alternator.
Voilà.
Hopping you will enjoy this one…
Pascal:pilot:
Edited by pg265
  • Like 12
3 minutes ago, Lvp said:
Looks fantastic!
Is this something you created yourself? or is it available to us mere mortals?
Thank you!
The kit is from Master Master Modeler Michael from MWT.
It seems that a veeeeeery short reissue is planned.
Pascal
On 1/11/2022 at 7:37 AM, capri-schorsch said:
That's great.
Great that this kit was made and great that you got the balls to build it instead of keeping it in the stash.
Awesome!
Hello,
Thank you!
I couldn’t have left this beauty in the stash without building it!!!
I did some work on the alternator.
All the threads are made, the studs and other threaded rods put to the right length, the parts separated from their supports and prepared...
The cables will be added to the lugs and terminals as soon as the painting is done.
Everything is tested to validate this sub assy and move on to another... or to painting.
Here are some pictures.
Here.
Next soon.
Pascal
Thank you so much Ron.
I’m myself envious of your “T”!!
Pascal
Edited by pg265
Good evening,
Thank you! Ron
The assembly or rather the preparatory work continues.
This part of the kit, the intake, needs a bit of work.
It is necessary to be very careful to remove the part from the tree, to remove their imprint...
It's not a 45 DCOE, but it's WEBER!
Pascal:pilot:
ooh, you bought one then? nice.
The block, oil pan, heads and valve covers  look identical to the 308/F40 as it happens.
I'm liking the 1/4 scale idea and all the ironmongery/gaskets at that size.
I trust you will winding that armature in the alternator!
How did he do the rolled bottom edge on the oil filter that looks really nice.
Love to see it finished, beautiful kit in fairness.
Regards,
Nick
Good evening,
Thank you very much!
the bottom of the oil filter is a machined part.
The engine stand is progressing quietly. The base is made of 4 square section tubes.
They are welded to ensure more solidity. The sturdy pieces are cut and bent to give them their final shape. They will also be welded to the base.
The bends are now welded. They are temporarily held on the structure with the Speed tape to give an idea. The wheels will soon be assembled.
More very soon.
Pascal:pilot:
5 minutes ago, Mumbly said:
Who makes this kit Pascal?
This is Michael from MWT.
  • pg265 changed the title to Ferrari 288 GTO Engine, F114 B. MWT, 1/4.
Good evening,
Thanks ;)
Adjustments and other blank assemblies continue.
The crankcase is installed on the block and equipped with some machined  parts, the block with studs and bolts.
Tightening all nuts will remove all play/gap.
The engine mounts are also bolted.
The back of the block is positioned.
The engine is then positioned on its stand to adjust the dimensions and permanently weld the side and front supports.
More soon.
Pascal:pilot:
